Mazter's '91 Alpine White 318is - I knew I'd be back!
  • MazterDizazter
    • 279
    Hey guys,
    After a 4 year hiatus from E30's, I found myself another one: a '91 318is in Alpine White II with tan interior. It's taken me a while to find a decent 318is and mine still isn't perfect, but it was fairly well-kept, considering it's age. This thread will chronicle the progress from when I bought it on November 1st and the day it drove home from the body shop on December 20th. I'll then update as I continue to restore the car.
    I found her up near Bangor, Maine. Apparently the car had spent it's whole life there, but miraculously wasn't a rot box like most 20+yr-old cars from New England are. At 193k miles, it's averaged just under 9k miles per year. After a long conversation with the current owner (who had only had it since July), I decided to forego the two questionable 318is's I saw in Connecticut and made the long trip up to Maine.
    The trip up to Maine took about six hours. I stopped north of Boston to pick up my friend Stefan who would ride up with me, then went straight up to Maine. Once we got up there, I gave it a good once-over to confirm that there were no major rust problems, took a quick spin around the block, handed the owner $2,000 cash, swapped his BBS wheels for some steelies and started the journey to Portsmouth, NH where I would go to BavAuto to get some parts.
    (Stefan demonstrating how gangsta we'd be if we lived in Iraq with these cars)
    Well, we didn't make it to BavAuto in time. Luckily, my best friend was working in Portsmouth for the day and I was able to call in the parts order and have him pick them up. Major props to both my best friend Andrew and for BavAuto for being so helpful! I picked up a Motorsport front spoiler and clips, new front and rear Roundels with grommets, taillight filler panel, fog light covers, and some goodies from UUC: stainless shift knob, shifter bushing, clutch arm bushing, and clutch pedal stopper
    Next it was over to Hooksett, NH where my friend Derek was waiting for the car to begin prepping it for paint. The original paint on the car was pretty tired and there were some dents on the body and some surface rust on the trunk from where the P.O. backed into something. Derek was going on his honeymoon for the next two weeks, but he would get straight to work on it upon his return. Since I was on a budget, I told him that, knowing you could only have something done two of three ways (good, fast, and cheap) I chose good and cheap. After dropping the car off, we made our way back to Mass. The whole trip took us about 12hrs and 635 miles.
    Fast forward two weeks later: Derek gets back from his honeymoon to find a pool of oil underneath the BMW where it sat. Fantastic! I guess I wasn't going to be able to drive it home until that was squared away.
    I took my next day off to head up there and determine what the issue was. Well, the culprit turned out to be a hairline crack in the oil pan, causing the oil to slowly seep out of the sump. While checking this I noticed a disgusting amount of sludge covering the front part of the engine, so I decided it was time to tear the front cover off and clean everything. In the upcoming weeks I ordered an upper/lower timing gasket set, front main seal, oil pan and seal, water pump, thermostat, and an electric fan and wiring harness to ditch the clutched mechanical fan. Derek was to prep the car for paint as I was taking care of the mechanical stuff. He would wait until that was complete before laying down the first coat of paint; wouldn't want to get dirt or oil in the paint!
    It took me two more days off worth of meticulously cleaning every part and replacing all the gaskets. I didn't have a manual to work off of, so it took me a bit of time to examine everything and make sure I was doing it right. I went through 3 cans of brake clean and a couple old toothbrushes to get the front of the motor clean.
    The timing chain tensioner was replaced in the past 5 years so I didn't see the need to touch anything there. The new water pump didn't quite fit at first (the back edge of the impeller housing was too thick) but a little sandpaper took just enough material off to get it to fit snugly and work properly.
    With the front cover back on and everything back together, I installed the electric fan, which was a piece of cake and freed up some space in the engine bay. Then it was a matter of getting the coolant in the car and bleeding the system of air.
    However before we ran the car again, Derek installed a cat-back exhaust on the car, because it didn't have anything after the cat. I bet you can imagine just how annoying of a ride it was from Maine to NH! I wasn't about to do that again, so I made sure the exhaust was done before leaving for home. I had ordered a Magnaflow Universal muffler and resonator in 2.5", and we ordered mandrel-bent piping but it didn't show up in time so we used crush bend piping temporarily. Well, it's really loud with that exhaust, so I'm going to try using smaller diameter pipe and a different resonator to see what happens.
    The paint was sprayed, the clear coat also. All that was left to do was the buffing and polishing, and then re-assembly. On my last day up there (yesterday, 12/20), Derek buffed and polished the paint, and I bled the cooling system, keeping far away from my shiny new fenders. With the car up to temp, the electric fan kicked on, confirming that my handywork was done right. Unfortunately I discovered a few more faults as I was working on the car: the steering rack, upper oil pan, and differential were all leaking, some quicker than others. Also, The Mess Under the Intake was likely causing some idle issues, as the car sounded like it had a lumpy cam in it. Those would have to be tackled at another time. We sprayed the black trim, headlight surrounds and grilles with trim black, as well as the lower rocker sections. Then the masking came off, the trim went back together, and, after a quick inspection, took the car out for a little test run!
