Another 5.0 build: #projectmerica
  • IronFreak
    • Dec 2012
    • 3702
    #166
    It's kind of nice to set tools on when you're wrenchin. Maybe clean up the corner so it doesn't stick out so far.
    Instagram @rebellionforge
    • eurotrash
      • May 2007
      • 768
      #167
      Make sure your coils tucked away from the heat also. With the exhaust right there its easy to cook um on hot days when the ambient temps start rising.
      • ballski
        • Jun 2012
        • 345
        #168
        Time for some Everglass, then Rage xtreme
        Current Moneypits: e36 m3/4/5 Turbo Techno
        1961 Cadillac deVille bagged -
        IG @bryang513
        • ballski
          • Jun 2012
          • 345
          #169
          Did a bunch of Everglass last night after a few final welds.
          I also got my RX7 4-piston front calipers in the mail. Ordered them off ebay. I also ordered the mounting kit that guy sells. Hopefully this helps for a budget BBK.
          generic pic:
          IG @bryang513
          • tooslow
            • Sep 2012
            • 60
            #170
            Looking good! I am about to tackle smoothing the engine bay, stitch weldind and spraying the bay and interior in my 5.0 project. Lots of good info here!
            Who is the ebay seller for mounting kit for the calipers? I only need the bracket for the caliper then my brakes will be ready to mount after a caliper rebuild,
            Thanks!
            Sent from my DROID2 using Tapatalk 2
            • ballski
              • Jun 2012
              • 345
              #171
              I got mine from here, but there may be others: https://sites.google.com/site/e30bra...30_RX7_CORRADO
              IG @bryang513
              • tooslow
                • Sep 2012
                • 60
                #172
                Thanks! Made my life a little easier
                • ballski
                  • Jun 2012
                  • 345
                  #173
                  no prob^
                  Picked up some dope wheels last night
                  Fikse FM10s
                  IG @bryang513
                  • IronFreak
                    • Dec 2012
                    • 3702
                    #174
                    This are a little skinny for a 5.0 aren't they?.........;)
                    • ballski
                      • Jun 2012
                      • 345
                      #175
                      lol give me those flares you just bought please!
                      IG @bryang513
                      • IronFreak
                        • Dec 2012
                        • 3702
                        #176
                        hahaha, Kamotors has his on sale for $300
                        • ballski
                          • Jun 2012
                          • 345
                          #177
                          Pictures of the bay with some Everglass applied:
                          Media blasted one of the Fikse faces:
                          Took a wire wheel to the rx7 calipers, I'll be painting them aluminum most likely:
                          IG @bryang513
                          • shEck3lls0
                            • Jan 2011
                            • 1154
                            #178
                            I posted in Stuart's build thread about the u-joint to use for the DS. Check it out. Here are the 2 links for reference:
                            Why You Might Need One. When doing a V8 swap into a BMW, the BMW U-joint is non-serviceable and requires special machining to replace. Stealth Conversion’s heavy-duty BMW driveshaft conversion flange has the same bolt pattern and pilot dimensions as the stock BMW driveshaft flange, but it uses the road-tested Dana 1310
                            Spicer 2-2-1679, Our Price: $155.80, Normally drop ships the same, or next business day. Flange Yoke, 1310 series, 4xØ.406 Holes on 3.344BC, Ø1.812M pilot
                            1989 Alpine 325is 2dr m50 swapped
                            Build Thread:
                            Current ongoing build. Check it out!
                            1991 318is 4dr rallycross
                            Rallycross Build Thread.
                            1991 Alpine 318is coupe - sold
                            • ballski
                              • Jun 2012
                              • 345
                              #179
                              http://www.northerndrivetrain.com/pr...-2-2-1679.html
                              you're a boss! thanks.....so I need to order one of these flanges and a 1310 u-joint for the rear of the DS? And I'll prob get a 1330 for the front.
                              IG @bryang513
                              • FunfGan
                                • Jan 2011
                                • 4958
                                #180
                                I think I just need to sell my car, get another e30, find a swap nobody has ever done and just take my time. Everyone's coming out of nowhere with amazingly done 5.0L swaps :puppy:
                                Absolutely love it so far dude, can't wait to see it finished.
                                Go here be happy!
                                Ratchet Garage e30 V8 build.
