The DS bolts at the diff I used my ratcheting box wrench and my foot to break them.
My long finished e30 project
Originally posted by TimeMachinE30 View PostThe DS bolts at the diff I used my ratcheting box wrench and my foot to break them.
1992 e34 Touring- S50 Swap
1992 325i-S50 Swap (SOLD)
1991 Brilliantrot Convertible 80k Miles (SOLD)
I got some Brand New Red Spark Plug wires the other day online during a sale. It's funny, when I owned my Mtech the car came with red spark plug wires installed and I always hated it. Somehow that hate turned into me wanting a set for my coupe and because of the sale I couldn't pass them up. To my surprise there made in Canada. Only two complaints, first was the wires weren't labeled by number so I had to do a continuity test with a Multi Meter to figure out which wire was for which cylinder. Secondly the coil wire was coming out of the wrong spot so I had to take the spark plug wire set apart and make the wire come out of the correct hole as pictured bellow, it was to short otherwise to reach the coil. Both not really big deals.
Well today I rebuilt the whole front end. Brand new Lemforder control arms, bushings, inner and outer tie rods, and sway bar mounts. All it needs now is an alignment and it should be good to go! I also installed a Mtech cloth shift boot/ eBrake handle but no pics.
EDIT: Note to self, installed at 121,383
new suspension parts are always a treat! enjoyI BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
I've barely driven the car since rebuilding the front end, sadly my rear wheel bearing failed so the car was just sitting around until I had time to fix it.. Which was today! Man this was a shit job to say the least, it was going so smoothly until it was time to punch out the hub. THANKFULLY Kronus gave me two extras, I had to literally cut mine out. I kept hitting it with a mallet for at least an hour, tried using a puller, absolutely nothing worked. Not to mention the inner race suck to the hub, It made it that much better I had a extra.
As for pulling the bearing, I bought a eBay bearing puller kit for $63.45 shipped to my door. Lot's of people recommended buying a Harbor Freight kit, but they raised there prices to nearly $120.. Plus there would be tax, and in my case, $5 bridge toll to get to there closest location. Honestly, I think it's the same kit they sell in stores it looks identical.
Onto the pics;
Half of the old bearing still stuck inside,
Should have done the sway bar bushings while you were taking apart the front!
Looks like the same kit sold at nearly all the stores.. many of the master tool kits like you purchased I have found (brake caliper tools, thread restore kits, etc) to be the same provider with dozens of companies simply rebranding them.
Originally posted by TimeMachinE30 View PostShould have done the sway bar bushings while you were taking apart the front!
Totally agree with the rebranding part, I'm sure that's what Harbor Freight and other company's are doing with some of there items. I haven't bought a cheap tool in the past 3 years (I've been slowly buying a few Snap On ratchets and sockets lately) but I have to say for what I payed it was definitely a good tool for the job, I don't think I could have changed the bearing with out it. If anyone out there reads this and needs to do wheel bearings on there car without paying a shop/ don't have a bearing puller, I recommend the kit.
Well today I decided to do another transmission fluid change. I say another because the last one I did was about 30k miles ago. This time I spent a little extra and bought Redline fluid. Lucky for me though, Napa Auto Parts gave me a slight discount because of my work. Ended up being $33.11 for two quarts which wasn't that bad I guess.
