My 333i turbo
  • scoobydo
    • Sep 2013
    • 137
    #91
    Here is a picture of the manifold that I am currently using.
    • e30m3s54turbo
      • Jun 2010
      • 3210
      #92
      The radiator looks good for fitment.
      On my m30 swap looks the same as yours.
      • abit
        • Jul 2011
        • 416
        #93
        333 turbo...niiice great car ;D
        http://instagram.com/mundieriss
        my 88' m20b30 HERE!
        • scoobydo
          • Sep 2013
          • 137
          #94
          Done a little bit more, didnt have much time this weekend as other commitments.
          Engine bay cleaned up a bit
          Firewall soundproofing removed, need to be careful here I think as need to make room for the coolant pipe on the back of the head but as I am right hand drive the brake bar runs behind here I believe. Could anyone advise on this area please.
          • scoobydo
            • Sep 2013
            • 137
            #95
            Not sure for you guys how rare this next item is?
            Alpina crossmember for the gearbox
            • e30m3s54turbo
              • Jun 2010
              • 3210
              #96
              Nice! Vary rare to find. I have the same one like yours. Yours is 1984 cross member. Mine is a 1986.
              • scoobydo
                • Sep 2013
                • 137
                #97
                Was hoping you would drop by the thread:) Your B35 T tribute, what intercooler did you get or was it custom built? Looking for ideas around this.
                Thanks
                • e30m3s54turbo
                  • Jun 2010
                  • 3210
                  #98
                  Thanks
                  No it is not custom. If you still plan to run your AC. I would run the intercooler that sits be hind the kidney grill.
                  • bulldog30
                    • Sep 2014
                    • 13
                    #99
                    updates???
                    • scoobydo
                      • Sep 2013
                      • 137
                      #100
                      Well got it back in. Wasnt too bad getting it back in after I got rid of the balance bar and subsituted the front connecton with a block and tackle. The Balance bar I was usng was too short to get enough tilt on it. I was biased to the rear of the car to get the angle but then it wouldnt level up to get on the mounts. Got it into the rear most holes on the e30.de brackets without any bulkhead bashing. Just needed a very minor tweak (just for piece of mind)with a bar around where the water pipe is on the back of the head. However I do have a question about the wings on the back of the block, this is now fouling on the bellhousing. My drivers side (righ hand drive) had already it grounded off, but the passenger side is fouling on the bell housing. Also my gearbox is being a bit of a pain as it is seems to be slightly rotated so when putting the mounts on it is under a lot of pressure, so much so one mount has decided to delaminate.
                      Will get some pictures up of the front end clearance that I took before I realised I had a problem at the rear end. Post these up later today.
                      Going back in
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        #101
                        What manifold is that? e23 745i?
                        • scoobydo
                          • Sep 2013
                          • 137
                          #102
                          Manifold is combination of two parts that have been flipped and a turbo flange added.
                          Parts numbers are 1788712 back cylinders 1788715 front cylinders
                          Here are a couple of the front in its resting position albeit with the lug rubbing on the front of the tunnel.
                          • Stanley Rockafella
                            • Aug 2011
                            • 4056
                            #103
                            as awesome as this car is, I'd hate to have one. Sure it's uber rare etc, but I'd lose so much sleep at night worrying about it
                            • Ray Smoodiver
                              • Jun 2004
                              • 8809
                              #104
                              Did you go with Otis' manifold? Will be interesting to see if it fits RHD cars.
                              • scoobydo
                                • Sep 2013
                                • 137
                                #105
                                havent got the otis manifold asmy turbo is a T3 flange. Got a bar and palte intercooler for behiind the kidneys to replace the stupid toaster that sat behind the headlights. Need to modify the suspension turret so my downpipe will fit as there isnt quite enough clearance now the engine is sitting back from position 1 standard 333i.
