A guy on myE28 forum said he used an aluminum angle and an E36 trans mount.....
New guy
A guy on myE28 forum said he used an aluminum angle and an E36 trans mount....'86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
Albie325 Build Thread | Albie325 COTM Jan 2021
While it's possible to find a shop that can and will change the u joints AND balance it as a unit, most people seem to get a replacement rebuild. Go to place to check would be driveline services in Portland, OR. I believe you just return your old shaft in their box and bobs your uncle.Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
I started working on the crank position sensors, which were stuck in the bores because the plastic started to melt. Slow and careful, tap away with a punch, a big punch, and a tiny screwdriver, trying not to gall the aluminum. Then I used a fine rat-tail file and just pushed once against the black plastic bumps. I believe there's a small ledge inside the bore, where the upper plastic part of the sensor bottoms. I'm trying to get that bit of plastic out of there without ruining the step. Tiny taps.
Is there an o-ring in the bore on the CPS? Interesting that it mostly made it.
Albie has me reading up on driveshafts:
BMW (including E30's) and some Mercedes drive-shafts particularly of the 80's-90's vintage have what are called non-serviceable staked in u-joints. Over-time the grease inside the u-joints drys out, get pasty or otherwise stops performing its job; this causes the u-joint needle bearings to bind. Binding u-joints will cause vibrations to be felt at a specific
Anyone heard of Driveshaft Specialist of TX?
http://driveshaftspecialist.com/Impo...gIVLh6tBh2ekQz 7EAAYASAAEgIX3_D_BwE
Originally posted by Vincenze View PostSeat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
- Likes 1
Driveshaft Specialist of TX seems like a possibility. They suggested a new DS for $545 - "a small series Ford Ranger type with replaceable u-joints and a center section that bolts together," but I'd like to keep it all original. It lasted 160,000 miles the first time.
EDIT - Driveline Service of Portland offers a remanufactured unit for $485 plus $100 core deposit and UPS Ground included.Last edited by LateFan; 07-07-2020, 09:48 AM.
Wholesale Import Parts
Remanfactured and balanced early E30 $393
https://www.wholesaleimportparts.com...shaft_1986.phpLast edited by LateFan; 07-07-2020, 11:53 AM.
Originally posted by jeffnhiscars View Post
Being "100% new" it's hard to imagine it's anywhere near the quality of an OE reman from a specialty shop for the same money. I mean...autozone 🙄
So, a remanufacturer will cut out the pipes from a drive shaft and weld new u-joints to them from another car (Nissan?).
Does it provide better quality than welding new u-joints to new pipes?
We ordered a scary shitload of swap parts last night. Added a starter in - this has to be original. Also timing belt and tensioner with camshaft seals. Gawd it adds up! Talking to three driveshaft shops to remanufacture.
Took a look underneath to check out clearances and mounts and hardware and CPS's etc. He needs a wash.
This passenger floor leak is frustrating. We've pulled the carpet up, dried everything. Floors look great BTW. We're looking at the firewall grommets, the A/C grommet, the elephant trunk drain, the windshield gasket, the sunroof drains... The water dribbles out the bottom of the sills the way it's supposed to. Spraying a hose on the A/C grommet next to the passenger fender makes it leak, but how does any water get inside the hood gasket and above the battery try to spray on there? Doesn't make sense. The electrical wire boot to the door doesn't fit all that tight, but it would have to run down into the passenger speaker well and pond up in there before pouring onto the floor. The floor plug on the slope above your feet drips a couple of drips - we can reseal that with some silicone. One place that really confuses me is the well where the heater blower sits. Water from the cowling vents runs across that areas to the elephant trunk drain on the passenger side - does it run right across the gasket for the blower? Or is there a gutter or trough through there?
