My 333i turbo
  • e30m3s54turbo
    • Jun 2010
    • 3210
    #136
    Originally posted by scoobydo
    Updates took a long time coming but weather is warmer so motivation is up. Hopefully didnt have to wait too long for the cable and hopefully they did charge you too much $$$$.
    I think it cost me $64.00 bucks. You can see it on my Alpina B6 3.5 tribute build.
    • scoobydo
      • Sep 2013
      • 137
      #137
      Bit more done. The 333i comes with a b32 engine as such has the coolant pipe on the back of the head. Not enough room in position 3 to get the hose on so had to modify the pipe. This involved cutting the coolant gooseneck down and inserting a 5/8 copper pipe and brazing this in place. Next up was the heater pipes, the bottom one needed a right angle pipe close to the bulk head to allow it to route towards the modified gooseneck. This was achieved by cutting the ally pipe down where it comes through the bulkhead, swage this pipe out to accept a 15mm copper elbow to be brazed on the inside of this pipe.
      Every made up pipe I stripped a bit of copper from a cable and made a retaining ring that I soldered in place to make sure the hose stays secure.
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        #138
        Very nice, looks like you've managed to gain quite a bit of clearance.
        • scoobydo
          • Sep 2013
          • 137
          #139
          Anyone got any ideas what this fixing is. This is on my custom exhaust manifold. All other nuts on the studs are easy to get to and are standard this one cannot get anything on it. Anyone got any ideas dont think it is a normal nut like the others but have very limited access. Note there is a flange above this in the second picture showing the limited access.
          i
          • kronus
            • Apr 2008
            • 13017
            #140
            it looks like it used to be a regular hex nut..
            cars beep boop
            • CorvallisBMW
              • 13039
              #141
              My 333i turbo
              used to be...
              Can you get a box-end wrench in there? Maybe grind down on the OD of the wrench to help it fit in the tight space? I've had to do that before:
              • Max399
                • Feb 2013
                • 991
                #142
                On this picture it looks like you have a crack around the mounting hole, hope its just dirt :)
                5-lug Kit | E36 & E46 Hub & Brake Adaptor for E30!
                Leave feedback about my transactions!
                • scoobydo
                  • Sep 2013
                  • 137
                  #143
                  Ok will get another look at it. It is a bit of a mix and match, one nut on the manifold is an m10 thread which is normally a 17mm AF spanner but it has a 13mm AF nut rethreaded to m10 1.5 pitch nut. This stripped but have found 12mm af nuts for exhaust with an m10 thread fits on easy.
                  http://www.demon-tweeks.co.uk/kartin...-locknut-k-nut
                  @max399 where do you think this crack is do you mean on the oil pressure outlet? Will go and check it out but didnt have any probs before the radiator sprung a small leak
                  • Max399
                    • Feb 2013
                    • 991
                    #144
                    • scoobydo
                      • Sep 2013
                      • 137
                      #145
                      Yes sure this is just a bit of crap but will check
                      • scoobydo
                        • Sep 2013
                        • 137
                        #146
                        For the time being I am going to stick with what I have but look what just turned up. Wonder how much this will affect spool from a semi log style manifold to
                        • e30m3s54turbo
                          • Jun 2010
                          • 3210
                          #147
                          Nice looking turbo manifold!:up:
                          • CorvallisBMW
                            • 13039
                            #148
                            Ooooh shiny :)
                            • scoobydo
                              • Sep 2013
                              • 137
                              #149
                              looks very much like a G&T manifold with a t3-t4 flange. Anyone know the runner size if one of G&T's? Workmanship looks good on this and price was good:)
                              • Alpina
                                • Oct 2004
                                • 838
                                #150
                                That exhaust manifold,,,,,,,,,,,,,,,,,, wow
                                Sveinbjörn Hrafnsson
                                E30 CABRIO V12 M70B50 ///
                                ALPINA B10 BITURBO 346 @ 507
                                E34 550 V12 JML
                                Finnish wisdom : If you want to Win,, hire a Finn
                                http://alpina.123.is/pictures/
