The 15 Y/O Turbo M42 Build Thread (Now Holley EFI Terminator X Controlled)
  • TheTacoMan
    • Nov 2011
    • 2308
    #556
    It may not be a gif but.....
    Take that. ;D
    • Dj Buttchug
      • Jun 2010
      • 7638
      #557
      avatar'd lol
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Schnitzer318is
        • Jan 2008
        • 2057
        #558
        ^That's pretty cold. Mine will fluctuate a little... but not nearly that much.
        I am running an 89C thermostat I believe. No drilling though. On a warm day sitting in traffic I'm at like 185ish with the efan on... basically same temperature as if moving at highway speeds with no efan. Mine never fluctuates like you describe unless I switch my efan on in traffic... then temps will go from like 205 back down to my normal operating temp of ~185. I run mostly water too... doesn't get that cold here in TX.
        I'll keep looking for you to post your msq. Still want to do a full comparison to what I am running. Mainly because you are running no ICV and getting a nice start and idle. With no ICV I have a helluva time.
        "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
        91 318is Turbo Sold
        87 325 Daily driver Sold
        06 4.8is X5
        06 Mtec X3
        05 4.4i X5 Sold
        92 325ic Sold & Re-purchased
        90 325i Sold
        97 328is Sold
        01 323ci Sold
        92 325i Sold
        83 528e Totaled
        98 328i Sold
        93 325i Sold
        • Dj Buttchug
          • Jun 2010
          • 7638
          #559
          todays update: cracked manifold. many noises, much leaks, little bewst, no bitches
          pics tomm
          Ig:ryno_pzk
          • Schnitzer318is
            • Jan 2008
            • 2057
            #560
            Weaaaaaaakkkkkssssaaaaauuuuuuccccceeeee... Been there too.
            You using m50 mani flipped upside down with last 2 cylinders chopped off?
            91 318is Turbo Sold
            06 4.8is X5
            06 Mtec X3
            05 4.4i X5 Sold
            90 325i Sold
            97 328is Sold
            01 323ci Sold
            92 325i Sold
            83 528e Totaled
            98 328i Sold
            93 325i Sold
            • Dj Buttchug
              • Jun 2010
              • 7638
              #561
              yea but I pretty much chopped mine all up and built it the way i wanted. So my pipes route a little different.
              to solve the issue I need to weld in a flex section to my down pipe. I think it happened when I came out of a parking lot and scraped my exhaust. Too much stress and it just snapped.
              also Just now reading your previous post. Ill send you my file!
              Ig:ryno_pzk
              • wazzu70
                • Jan 2005
                • 1143
                #562
                Do not like...
                -Nick
                M42 on VEMS
                • MF DOOM
                  • Apr 2012
                  • 944
                  #563
                  • Schnitzer318is
                    • Jan 2008
                    • 2057
                    #564
                    I had to add (well, have my exhaust guy add) quite a bit of gusseting to the mani to stop cracking. The weight of the turbo and downpipe was causing multiple failures. Now you could drive a tank over it. I've scraped/hit the exhaust many times since and not had any issues.
                    Send the whole project please, not just the msq. If you send just the file my Tunerstudio gets pissed off.
                    91 318is Turbo Sold
                    06 4.8is X5
                    06 Mtec X3
                    05 4.4i X5 Sold
                    90 325i Sold
                    97 328is Sold
                    01 323ci Sold
                    92 325i Sold
                    83 528e Totaled
                    98 328i Sold
                    93 325i Sold
                    • wazzu70
                      • Jan 2005
                      • 1143
                      #565
                      IMO the whole project thing is dumb. The config file should have everything you need. Its a PITA to look at a tune when you have to get the project files too. I don't see any benefit and I see a lot of PITA :)
                      Just my mini rant.
                      -Nick
                      M42 on VEMS
                      • Good & Tight
                        • Apr 2004
                        • 2057
                        #566
                        You need one of these...
                        Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                        ____________________________
                        E-mail Panayiotisx2@gmail.com
                        Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                        • wazzu70
                          • Jan 2005
                          • 1143
                          #567
                          Truth. If I don't make my own.....Otisfold for sure :)
                          -Nick
                          M42 on VEMS
                          • Dj Buttchug
                            • Jun 2010
                            • 7638
                            #568
                            It would be nice! but then I would have to re do my downpipe and IC piping to fit it.
                            Id also need one without the external wastage flange.
                            The worst part about whole thing is I have to un wrap my manifold. It was so nicely done :( and mani wrap is stupid priced.
                            Ig:ryno_pzk
                            • einhander
                              • Apr 2004
                              • 2024
                              #569
                              ^ Well, you're Polish so you've got plumbing skills built into your genes.
                              2011 1M Alpine white/black
                              1996 Civic white/black
                              1988 M3 lachs/black
                              • Good & Tight
                                • Apr 2004
                                • 2057
                                #570
                                Send me your crappy manifold and I can duplicate it so you don't have to change anything around.
