Gabriel's 1991 318i sedan
  • scabzzzz
    Estado de mierda de encargo
    • 6871
    #46
    Nice white car in the background ;)
    Ima hit you up on some m42 advice later Gabe..
    • Kershaw
      • 11822
      #47
      put the trumpet back inside the air box.
      it is there for a reason. you are losing horsepower without it.
      other than that, great score for $400.
      AWD > RWD
      • Pantless Spency
        It's McRib time!!!
        • Feb 2011
        • 7283
        #48
        what exactly did you use for your chalkboard hood??!?!?! i really want to do this with an extra hood :)
        • rightcoastbias
          • 449
          #49
          Resolving mechanical issues doesn't make the car pretty. The hood is chalkboard, the fenders are dead paint.
          A certain forum member gave me this iS trunk spoiler. I sanded it (250,400) and gave it a coat of matte plastic fusion spray paint. Then drilled holes in the decklid. :D
          :up:
          M52B28 OBD1 - G240 - S4.10
          Stuff for Sale: 24v swap parts
          • Pantless Spency
            It's McRib time!!!
            • Feb 2011
            • 7283
            #50
            :up:
            So awesome, is it sprayed on ? How do you spray this stuff haha
            • GunMetalGrey
              • Dec 2010
              • 1499
              #51
              I like where this is going, feel free to do write ups with pictures on the cam adjustment, and chip install.
              • rightcoastbias
                • 449
                #52
                Roll on.
                My process was:
                - Sanded the hood with 250grit.
                - Washed with Acetone.
                - Hung hood from Garage ceiling
                - Sprayed with 1 rattle can of Rustoleum Auto primer
                - Applied 1 pint of Chalkboard paint with a 12" matte finish roller.
                Cam adjustment is documented on M42club. Chip install comes with chip. I can do my own write up if requested.
                • Pantless Spency
                  It's McRib time!!!
                  • Feb 2011
                  • 7283
                  #53
                  Roll on.
                  My process was:
                  Ah very ingenious I'm going to have to try this myself, it looks awesome.
                  • GunMetalGrey
                    • Dec 2010
                    • 1499
                    #54
                    Chip install hard? Or is it a plug in situation?
                    • dreamchasin
                      • 3892
                      #55
                      Chip installs are very easy, you pop open the side of the ECU and pull out old chip, plug in new chip.
                      90 325is alpine2 m50b25 becoming a dorifto car.
                      • GunMetalGrey
                        • Dec 2010
                        • 1499
                        #56
                        Solid
                        • Winning
                          • 39
                          #57
                          If you buy a chip buy from MarkD
                          • rightcoastbias
                            • 449
                            #58
                            I am certainly not the first one to do this.
                            GIS: "Chalkboard e30"
                            http://www.flickr.com/photos/neil113...n/photostream/
                            I understand the "trumpet" is supposed to reduce pressure losses by creating a less abrupt expansion of the flow path in to the airbox, but I really like the sound of my 4-cylinder gasping for air. :firehop:
                            http://www.dsylva-tech.ca/
                            Yes, buy a chip from MarkD. Do not waste your time with any other chips. Your M42 will love you for it.
                            • rightcoastbias
                              • 449
                              #59
                              Yay, its going to be a busy weekend.
                              • rightcoastbias
                                • 449
                                #60
                                Well, I'm quite happy with what were got done this Saturday.
                                -replaced inner/outer front control arm ball joints
                                -replaced inner/outer tie rods
                                -rebuilt front and rear calipers
                                -installed Ireland engineering Rear trailing arm and subframe bushings
                                There is still so much to do.
                                A very welcome sight:
                                Throwing subframe back in tomorrow. I need to pull the trigger on a suspension. I'm stuck on H&R race and Bilstein sports, but unlikely to happen on this budget.
