Abit's 318iA m20b30 + pssycat cam and more...
  • Link
    • May 2012
    • 834
    #196
    Your car has come a long way! Keep it up.
    View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
    • Northern
      I like cupcakes & sh!tboxes
      • 5283
      #197
      Originally posted by abit
      thanks.
      *Calipers together with brake caliper supports is from Ford Mondeo MK3 (about 2000-2007 years, they are the same for all engines)
      *Brake discs is from audi a3, i think It was 1.8t model who has 288mm rotors, you should just redrill bolt pattern, because audi has 5x100 pcd, easy job.
      supports etc will bolt on, just some minor modifications have to be done to disc brake dust protection and you maybe will need some small spacers between hub and caliper support.
      Do those Ford calipers bolt on without an adapter?
      I'm assuming since the Audi A3 has a 57.1mm centre bore, they bolt right on once the bolt pattern is redrilled?
      Originally posted by priapism
      Originally posted by shameson
      • abit
        • Jul 2011
        • 423
        #198
        almost, just need 6mm(center 12mm, out ~25, and 6mm width) small spacers between brake carrier and wheel knuckle.
        ....discs, center centering bore also should be machined (as I remember BMW has ~1mm larger centering diameter, so -1mm should be machined off), and of course re-drill bolt pattern, yes.
        http://instagram.com/mundieriss
        my 88' m20b30 HERE!
        • abit
          • Jul 2011
          • 423
          #199
          ok, one shorty :D
          finally tuned up my engine management with #402 ecu, now car runs sooo good....actually ran
          some random shot before we installed all gadgets for tuning :D
          had so much good time rolling down the streets with full throttle, dayummn :D
          one more shot with other bangers :D
          yeah https://instagram.com/mundieriss/
          and then, so much fuuuck, hit rear underneath of car so bad, that it bend my exhaust from round to flat and exhaust banged right in my fuel tank, breaking the fuel cells connecting pipe, so fuel started leaking straight on hoot exhaust, so much luck that it didn't catch fire, dammn, so now I need to repaid my tank.
          stay tuned :)
          my 88' m20b30 HERE!
          • abit
            • Jul 2011
            • 423
            #200
            fck yeah, fuel tank is repaired, and we roll again :D
            first, bought IX body plastics, test fitted ....mm, when I bought them, I thought that these arches will make my wheel arches bit wider, but I realized that IX arches just makes wheel arch lower, fail :D... so already trying to sell them :D
            next, fuel tank
            it was quite rusty there and a hit from exhaust was heavy enough to crack tank
            and how it looks now
            then met one of my mates, with his Swedish turbobrick ;D
            and then, finally, real testing and fun :D
            ok, enough... :D resume, car now is much more powerful sliding it around the corners than last year, and i love it :D
            see yaaa....
            my 88' m20b30 HERE!
            • abit
              • Jul 2011
              • 423
              #201
              It's now official
              I think these are ok numbers for my low comp engine ~9,75:1
              my 88' m20b30 HERE!
              • Nisse Järnet
                • Aug 2013
                • 1221
                #202
                E36 wheels on the Volvo? Looks cool :)
                Good power from the M20!
                E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                E30 M50 6 spd 764whp @ 24psi.
                E30 M20 6 spd 675whp.
                • stonea
                  • 2892
                  #203
                  Great build! I've read it about 4 times, lol. Finally subscribing. Also is it weird that I think I liked it more with miss colored bumpers and fenders?
                  My Garage
                  Feedback
                  Instagram: Stone.Hopkins
                  • abit
                    • Jul 2011
                    • 423
                    #204
                    Sooo, what's new...actually nothing much :D
                    Car is running good and no big faults has been observed..
                    repaired bent exhaust...
                    then bought and installed fiberglass Is front lip..
                    also bought some yokohama slicks, so I don't turn my good front tires in trash on track, when we go drifting etc, so mounted slicks @ front and of course...testing :D
                    let's kill them all :devil: :D
                    chillin'
                    and then the biggie, decided that my zinno is not that shiny anymore how it was after repaint, so...lets polish that bitch up :D
                    first sanding with sandpapers.. matte :D
                    getting closer :devil:
                    meanwhile tuned up my second car, my musclecar
                    It took about 4 loooong evenings to make it done, dayumm, that was tough..
                    after some time, plastidip painted front wheels to see how they would look black, aaand trashed some more tires :D
                    and then made some fog in forest :D
                    but the biggie...
                    my 88' m20b30 HERE!
                    • abit
                      • Jul 2011
                      • 423
                      #205
                      some pics of autumn photoshoot
                      enjoy
                      ...of course some smokeeeey :D
                      yeah
                      my 88' m20b30 HERE!
                      • litu
                        • 848
                        #206
                        Awesome job that color save...Was you sand hole car and what paper you was using, like 1000, or 1200??
                        https://www.facebook.com/Cry_77_IX-110483784967661
                        https://www.instagram.com/cry_77_ix/
                        • abit
                          • Jul 2011
                          • 423
                          #207
                          yes, whole car was first wet sanded, as I remember we were using like 1200 and 2000 or so? and finish with soft foamy thing :D I don't know what grade it stands for but something about 3000/4000? and then done 3 step buffing with heavy, medium and soft polish compounds, and wax at the end.
                          my 88' m20b30 HERE!
                          • litu
                            • 848
                            #208
                            Ok, thanks for that info...I was test my e30 that heavy buff, then soft for polish, but it need in some areas that sand paper.
                            • abit
                              • Jul 2011
                              • 423
                              #209
                              aaha shhht, some one hand filming
                              getrag260 + 3,64 diff
                              my 88' m20b30 HERE!
                              • digger
                                • Nov 2005
                                • 6196
                                #210
                                i would get an adjustable cam gear and set it at 4degrees advanced if possible, it should make more torque below 3500rpm so its not "cammy" like catcams always seem to be
