2nd e30, 87 Lachssilber Revival
  • Reichart12
    • Aug 2012
    • 2158
    #301
    Originally posted by digger
    The mechanical part of the ITB install is actually fairly straight forward. The instructions are fairly comprehensive from what i recall.
    When you bolt the manifold to the head use a straight edge to align the the bores and keep the face planar as there is some wiggle room on the bolts, then again with the throttle bodies themselves this way the axis of each 3 shafts is as coaxial as possible in both axis
    Totally get what you're saying about using a straight edge. This is some minor wiggle room when attaching.
    Well, I have the throttle bodies on and visually adjust. Car doesn't run yet. But I'm definitely confused about the coolant lines. There were two that attach into the side of the stock throttle body. I think that's basically a loop so I should be able to connect these two lines together but still have some searching around to really be sure.
    Instagram: Reichart12
    • digger
      • Nov 2005
      • 6096
      #302
      Loop the TB cooler lines or block off at T-Star housing and back of block
      • ForcedFirebird
        • Feb 2007
        • 8300
        #303
        Originally posted by moatilliatta
        Noice! A goal of 10 Motorsports events this year sounds fun. Any of them stand out or more excited about than the other?
        "Fun" is relative. At the peak of my driving career, it was 25-35 events annually. Most of the time, it was volunteering to clubs for free track/test time. I'm getting old and just pay for the track/dyno time when needed anymore. I spent more time volunteering than working on my own junk.......
        john@m20guru.com
        Links:
        • Reichart12
          • Aug 2012
          • 2158
          #304
          I can't wait to get to a track day. Don't really trust my brakes all that much but hopefully soon I can refresh all of that. I've just been going to autocross but have already missed three events so far. Oops!
          • Reichart12
            • Aug 2012
            • 2158
            #305
            So I think my mechanic-skills have been struggling trying to connect everything back together with these ITBs. Wish the instructions just had a bit more info on what to do. Figured enough people have installed them but not really finding the details. Here are the four hoses I have leftover.
            The valve cover hose, no idea where the other ends go.
            Brake booster hose, I think I just need to reuse the elbow and get a new hose that connects to the T supplied by RHD. Other ends of the T go to one runner and the distribution block.
            The ICV needs different hoses I think and one end goes to distribution block and the other end to a plug fitting that needs to be install into the plenum or backing plate.
            Other item that is from the charcoal cannister needs to reconnect to canister and go to the distribution block.
            Mainly just need to find a couple fittings and hoses to connect everything. Feels off since the instructions originally said only needed to provide some 8mm hoses but now I'm searching for all of this.
            Here's my distribution block set up. Just going to be chilling in there, no clue how to mount it to anything. Also notice the wiring circle thing and two plugs that normally attach into a bracket. They will also just be hanging out until I can find a solution for mounting. Also need to get a real connection for the coolant hoses. All I had sitting around was this T haha. At least I know the size now.
            Hopefully the last thing to tackle will be rearranging all these cables. Somehow I think the engine harness should have been run behind the throttle body, like next to the runner but there is not a lot of room to orient these things in a cleaner fashion. They do not want to bend into the places I want them in.
            • digger
              • Nov 2005
              • 6096
              #306
              I didnt get any hoses, fitting etc with the kit way back when i did it so have no idea how you are supposed to fit with supplied parts but i just got hoses from autoparts store and routed and connect everything and did not get too focused on neat any tidy initially.
              VC i vented to catch can and then atmosphere, i am working on routing back to airbox in a neat way.
              When i had that style of distribution block i had it sitting around not mounted in a bundle of hoses, i ended up tidying it up making a rail type distribution like the s54 but i suggest you decide on mounting and orienting it appropriately if you want something tidy for it as it will dictate the hoses and routings for the other stuff.
              ICV is just a hose attached to a fitting on the airbox to the ICV then to distribution block. I would mount ICV close to the block as its a vacuum line so prone to collapse.
              • Reichart12
                • Aug 2012
                • 2158
                #307
                Thanks Digger that helps. Will be a few days until I have the time to get working on this again but should be further along getting some hoses to start connecting everything. I don't have a catch can set up but maybe I can make a little makeshift at home version.
                • Reichart12
                  • Aug 2012
                  • 2158
                  #308
                  Woah almost two month update... oops! So much for a week long swap.
                  Anyways, added a catch can. Moved some wires around. Things look mildly cleaner. Added the vacuum hoses to each throttle to the distributor block.
                  Did get a first start but you'll have to wait to hear that.
                  Still need to connect the brake booster and ICV and then finish the runners and trumpets.
                  • Reichart12
                    • Aug 2012
                    • 2158
                    #309
                    Haven't posted much lately but still working on the ITBs. They should be finished soon. The car starts with throttle input and will idle. Slight vacuum leak due to a slightly too big hose being used from the charcoal canister without a hose clamp. Need to sync the throttle next and finish bleeding the coolant and that's mainly it before some basic tuning/driving. Planning to go to the Pro3 20th anniversary race this weekend to spectate and take photos. Here's a photoshoot I did of the car before the ITB work started, surprised I never posted them. Videos coming soon, breaking the install into a few parts.
                    • roguetoaster
                      Biggus Tippus
                      • 7830
                      #310
                      Every time I see those wheels on a small screen I momentarily think they are those Ronal teddybear wheels.
                      • Reichart12
                        • Aug 2012
                        • 2158
                        #311
                        Find me a set for under 600 and I'll do it
                        • roguetoaster
                          Biggus Tippus
                          • 7830
                          #312
                          Ha! Next time I see a set...
                          • Reichart12
                            • Aug 2012
                            • 2158
                            #313
                            New Youtube video posted:
                            This is the actual install of the runners and throttle bodies that I did several months ago now. WOW I'm lazy. Breaking it up to 2-3 parts but I have all the footage to the first start so these videos should slowly release as I trim them up. And maybe this weekend I will get in the garage to sync the throttles. For the YT side of things, I'm trying to have a light music track playing underneath everything. Just sounds empty right now with all the pauses I take while talking. If anyone here has been watching the video, there was a truck video and the catch can video where I recorded on my Nikon camera and not the Go Pro, that takes a lot more work to set up but I think I will continue doing that. Should show how long ago these ITB videos were as it was before I thought about making the switch to using the Nikon haha.
                            And because I couldn't leave a post without a photo, this is from last weekends Pro3 event where they had a 50+ car grid. I'll get to the other 400 photos I took someday...
                            • Reichart12
                              • Aug 2012
                              • 2158
                              #314
                              https://youtu.be/RrHSRT1oL3o
                              Finished the base layer ITB install. Started the car and began troubleshooting whatever is left.
                              Next videos will have going into MegaSquirt where I had two of the three location set for wideband. Changing that to be three for three helped the car start right away. Idle set too high right now so hopefully there is enough room in the set screws to lower this back down. The throttle cable doesn't sit nice and flat so I zip tied the knob to the arm. Oops! Desparately wanting to get the ITBs and wideband to act correctly to be able to drive the car this coming weekend. Was getting cobwebs on it from sitting so long I had to take it out of the garage for a wash!
                              • roguetoaster
                                Biggus Tippus
                                • 7830
                                #315
                                Looking shiny inside and out.
                                Do those ITBs need to be balanced/adjusted at all?
