The 15 Y/O Turbo M42 Build Thread (Now Holley EFI Terminator X Controlled)
  • bmwguy325is
    • May 2011
    • 1263
    #286
    Originally posted by dj buttchug
    ^ agreed. What part of utah?
    s. Slc
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • Dj Buttchug
      • Jun 2010
      • 7637
      #287
      aight mother fuckas. no more dicking around. trans out, and well you can see yourself in my flywheel.... glazed with some nice hot spots
      Pics
      This is roached out. who sees the problem???
      for the m42 dudes. intake air temp sender gm style here fastened with hose clamp
      updated vacuum station for various things :)
      need m20 starter <3
      oh yea almost forgot
      Because racecar
      tehehehehehe
      gay blow off
      more soon homosex boysss
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Dj Buttchug
        • Jun 2010
        • 7637
        #288
        more pics just cause.
        new 16lb flywheel from a member here. shit looks fresh
        now all i need is a clutch that can take my boostagee. clutch ideas?
        Ig:ryno_pzk
        • e30guydownunder
          • Jul 2008
          • 874
          #289
          pretty sure the problem is you used a ghey dualmass flywheel and standard clutch.
          almost positive that the 240mm clutch that suits that S50 flywheel won't fit in a G240 bellhousing. The PO of one of my M42's suitable took to the bellhousing with an angle grinder :/
          That would have been acceptable if they'd gone the next step and welded reinforcing material around the outside, but they didn't....
          - Chris
          Project M42 - 255 @ 19 psi
          • Dj Buttchug
            • Jun 2010
            • 7637
            #290
            weird. this one fits perfectly. its exactly the same size as my dual mass... now that i think of it this is an m20 flywheel that the po was going to use on his s50 so yea i am retardation.
            Ig:ryno_pzk
            • JdmEuroNorth
              • 222
              #291
              Holy backwards friction disk batman!
              Function.
              Form.
              • e30guydownunder
                • Jul 2008
                • 874
                #292
                haha was the disc backwards? i was going to mention the marks but anyhow. The clutch disc in my roady was also installed backwards by the PO. I removed the "worn" clutch to find about 50% of the material at that hub had been worn away. Would have made a little mess!
                The flywheel goes in fine but when you are running a 240mm clutch setup the pressure plate contacts the bellhousing. I was going to use a G260 on my M42 to use the 240mm clutch setup I had.
                There are plenty of HD 225mm clutches anyway so it should just be a case of pick your budget and clutch to match that. There are a heap of people using eBay things with success but they also seem to be a bit hit and miss in the success stakes. I would just go to your local preferred clutch shop (reputable) and pay for what ever they recommend.
                The power we are talking isn't hard to manage, just a matter of decided how driveable you want it.
                - Chris
                • Massimo
                  • Jan 2008
                  • 3207
                  #293
                  BECAUSE RACECAR you need this.
                  • Balleristic31
                    • Aug 2009
                    • 4198
                    #294
                    Like
                    Edit: dude how r u low without cutting struts?
                    -NICK
                    • bmwguy325is
                      • May 2011
                      • 1263
                      #295
                      Looks fun but kinda a PITA going through the drive through. I like the more clutch but more 10k Limiter!
                      • Dj Buttchug
                        • Jun 2010
                        • 7637
                        #296
                        lol yea. apparently i cannot install a clutch correctly. thanks for the info tho. Ill make sure i get the right size to fit.
                        Originally posted by Balleristic31
                        Like
                        I dont know... my ksports go really low so i never had to cut the strut. Im almost maxed out in the front tho so i will prolly cut em eventually
                        Ig:ryno_pzk
                        • bloodshot-e30
                          • 1494
                          #297
                          i dont see oil under your car :(
                          ^Back in the game^
                          BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
                          FS thread:
                          http://www.r3vlimited.com/board/showthread.php?t=214105
                          • Dj Buttchug
                            • Jun 2010
                            • 7637
                            #298
                            actually there is Ps fluid. my rack is shot. engine is tight tho :)
                            Ig:ryno_pzk
                            • Good & Tight
                              • Apr 2004
                              • 2057
                              #299
                              Check this site out they make good clutches for reasonable prices. http://www.clutchnet.com/
                              I used the 3 puck solid hub disc with a Centerforce pressure plate on my M10, held 360rwhp/333rwtq.
                              For your mickey mouse turbo I would suggest a 4 puck, it's less aggressive and will work with your pressure plate.
                              Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                              ____________________________
                              E-mail Panayiotisx2@gmail.com
                              Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                              • Dj Buttchug
                                • Jun 2010
                                • 7637
                                #300
                                this will be in my hands in the near future.
                                Ig:ryno_pzk
