The 15 Y/O Turbo M42 Build Thread (Now Holley EFI Terminator X Controlled)
  • Dj Buttchug
    • Jun 2010
    • 7637
    #361
    Originally posted by lambo
    I apologize if you mentioned this earlier, but are those real Brides or reps? How comortable are they?
    They are not real. They are actually pretty comfortable and decently built. Ive been really pleased with them ever since I bought them. They work well and hold you in great. Like all race seats, its not that fun to drive around for long periods of time. Sitting in them gets annoying after a while.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    • Dj Buttchug
      • Jun 2010
      • 7637
      #362
      In other news my m42 powered sedan gave up the ghost this evening. Driving along and all the sudden no power and a very loud metal on metal noise coming from the engine. If I let off the gas the sound stops immediately. Car began to slowly overheat. Dies if you dont keep your foot in it. Misfiring, the whole lot of awesome. Compression test reveals 30psi on cyl#1 and 40psi on cyl#2. 3 and 4 are good at 180ish.
      ugh. fml.
      Ig:ryno_pzk
      • Good & Tight
        • Apr 2004
        • 2057
        #363
        You need to throw a big six or 24V turbo setup in that thing and quit dicking around with that 4 popper.
        Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
        ____________________________
        E-mail Panayiotisx2@gmail.com
        Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
        • Dj Buttchug
          • Jun 2010
          • 7637
          #364
          couldnt agree more
          blown head gasket of peace.
          Ig:ryno_pzk
          • Good & Tight
            • Apr 2004
            • 2057
            #365
            Originally posted by Dj Buttchug
            couldnt agree more
            Too much timing burned through that gasket.
            • wazzu70
              • Jan 2005
              • 1143
              #366
              One of the few times I will have to disagree with Otis. You should stick with the 4cyl because M42 turbos are unique :) The lure of cheap easy 24v power is hard to overcome though!
              On the gasket he is right, too much timing.
              Also, did you ever dyno the car? I don't think I have seen a chart for this? Just curious.
              -Nick
              M42 on VEMS
              • Dj Buttchug
                • Jun 2010
                • 7637
                #367
                The thing about this gasket is that it is from a completely stock NA m42. I have two cars.
                Not sure what could have caused this to happen. I take very good care of my engines.
                I am to invested in m42s now to back out. I may swap my other car someday but the turbo one is here to stay. :up:
                Ig:ryno_pzk
                • wazzu70
                  • Jan 2005
                  • 1143
                  #368
                  Glad to hear you are sticking with the turbo M42!
                  -Nick
                  M42 on VEMS
                  • Dj Buttchug
                    • Jun 2010
                    • 7637
                    #369
                    well the 225s dont work. Im at 8psi running off just the stock wastegate setting and I can light the tires up in 1st and part of 2nd.
                    balls.
                    Ig:ryno_pzk
                    • Massimo
                      • Jan 2008
                      • 3207
                      #370
                      Bit late to the party here. Might I suggest that the baffle in the center their be more designed like the shape of a wing (or halve teardrop) with the flat edge facing the throttle body. That should reduce the swirl you have going on there and increase cylinder 1 velocities.
                      Other then that I am waiting for the end results :up:
                      • Dj Buttchug
                        • Jun 2010
                        • 7637
                        #371
                        I was able to get some more tune time. Things are looking up as my goal for 300+ whp is now closer than ever.
                        blue is torque red is hp. here we are only at just a little over a bar of boost. AFR is below in black. Its a little rich, better safe than sorry...
                        its falling flat on its face around 6100 revs. the m42 throttle body is just not cutting it anymore. It cant support enough airflow to sustain the engine at anything above 6. I will be making adjustments for a m5x throttle body. A whole new intake is in order soon.
                        Ig:ryno_pzk
                        • wazzu70
                          • Jan 2005
                          • 1143
                          #372
                          Nice results. A new manifold/tb should work well.
                          -Nick
                          M42 on VEMS
                          • Dj Buttchug
                            • Jun 2010
                            • 7637
                            #373
                            I think it will make a huge difference.
                            A few things happened that we didnt expect. First off the car would not keep traction. We had to air the rear tires down and even with 3 full size dudes sitting on the trunk it still managed to spin tire. The torque my turbo is creating is quite impressive for an m42.
                            the rollers are also small and pretty slick. We managed to make it work
                            Also a note to anyone running a m20 clutch and fly conversion on there m42 with a g240 trans. make sure you cut and extend the clutch slave pushrod. If you dont the cylinder will push out of the slave housing and piss fluid everywhere.
                            ask me how i know.
                            Will have a video up soon.
                            Ig:ryno_pzk
                            • wazzu70
                              • Jan 2005
                              • 1143
                              #374
                              Is your cam timing stock? If so you can retard the intake a few degrees for dome more top end.
                              You shouldn't be losing traction on the dyno with that level of torque. I know smaller rollers hold less torque. I havent used a dyno with two rollers like that though.
                              Either way, excited to see the build keep progressing!
                              -Nick
                              M42 on VEMS
                              • e304me
                                • Feb 2006
                                • 1374
                                #375
                                What ignition timing are you running? I am running waaay dialed back timing on my DASC but it isnt intercooled. I need to have it professionally tuned.
