In need of some assistance (r3ved content)
  • lonestar22
    • Aug 2005
    • 417
    So it snowed over night last night. My car was in the garage so i wouldnt have to deal with getting snow off of it in the morning. My car is pretty low, but i did not expect what happened next to happen, i made it about 8 miles before the car shut down, i opened the hood and saw this...
    my car was driving over snow in the center of the lane but i had no idea it was packing it all in the engine bay. car is not getting spark, even after removing all the snow. is it safe to say the CPS is shot?
    here is the car
    Originally posted by Lof8
    Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.
  • ak-
    • 12422
    Because this is the Member's ride section, I can't do anything but look at your car and compliment how much I like the spark plug wire holder since I seem cracked very often.
    1991 325iS turbo
    • noE30
      • Jun 2008
      • 2260
      I've almost had that happen myself! Car still ran but everything from the motor mounts down was covered in snow/ice. Try to clean as much out of there as you can, if it freezes you'll have a huge mess.
      Good luck with the engine.
      Flickr
      @michael.colby on Instagram
      "All he needed was a wheel in his hand and four on the road"
      • dannyyisntt
        • 3141
        Lol I've done that before with my ix
        • Cronopoulos
          • Jul 2011
          • 2187
          Check under your dizzy cap.
          Project log -- DIRTY 30
          2.7i * Megasquirt tuned * E85 powered
          • Bimmerista
            • Nov 2005
            • 5425
            Where were you driving?
            • gte175x
              • 150
              yes - and check to see that you didn't knock the coil wire out of the cap when you knocked out all that snow and ice. if you're not getting spark.
              • lonestar22
                • Aug 2005
                • 417
                checked the wires on the distributor. all of that is good. what is the likelyhood of the crank sensor giving out due to water? it was completely submerged. thats my best guess as of right now, especially since it doesnt have spark.
                • Cronopoulos
                  • Jul 2011
                  • 2187
                  Where and how are you testing for spark? Take the cap off and inspect the rotor and it's friction points.
                  • MoreMayhem
                    • Feb 2012
                    • 650
                    If the CPS is intact, no broken/exposed wires, it's probably fine. If in doubt, it is very easy to test with a DMM.
                    • lonestar22
                      • Aug 2005
                      • 417
                      the cap and rotor look fine. i checked for spark just by trying to get one of the plug wires to arc on something.
                      i also hooked up a digital multimeter and only got 43ohms reading across the connector. from what ive been reading i should get somewhere around 540ohms.
                      • glucklich21
                        • 1912
                        By the looks of your engine bay I'm never moving farther north of Austin. Also did you still have the splash shield installed underneath?
                        • lonestar22
                          • Aug 2005
                          • 417
                          no, splash shield was not installed. this wouldnt have happened if the car wasnt so low
                          btw i found the problem. timing belt snapped. broke two rockers. id hope that if the rockers broke then the valves are okay. but i doubt that.
                          • Todd Black 88
                            • Oct 2007
                            • 3449
                            Um....the rockers broke because the pistons smoked the valve and drove it into the rocker.
                            Originally posted by codyep3
                            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                            2001 silver/Blk 325 cabby. SOLD
                            2002 325xit Sil/blk. SOLD
                            2010 F650gs twin
                            • Northern
                              I like cupcakes & sh!tboxes
                              • 5283
                              pretty sure he knows that, but he's hoping the rockers were weak enough to snap before the valves bent. Seriously wishful thinking.
                              Originally posted by priapism
                              Originally posted by shameson
