You ever seen this?
  • Stephen
    Шлем ишака
    • 10774
    #46
    wut
    • !kid
      • 1362
      #47
      in the right hands iam sure that wheel can be repaired. dont trash it!
      :borg:
      • sohc12vm20
        • Jan 2010
        • 688
        #48
        wow! lucky nothing happen!:drink:
        • AndrewBird
          The Mad Scientist
          • 11892
          #49
          Is it possible that the caliper broke loose first, causing the wheel to lock and the sudden trauma sheared the strut tube?
          Also, to all of you who want to weld the strut tube to the knuckle, I wouldn't. The knuckle is cast and without preheating and proper welding, there is a good chance you will make it brittle causing it to crack. Even done correctly, there still is a good chance it will crack. It was probably pressed in place from the factory for this reason.
          • Wh33lhop
            • 11705
            #50
            I was also thinking this explanation makes a LOT more sense.
            paint sucks
            • HarryPotter
              • Jan 2010
              • 3642
              #51
              How many times has this happened? One recorded time? No reason to shit ur britches leave ur strut toobs alone.
              John F. Kennedy
              • tg318is
                • Jun 2008
                • 2052
                #52
                Holy crap! Glad youre OK, that could have been pretty nasty..
                Tim.
                • Danny
                  • 14216
                  #53
                  I don't think so because the bolt was sheered clean off, not just lost.
                  • YeOldeBuggy
                    • 208
                    #54
                    What does your ball joint look like? The only reason I ask is because I used to have a 2ga (1995) dsm, and they were infamous for having their ball joints break. I saw one on the side of the road that had a balljoint actually bust on them, and it looked similar to your first pic. I never actually saw the damage it caused, but he was only doing 20 or less when it happened (he was in a turn lane when the ball joint gave out)
                    Thad.
                    Edit: Sorry to see the damage it caused, but at least it's nothing that isn't fixable...
                    Need BMW parts?
                    http://www.blunttech.com
                    or face ultimate peril.
                    • Butler
                      • Nov 2009
                      • 1613
                      #55
                      Thats super shitty man. Do you have another car to drive while you do werk fixing that mess?
                      This makes sense... but you say no?
                      -Nick
                      Originally posted by 87e30
                      First of all: calm the fuck down; second of all; cool story bro.
                      • Sagaris
                        • Sep 2009
                        • 2243
                        #56
                        I cannot tell from the pictures what is going on with the ball joint, but is it possible that the balljoint failed and all the ensuing madness resulted from that?
                        • ubernasty
                          • Jan 2009
                          • 2749
                          #57
                          Originally posted by Danny
                          What?
                          i kid.
                          thats a bitch, i had a bottom spring perch break through on my old car... luckily just pulling into a 7-11 though.
                          sucks man.
                          • dkbmxer002
                            • Nov 2007
                            • 1389
                            #58
                            glad to see you are ok and can handle an emergency situation. that could have been a lot worse like said.
                            sorry to see the car get damaged though.
                            • bejbis
                              • Dec 2008
                              • 596
                              #59
                              Id put money on your caliper bolts breaking or coming out and causing the rest of the damage. Ive seen that happen more than once.
                              -Dan
                              • moatilliatta
                                • 6121
                                #60
                                I always wondered if that would happen..
                                Hope things fix back up easy.
                                @Zakspeed_US
