My 333i turbo
  • scoobydo
    • Sep 2013
    • 137
    #121
    not sure it is an Alpina manifold unless you have details confirming? Think it is more a homebrew of parts that have been flipped and a turbo flange welded on. Wasnt a tight fit with the Alpina mounts everything had plenty of clearance but the shift back 30mm had hurt the clearance. Would love a G&T manifold but would need t3 flange and without the external wastegate provision as mine is internal.
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      #122
      I just figured it was since its a alpine car. But that still a cool home brew manifold
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • scoobydo
        • Sep 2013
        • 137
        #123
        For those lucky enough to have an Alpina gearbox crossmember dont make the mistake I did, it is actually handed this is why I was having problems getting the gearbox to sit on the mounts.
        • e30m3s54turbo
          • Jun 2010
          • 3210
          #124
          I hope you solved you problem.
          How is the rest of the project coming out?
          • scoobydo
            • Sep 2013
            • 137
            #125
            slow progress, but now I have dejunked the garage at least I can work on it out there. Need to order boost pipe, new IC is only 2.5inch old was 3inch so going to go 2.5 out turbo into IC then might increase to 3 out of IC. Hopefully finalise engine position now I have realised the error in my ways:D
            • e30m3s54turbo
              • Jun 2010
              • 3210
              #126
              On your throttle cable. Is it from Alpina or is from a right hand car like a e28 535i? I have a Alpina B6 intake. I just need the cable.
              • scoobydo
                • Sep 2013
                • 137
                #127
                Here are some pics I have of that area
                • e30m3s54turbo
                  • Jun 2010
                  • 3210
                  #128
                  Thanks for the pics!!!
                  I was hoping it would have original cable it came with. I can't remember what my old 1984 Alpina B6 2.8 was using. I really don't want to modify a bicycle cable. I will check with KSK or with Mel
                  • scoobydo
                    • Sep 2013
                    • 137
                    #129
                    Think it may have all been changed out when the ECU was changed to Zytek. You could try the BMW SA E30 forum maybe they have stock. Doesnt look OEM
                    • scoobydo
                      • Sep 2013
                      • 137
                      #130
                      Long overdue update.
                      Finally got some time on my hands. Have mounted the intercooler, used a inch x half inch ally c section, and M10 studs. Have trimmed the front valance down to allow the intercooler to sit as far forward as possible. This now allows a SPAL pusher to go in easy between the IC and e28 radiator. Progress at last.
                      Waiting for some pipes to come so I can sort the plumbing out from the back of the head to the heater matrix. I need to braze a 5/8 copper pipe into the cut down gooseneck and then route to the heater matrix.
                      • Alpina
                        • Oct 2004
                        • 838
                        #131
                        More pictures,, (please)
                        Sveinbjörn Hrafnsson
                        E30 CABRIO V12 M70B50 ///
                        ALPINA B10 BITURBO 346 @ 507
                        E34 550 V12 JML
                        Finnish wisdom : If you want to Win,, hire a Finn
                        http://alpina.123.is/pictures/
                        • scoobydo
                          • Sep 2013
                          • 137
                          #132
                          Not got much more to show yet. Have wrapped downpipe and pipe linking rear cylinders to front. Got a question regarding the bottom mount for the e28 radiator. My shell I think may be different as it came with the alpina rad. What are the arrangments normally for mounting the bottom of the rad? My original rad was mounted from the front on tabs and cups that forward of the mask that my IC is now mounted via the m10 studs
                          • scoobydo
                            • Sep 2013
                            • 137
                            #133
                            Here are a few more pictures
                            Wrapped downpipe
                            Partially wrapped manifold
                            Cut valance didnt have to do too much also removed some of the Headlamp support as I am running 3 inch outlet from IC.
                            Clearance of fan to IC got about 6mm clearance so plenty
                            Clearance fan to radiator
                            Crankshaft pulley clearance in position 3 enough room to keep my aircon
                            3inch cold side from IC
                            Here is what used to be the air feed to the side mount IC just a few 10mm holes drilled in the headlamp support. It was a doble thickness wedge shape IC from RS500 folded in half you can see why I wanted to change it
                            Bit more IC in the frontal area
                            • e30m3s54turbo
                              • Jun 2010
                              • 3210
                              #134
                              Coming along nicely!!! Keep the pics coming!!!
                              I bought a Alpina throttle cable from Alpina.
                              • scoobydo
                                • Sep 2013
                                • 137
                                #135
                                Updates took a long time coming but weather is warmer so motivation is up. Hopefully didnt have to wait too long for the cable and hopefully they did charge you too much $$$$.
