The Bronze Bomber
  • Hey_You
    • Nov 2009
    • 963
    The Bronze Bomber
    So I figure since there are some big changes to my car in the works, that I could start a thread here. (On second thought, I probably should have posted in the Projects Forum. Change if needed Mods) A bit has changed from the day I bought it until today. So why not show some of the steps taken, and yet to come with you folks.
    Oddly I don't have a picture of the day I bought it, I did, but it's M.I.A. But it looked like this, minus the tint (A/C didn't work, and living in Riverside, CA at the time sucked, had to cool off the interior while parked)
    So then I decided it was time to lower the thing. I went with B+G springs as I was somewhat familiar with the brand from having a MK2 GTI before the e30. I tried to wait until I could get Billy Sports before installing, but I couldn't resist, threw them on with stock shocks.
    Just the fronts installed
    Then the next day I finished off the rear.
    I figured I would tint the tails too. I used Testors R/C car translucent paint. First to red out the orange. I ended up buying the wrong red. I got damn Hot Rod Red instead of Regular Red. It would have been perfect, but I added one too many coats of it, and the orange in the red brought out the orange in the tails some. Then the spray tint, and many coats of clear.
    After this, my shocks blew, I knew it would happen, but man it happened fast. Within 2 weeks. Then more running problems. From the time I purchased the car I have replaced the spark plugs (x2), wires (x2, stupid Bimmerworld wires were shit, won't ever do business there again), cap and rotor, in-line fuel pump, fuel filter, air filter. Then the in-tank pump gave out. So out it went and in a new one did, boom, running again. (Sorry I don't have a lot of pictures with that stuff, I wasn't exactly in a picture taking mood at the time. More pissed than anything and wanted to just get my car going again). All was good. I decided to play around with the car a bit more. New shift boot, and rear parcel tray covers.
    The rear didn't turn out too great. It's quite difficult to keep the fabric tight, and keep the lines straight at the same time. The picture makes it look better than it is. I then decided to tuck my bumpers and paint them black, along with making my awesome bottle caps somewhat hidden.
    Then one day my car stalled, and wouldn't restart. I started scratching my head and couldn't figure out why. I checked my plugs (even installed another set just to be sure) and they were fine. I was getting spark. I checked my fuel and had plenty of pressure (had just replaced my FPR, and both pumps). I then checked my coil, and it was badly corroded. I bought a new MSD Blaster 3 coil and installed it. Still wouldn't start. So I had it towed to my house. I knew I had a head gasket leak from the milky oil that was on my dipstick. So I decided to pull the head. I took it to the machine shop to be checked out and decked. Turns out it wasn't in too good of health. The previous owner didn't change the coolant and rusted the cooling system. It ate through chunks of my head, so I had the machinist fill the voids, and rebuild the head. Only reused the cam. Put it back together, still nothing, well fuck. I had it towed to the shop I used to work at for them to diagnose. They managed to get it to idle, but it was running WAY too rich, and wouldn't run above idle. After hanging out enough, I got my old job back (after being unemployed for 10 months after relocating areas). Turns out someone cut the wire for the Coolant Temp Sensor and soldered on a resistor. Why not replace the sensor you cheap bastard! It took me FOREVER to find that after manually checking EVERY other option. Got her running, then a few months later I had an issue with the top end. Short story, I have a new shortblock, and am re-rebuilding the top end. I also installed new shocks, I still couldn't afford Billy's at the time, so cheapo's they are. But they work for now, and I can easily do the labor again once I rework the suspension. Plan now is for boost. And this is where I leave off. Some new pictures but no details of whats going in until I get the parts and take pictures.
    I couldn't help myself, I cleaned up some parts, and hung them on the engine just to see what it would look like. I still have to refresh the head.
    And then I drilled my oil filter housing for the feed, and oil pan for the drain. Still have yet to tap them or buy fittings
    And what will be replacing the e36 seats I have in there now. Sorry the picture sucks, but the lighting was bad, and I sucked at holding the camera still. But the logo does say Recaro
    More updates and pictures will be coming, but I can't afford to update this thread daily, it's coming together one paycheck at a time.
    85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
  • Constantine
    • 862
    that is going to be a good looking m10!:)))
    1988 E30 M3
    My eBay store: http://stores.ebay.com/Uberpart
    • Erik
      • Oct 2005
      • 5370
      Your motor tidbits match my door handles! :D Lol
      -Erik
      Originally posted by 87e30
      • !AjHoWzA!
        • Jan 2010
        • 1140
        Nice car. Cant wait to see how it turns out
        '91 318is
        • moatilliatta
          • 6121
          what are the seats out of?
          @Zakspeed_US
          • jizo
            • 1191
            Dont know which direction your going with it but....Would it been cost effective to just drop and M50????
            • camshaftgsxr
              • Aug 2011
              • 416
              I love the bronzit and black theme...
              BroWorks.com Bro is a lifestyle
              • e30maddmann
                • 4
                nice recaros, I have a set and I love them.
                • chondamx
                  • 247
                  I <3 boosted M10.
                  '91 318is M52 Turbo (in pieces)
                  • Shangsta
                    • 1485
                    Are those recaros out of an Alfa Romeo?
                    :shock:
                    • grippymonkey
                      • Jun 2011
                      • 759
                      good job man... and those seats are fresh!
                      GRIPPY'S*GARAGE
                      • E30me
                        • 21
                        Gotta photo of the finished engine bay?? The Plaid looks great on the read deck. Nice job.
                        • Wishno87
                          • 6025
                          Been a long time since I have seen someone do something with an M10. Good job. The "all black everything" is a little much though.
                          • Hey_You
                            • Nov 2009
                            • 963
                            Thanks for all the positive comments everyone. I have been doing what I can when I can so I'm looking forward to the finished outcome. I'm not sure if the Recaro's came out of anything. I bought them from a friend who had them in a 71' Mustang. They are Classic C's. The black theme will change once I can rid my ride of the DB's. But it probably won't change too much. Black just flows with bronzit, too me at least. And yes, the m50 swap probably would have been much faster to complete. However, my engine will be completely refreshed, and should be making a bit more power than a m50 once complete. A m50 is a possibility in the future, but probably not for this car, I have a 240z that needs a heart ;)
                            • Hey_You
                              • Nov 2009
                              • 963
                              Ordered some top end parts from Ireland Engineering. New aftermarket intake and exhaust valves, stock size. Rocker locks, and Double Valve springs. [Picture will be here once I get the parts delivered.]
                              I also won a snail on eBay. It should be here Monday. I will need to clean it up/rebuild it but that can be done fairly easy, and I have all the tools needed at my disposal. And continued to purchase my manifold. Went with the boost brothers manifold (I have read some negatives, but I have talked to who I was buying it from, and they said no problem returning if it doesn't fit) This is a budget build to get my feet wet after all. It will most likely be getting some black header wrap.
                              Then I took a small break from buying car parts, and bought something else
                              He's gonna be beast. Great Dane/Mastiff mix. Might possibly top my last 160lb Rottweiler in size.
