Yep thanks again. in the next couple days ill get the 6al w/ 2 step. Prob have to test that also.
new project/drift car
Good deal, i started a build thread for my 5.0 project. Check it out.
Instagram @rebellionforgeComment
Thing is gnarly!Fuel pump works. Chin hair no care!
Old fuck across the street hates me now. Pretty sure it means he's a terrorist. Howdy neighbor.
6al is wired up and works great. Crisp clear and super snappy now. Doesnt break up @ 4.5 and 5k but still only revs to 5.5k. Its super crisp up to 5.5k but wont go past it. Think maybe my tach might be off since i have a 6k pill in it. May switch to a 7k pill and see if i can rev higher.Comment
Video proof of a killer burnout to piss your already pissed off neighbor off more............or it never happened.6al is wired up and works great. Crisp clear and super snappy now. Doesnt break up @ 4.5 and 5k but still only revs to 5.5k. Its super crisp up to 5.5k but wont go past it. Think maybe my tach might be off since i have a 6k pill in it. May switch to a 7k pill and see if i can rev higher.
Knowing it was gonna be down for a while, so.....
Then
Aluminum rad and taurus fan. Had to cut everything out to make room. 3.8l Taurus fan moves 2500cfm on low and 4500 on high. Its a little thick compared to a slim line (about 3.5-4") but with a bit of ducting i should have zero issues with it running hot in any condition.
Lower mount is all done. Gonna start the top then move onto the rear subframe and racecar switch panel.Last edited by eurotrash; 04-28-2013, 07:40 AM.Comment
Nice! Is that little brace going to be enough though? It seems like you've cut a lot of the core support bracing off without replacing much of it with other bracing...Comment
It was all sheet metal for the lower support so it should be fine. Havent started up top. Gonna box in the remaining upper rad and weld a nut on the back and build a bolt on upper rad mount then brace that going back down to the frame. Also gonna run anouther bolt on brace back behind the whole rad assembly in front of the pully to keep the frame from movin around. I wanted to be able to basicly just yank the engine straight out. Plus the rad had to be tilted way forward for the taurus fan to fit.Comment
Broke an axel after rallying the shit out of the car on the 4th of july. Also ordered up the last couple of dinan eccentric bolts for the rear subframe (to the tune of $140 fuck) and ill be ordering as much of the hydro clutch conversion as i can afford.Comment