    We confirmed the car ran right with the temp staying just above the halfway point, and the engine was holding an idle (just). So I thanked Derek for everything, packed all my tools up, and made the trek back home. All was not well as there were a lot of strange noises coming from all four corners of the car (I suspect brakes and/or wheel bearings) but the car tracked straight and there was no vibrations felt through the steering. I lost a brake cooling duct on the highway at one point (I must not have secured it properly), but otherwise, made it home in one piece!
    I'm very busy this weekend, what with the world ending and all, but I'll take some "finished" pictures after I give the car it's first hand wash and detail the interior. I hope you all enjoyed my little story, and you like what you see!
    Here's progress pictures of the painting:
    Stay tuned for completed pics!
    1987 Toyota MR2: 20v blacktop screamer
    2013 Subaru BRZ: the new hotness
    1991 318is Alpine White: sold
    1989 325i Alpine White: sold
  • camshaftgsxr
    • Aug 2011
    • 416
    sub'd
    BroWorks.com Bro is a lifestyle
    • DAN318IS
      • Nov 2012
      • 5
      hey youre care are nice man, i have one 318is but i have to do a lot of thing to look like yours
      • BROKINBIMMER
        • Nov 2012
        • 195
        Car looks good! But why not remove the mirrors, door locks, handles/quarter trim/bumpers and door moldings? Honestly takes maybe an hour to remove all those items and you would have ended up with a much better job. Car looks great regardless, I'm just a bit surprised to go thru all that work and skip a couple of simple steps...
        • rturbo 930
          • Dec 2005
          • 2621
          Damn dude, you didn't waste any time tearing into it! Looks great man.
          • 325ix
            • Aug 2009
            • 7783
            I was just going to say this. None of those things are that hard to remove.
            • MazterDizazter
              • 279
              Thanks, guys!
              Yeah, I felt similarly, but my body man felt otherwise. He was more afraid that he'd break the trim pieces or the retaining clips taking them off. I wish I had twice as much money and time to get it done the way I wanted it, but it came out pretty decent for what I paid. I wasn't going to throw more money into the paint job than I paid for the car or what it's even worth. The car is a 5-footer and will be a daily driver, so it is what it is.
              • JRYE30
                • Sep 2011
                • 465
                Looks great! As others said, ou dont waste time haha. I believe the previous owner was on this forum.
                How much did that respray cost you if you don't mind me asking?
                And how do you mount your badge back up? Mines off and I don't feel like buying a new one hah.
                1987 325 | @e30_hunter |
                • Slicktop_serg
                  • Nov 2011
                  • 198
                  Reminds me of my first e30 . good shit
                  91' Alpine II 318is Slick top - Totaled
                  89' Lachssilber 325is - :p
                  • sayed ali
                    • 762
                    Nice paint job :)
                    M20B28 Turbo
                    My Build Thread
                    http://www.r3vlimited.com/board/showthread.php?t=255839
                    • KrayJoeArmstrong
                      • Sep 2011
                      • 102
                      you don't wasting time. good job dude ! love it
                      • MazterDizazter
                        • 279
                        My friend owed me a favor so I got a special price on it. I reckon it would cost $2-2,500 normally. To re-mount the 318is badge, I just cleaned the old adhesive off the back and used 3M double sided tape, trimmed to fit. Just make sure not to take the red backing off until you're ready to mount it, otherwise the oils from your hands will reduce the effectiveness of the adhesive. For the roundels, just got new grommets and they popped right in.
                        So I've driven it a couple times since bringing it home, and I've determined that I need brakes all around, as well as wheel bearings (fuhhhhhk) and possibly rear axles. I'm also going to replace the steering rack and fix the upper oil pan leakage. Do I need to drop the subframe and/or un-bolt the transmission to get the upper pan off? I didn't get a good look at it.
                        • MazterDizazter
                          • 279
                          Quick snap I took when I got the car in the garage last night:
                          I'll likely be cleaning the car tomorrow as X-mas is the only time I have to get it done, go figure.
                          I'll post interior pics up shortly; right now I've got everything but the dash, rear seat and carpet out and will be removing the carpet to take to work for steam cleaning. I found a nice dead mouse chillin' behind the center console. Sweet.
                          • MazterDizazter
                            • 279
                            Updates! 1/13/13: Baby's first bath (and clay bar, and polish, and wax)
                            Plasti-dipping the wheels because the clear coat is almost gone:
                            Interior mostly out, hoping a good steam clean will get these stains out
                            Trim discoloration; think I'm going to paint the door handles and map pockets black:
                            Cleaned up the dash, still have to address the cracks but it's all clean now - lots of q-tips needed to get those heater vents clean!
                            Pics in the garage after clay/polish/wax and cleaned windows inside and out:
                            Right now I'm painting the inner wheelwells black to cover up the overspray and will be undercoating the car shortly. Then more mechanical work - steering rack, gearbox and diff. fluid change, brakes, etc.
                            • tak7
                              • 856
                              Nice car, coming together quickly and nicely!
