The 15 Y/O Turbo M42 Build Thread (Now Holley EFI Terminator X Controlled)
  • Massimo
    • Jan 2008
    • 3207
    #331
    WTF is going on here is the car running, is there any updates? I want to see vids.
    Valve cover is tits btw.
    • Dj Buttchug
      • Jun 2010
      • 7623
      #332
      Update time! First off I must apologize to all my fellow r3vers for lack of progress. Now that I have finished my degree and I am back in socal with all of my e30 resources the build will be speeding up.
      Speaking in numbers the car is 90% done. I have odds and ins to tie up, cosmetic issues to sort out and some good cleaning to take care of.
      Previously my coolant lines to the turbo ran in a big loop around the engine bay starting from under the intake manifold and ending back behind the valvecover. I opted for a re route and I am much happier with the results.
      As you can see here both lines run in the same direction and the oil feed follows suit as well. Much cleaner than before
      Next was electrical. If you want proper information you need reliable gauges flashing the right numbers at you. I spent the better half of a whole day creating my own harness for the gauges. Turned out well imo. My only issue is the VDO boost gauge. The bulb is much dimmer than the others. I may switch it out for a brighter light source.
      Heres a better bay shot with the COP kit and my turbo blanket. Keeping the engine bay cool has been a bit of a task but the wrap and the turbo cover make a huge difference.
      More to come.
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
        • 37825
        #333
        That's the money shot right there! Nice. :)
        Classic BMW Specialists
        Santa Clarita, CA
        www.BimmerHeads.com
        • ak-
          • 12422
          #334
          Hell yeah finally.
          Going absent and shit! Hope to see it soon some time!@#()!^#
          This is the LED bulb you need for that specific VDO gauge
          1991 325iS turbo
          • e30guydownunder
            • Jul 2008
            • 874
            #335
            Nice work on the turbo lines, I have run mine exactly the same way.
            - Chris
            Project M42 - 255 @ 19 psi
            • Dj Buttchug
              • Jun 2010
              • 7623
              #336
              Heres how the car sits as of now. Ive come to the conclusion that 205s suck. Its just not enough meat to put anything reasonable down and well, yea.
              So ive opted out of 16s entirely on both my e30s. Running a square 225/50/15 setup here. I really like the look of 15s. Think ill probably end up staying with that size for a while. Form is nice but this car is so retarded, function and drive-ability are more important goals of mine.
              In other news Ive been trying to diag a no spark issue with my MS. Heres the guts of the system. Still need to run some more tests. Really pissing me off right now.
              Stock brakes are upgraded to some vented discs and some better pads. Will see how these work out. yes, I know, two lug nuts=fail. Dont worry, just a roller for now.
              My goal is to be back on a dyno in two weeks or less. By then I should have the car back up to test out the new clutch and actually see what this thing can put down. Its been over a year and a half since Ive been there with the car.
              Ig:ryno_pzk
              • lambo
                Captain Scene Points
                • 10953
                #337
                So weird not seeing this thing on the pink fagmobile wheels... I miss it...
                • Dj Buttchug
                  • Jun 2010
                  • 7623
                  #338
                  dont worry i have something equally obnoxious in the works.
                  Ig:ryno_pzk
                  • freeride53
                    • 11972
                    #339
                    do you live in SD now? i'll be moving down and into my new house in a few weeks. lets rendezvous.
                    1983 Peugeot 505 STI
                    1992 Volvo 240 Wagon
                    • Dj Buttchug
                      • Jun 2010
                      • 7623
                      #340
                      I sure do, and yes we must! the goon squad will assemble!!!
                      Ig:ryno_pzk
                      • MF DOOM
                        • Apr 2012
                        • 944
                        #341
                        My thoughts exactly. Looks like such a different car without them.
                        Excited to see numbers!
                        • Dj Buttchug
                          • Jun 2010
                          • 7623
                          #342
                          Im also opening up a whole new can of mo fackin worms.
                          Im currently tossin this idea around. Full custom intake plenum. Ive been researching flow problems/ design differences ect for quite some time.
                          Bottom line is the stock M42 intake sucks a fat chode. So does the TB.
                          I will most likely run a m50 tb with a JUN style plenum design like this.
                          In for ideas/ guru's/ smart techy peeps for input.
                          Pics of mock up model built from high density card board coming soon.
                          The second render is designed with 2 barriers placed in areas close to cyl 1 and 2 to help aid in sufficient flow to all cylinders. Very interesting stuff.
                          Ig:ryno_pzk
                          • unevolved
                            • Nov 2011
                            • 714
                            #343
                            Did you do that CFD yourself?
                            1991 318i SOLD
                            2003 325i SOLD
                            Racecars and stuff.
                            • 325ix
                              • Aug 2009
                              • 7783
                              #344
                              MMMMmmmm, I like the sound of that intake.
                              • e30guydownunder
                                • Jul 2008
                                • 874
                                #345
                                What software are you using to do the simulations? I have something I have been working on in Inventor ;)
                                - Chris
