My dads and my E30 M3
  • rzerob
    • Jun 2013
    • 2315
    #76
    This is a beautiful example of an E30M3. But I am confused on the "My dads and my E30 M3".
    Did you split the cost and have 50% ownership? Is this a father son build, that is your fathers now but when you are old enough to drive it will be yours? Is it a dedicated track car that you and your father both use? Or you both wanted an E30M3 and you are sharing this one until you find another one, then you will each own one.
    It's just I could not share this car with someone, it would be mine and only mine. I admire your character to be able to share such an exquisite example of an E30M3.
    • M3s14
      • Jan 2014
      • 34
      #77
      Originally posted by diegom6
      Outstanding job! Just get rid of the black electric tape (if is that what appear to be) and put some nice wiring harness tape like factory so all the detail you have worked in, doesn't get opaque by that minnor detail :)
      Tape
      Thank you for the tip, I will do that.
      rzerob, yes we split the costs and bought ourselves the car. ;)
      • jhaurimn
        • Nov 2012
        • 2224
        #78
        Wow. You really tore that thing down. Ill be honest, scrolling through the pictures I couldnt help but think "damn are they really putting this back together?"
        No expense spared, obviously. Very nice to see the body work pictures
        Current:
        1989 325i
        1988 M3
        1987 325ic
        Past:
        2001 330ci
        2001 M3
        • DER E30
          • Sep 2013
          • 2349
          #79
          Originally posted by M3s14
          The car is very, very loud. At low rpms it is just droning (?) in your ears.
          You need to talk loud with your co driver to be able to understand each other.
          Then past 3000rpm, that droning sound in your ears fades, and the S14 starts to scream more and more the higher you rev it.
          Even in idle it is very loud, already got a "word" by a neighbour who was angry.
          Sounds like my m42... stupid drone below 3k...
          Beautiful car!!! Wow!
          -Christian
          • n3rdy30
            • Jun 2011
            • 394
            #80
            FFFFUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
            1984 318i (w/ delicious M50 powa)
            Produktionsdatum: 03.10.1983
            Außenfarbe: Achatgruen Metallic (177)
            • Aleman
              • Mar 2012
              • 1604
              #81
              I do believe you've earned the right to wear this shirt. Amazing work!
              R135 /// 1990 Alpinweiß II 325is
              └┼┼┘ /// 1993 Black/Black Convertible (sold)
              ..24
              • BacDoc
                • Aug 2011
                • 83
                #82
                Thats it. The guys who rebuild the car body did an amazing job.
                Yes, the wire is going forward. The car has xenon lights, and there is one box connected next to the drivers side headlight, this is where it is going.
                Mtechnik II steering wheel is in now. But it is the biggest one, we are looking for an 365mm that we want to put in, and one photo at the fuel station...
                Maybe I can make a video of the engine sound sooner or later.
                The engine has 284° inlet and 276° outlet cams by Schrick, including harder Valvesprings, lifters and so on.
                48mm throttle Body. Lightened crankshaft and flywheel. Widened inlet and outlet ducts including bigger inlet and outlet valves.
                11,5:1 compression, single spark plug for each cylinder, KMS engine management, evo 3/sport evo crankshaft and engineblock. Engineblock was bought brand new at BMW. DTM header, 2x63,5mm exhaust pipes, bigger water cooler, bigger oil cooler and so on...
                The engine was built by "Peter Röllinghoff" who is an german expert for the S14 engine. You can find some stuff by him when you google.
                I can't express how much I hate you.
                • AlphaE
                  • Sep 2011
                  • 503
                  #83
                  wait... im confused... did you guys do the work? Or the pics are from when the previous owner had the work done??
                  Looks like a basket case some one couldn't walk away from..
                  Either way it looks sick now.. but what a mess of work to get there..
                  congrats on the new ride
                  Now with 2.7i power!!!
                  • M3s14
                    • Jan 2014
                    • 34
                    #84
                    Editet.
                    • econti
                      • May 2014
                      • 1149
                      #85
                      That sounds great. The crackle on the overrun is breathtaking.
                      Would love a video from outside the car.
                      My neck hurts though...
                      • tyouphoto
                        • Jun 2014
                        • 21
                        #86
                        :eeek: soooooooo gooooooood
                        travisyoungphotography.com // instagram @tyouphoto
                        • rommaster2
                          • Mar 2014
                          • 89
                          #87
                          I'm fairly certain from reading the first post that they purchased it in rebuilt form, the pictures from the rebuild are either the dealer they bought it from or the previous owner.
                          • M3s14
                            • Jan 2014
                            • 34
                            #88
                            Hello, yes exactly. I think I wrote it two or three times already, that we dont earn any credit. The previous owner did let the work done by a chassis shop, and did the rest of the work with his company, while Röllinghoff built the engine. I just wanted to share this car here. Sorry in case you got me wrong.
                            • BacDoc
                              • Aug 2011
                              • 83
                              #89
                              Turning cash into music. Beautiful.
                              • b1800e30m3
                                • Aug 2012
                                • 63
                                #90
                                real nice looks awesome!!!!
