Larry's 89 Zinno E30 M3 build
  • Dj Buttchug
    • Jun 2010
    • 7672
    #46
    those turbofans are amazing. great work
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • SteadyAim.
      • Jan 2013
      • 249
      #47
      Looks great Larry! EVO III under trays are pretty hard to find. Glad you managed to find one.
      And about that front bumper gap.. Mine has it as well on the driver's side. It's such an eyesore :down:
      '90 Alpine White M3
      OEM Hella Smoked Euro Smileys | OEM Headlamp Washers | Startec Tail Lights |
      EVO III Undertray | EVO III Front Lip | '92 DTM CF Gurney Flap | Recaro N'Joys |
      Ground Control Coilovers | OZ Futuras
      DD: '97 Alpine White M3/4/5
      • f50nut
        • Aug 2012
        • 130
        #48
        Thanks :D
        Thanks, I'm glad I found one too. Was worried after the EVO II spoiler didn't ship out...always preferred this one anyway.
        The bumper gap is super annoying. I might try to modify the mounts to pull the bumper in a bit. Levent says it may be due to the car having been towed from the factory hooks at some point, extending the bumper shocks a few mm.
        Livery Wheel | Facebook | Instagram
        • CorvallisBMW
          Long Schlong Longhammer
          • 13039
          #49
          Wow, fantastic work & attention to detail. Keep it up!
          • f50nut
            • Aug 2012
            • 130
            #50
            New undamaged Evo 3 spoiler arrived
            So it's off for paint along with some Evo brake ducts I found (not pictured)
            Loaded up and ready to go. That's my GF's GTI.
            And these finally arrived :devillook
            • f50nut
              • Aug 2012
              • 130
              #51
              Thank you :up:
              • jhaurimn
                • Nov 2012
                • 2224
                #52
                Im looking to purchase an e30 m3 soon. I am worried I wont be able to find an evo 3 spoiler when I get it. Hopefully I have your luck!
                Current:
                1989 325i
                1988 M3
                1987 325ic
                Past:
                2001 330ci
                2001 M3
                • *freshm3
                  • 174
                  #53
                  Great build so far. I'm working on the getting my s54 swapped e30 M3 perfect at the moment. Finned diff cover, VAC's BBK etc.
                  The little things certainly add up but it's fun!
                  Glad you already know about Guten (great bunch of people)
                  Where in NY are you located? I'd love to check out the car if you're ever near the south shore of L.I. Good luck on the build over the winter....
                  If looks could kill:::
                  • f50nut
                    • Aug 2012
                    • 130
                    #54
                    There are some good carbon fiber replicas out there. Not ideal, but better than nothing.
                    Sounds awesome. S54 e30 M3 is a dream car for sure. I'm out in L.I. all the time, my family is out there. Would be great to catch up. PM me.
                    • f50nut
                      • Aug 2012
                      • 130
                      #55
                      Suspension arrived from Vorshlag. They are an official dealer of AST and I had the spare strut mounts shortened and built into AST 4100 coilovers. Overall the fit and finish is great, and Vorshlag did a nice job powdercoating the old housings.
                      Here's everything. Added brand new brake dust shields. You can also see the e28 bearings. Not pictured are the new abs rings pressed onto the back side of the bearing.
                      Swift springs and Vorshlag plates.
                      Big fan of these adjusters. So much nicer than dual locking aluminum adjusters.
                      Rear springs
                      Old vs new
                      Rear adjusters
                      Well this sucks, the allen bolt that holds the rotor on is too soft. I stripped both sides and had to make new allen keys to get these out. Will need to replace these with new, but for now, they're all I have.
                      Yes I put a jack stand under there ;)
                      It was 100 degrees that day.
                      Sorry no pics of the actual installation. Was under a time crunch to get this done. But here's the final result:
                      Drives beautifully.
                      Only complaint is that I couldn't adjust the fronts any higher without spinning the threaded tube on the front housing. Called Vorshlag and they blamed this on me, that I must have loosened the gland nut that holds the tube on. That's absurd. I had to go out and buy a gland nut wrench to finish the assembly job for them, since they didn't apply enough torque to the assembly. Another thing, I will have to shorten the front bump stops because there isn't enough travel when I match the fronts and rears. Pretty disappointed in their response after spending so much money on having these built.
                      That said, I like their plates and this is a great overall setup.
                      • jhaurimn
                        • Nov 2012
                        • 2224
                        #56
                        God, I love your car.
                        I will be watching/stalking this progress thread. Your car is absolutely stunning. The red paint looks so nice. :D Customer service you got from vorshlag definitely doesnt sound pleasant though.
                        Current:
                        1989 325i
                        1988 M3
                        1987 325ic
                        Past:
                        2001 330ci
                        2001 M3
                        • randomtask37
                          • 3154
                          #57
                          Looks nice man. I recently dealt with stripping out a rotor set screw. Frustrating
                          98 M3/4/5
                          • eshtog
                            • Oct 2013
                            • 36
                            #58
                            Originally posted by f50nut
                            Missing this plastic nut for the tool tray cover.
                            Off topic, but I am also missing this on my 89 Zinnoberrot M3 I recently bought. Except mine has the Natur interior :). Where did you source this and do you have a part # by chance? Looked at all the parts diagrams on realoem.com and could not find it anywhere.
                            Your car looks great!
                            • MJCRO
                              • Apr 2012
                              • 597
                              #59
                              Great to see this beauty make it's way to NY. Hope to see it at GutenFest next year!
                              • litu
                                • 836
                                #60
                                Again that color.......Cool project :)
                                https://www.facebook.com/Cry_77_IX-110483784967661
                                https://www.instagram.com/cry_77_ix/
