you sir give me inspiration to tarbo my m42 :-)
Turbo M42. The journey to 300+whp
I drive mine daily so my tune is mild, I wanted it to last. I would love to add more boost and make more power, but I don't want to be fixing broke parts. I have a tune that makes more power but with my gearing doesn't benefit in any way. The current tune is much smoother and defined power band. I think with your plan of 15-18 psi, you will make 275whp or more.
Originally posted by Dj Buttchug View PostIf thats how it is, my 15-18psi idea may have to be toned down a little.
haha... NOT. ;)
I wasn't having a huge problem with traction as long as I was going straight when I had my summer tires on the car and teh 4.10, but first gear was really too short to even do anything. I would shortshift into second around 5k rpm if I was accelerating hard. I'm hoping 3.73 will be long enough to let boost build but not so long that I'll have to work around the (now much larger) powerband.
So I take it you still have the stock ECU in the car? I would just take your time, just so you don't risk it...
As far as my oil feed line goes, I ran an oil line from the factory oil pressure switch to a t-fitting, and the turbo feed and the pressure sender are run from there. The fitting i mounted to the frame, so I don't have to worry about the vibrations that are kinda notorious for killing those senders. VDO sells a sender that has a post for the gauge and then an on-off 7 psi post for the idiot light, so I can keep the factory functionality.
Originally posted by gearheadE30 View PostI wasn't having a huge problem with traction as long as I was going straight when I had my summer tires on the car and teh 4.10, but first gear was really too short to even do anything. I would shortshift into second around 5k rpm if I was accelerating hard. I'm hoping 3.73 will be long enough to let boost build but not so long that I'll have to work around the (now much larger) powerband.
Originally posted by CabbE30 View PostI can haz pink wheels???
But seriously the only e30 that could pull off those wheels. Good thing mines exactlt like it. xP
Turbo M42 Build Thread :Here
Ig:ryno_pzk
I like the tuna here.
Originally posted by lamboButtchug. The official poster child of r3v.
Awesome build on the engine mate. I'm going to go with a fresh Head Gasket and some Big head bolts first up. I'm aiming to get over 150kW and keep it nice and responsive. We shall see. With my car weighing maybe a fraction under 1000kg's not like I need massive power :)
Was planning a balanced and forged build, but the coin is a lil out of reach currently and not really necessary for the power I'm talking I recon.
In for more progress on this thing!
Car is looking great! Awesome job on the turbo build! Hopefully Ill get to see it at the next friday meet! You gonna be going? I haven't been in a while lol
1991 LS1 Swapped 318is
Instagram:
https://instagram.com/saltybeast/
LS Build Thread:
https://www.r3vlimited.com/board/for...s-e30-ls1-swap
Originally posted by ian e30 318is View PostCar is looking great! Awesome job on the turbo build! Hopefully Ill get to see it at the next friday meet! You gonna be going? I haven't been in a while lol
Ig:ryno_pzk
