my m42 carnage...
  • hellraiserdlx
    • Feb 2014
    • 47
    my m42 carnage...
    URL=http://s880.photobucket.com/user/Pewaukee23/media/20140215_205131_zpsmy2t9g6u.jpg.html][/URL]
    Idler gear snapped the F@*k off...the chain almost wore through the cover lol time for a new motor. Just figured i would share with you all.
  • getouth
    • Jan 2010
    • 3343
    That sucks bro!
    FEEDBACK:
    http://www.r3vlimited.com/board/showthread.php?t=316212
    BMWCCA #398608
    IG @yagayo38
    "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
    • M-technik-3
      • 18946
      That will buff right out, don't worry about it. J/K sorry to see your pain and suffering.
      • Nick_S
        • Apr 2011
        • 3658
        Damn! Bummer man. I've got my old motor sitting on a stand. If you can find a cheap easy way to get it to Wisconsin you can have it for $100 + what ever shipping is. It's just the bottom end and head, most everything is sold off it.
        91 318is M50 swapped
        05 Honda Pilot
        24V swap thread
        • wazzu70
          • Jan 2005
          • 1143
          That sucks. Gives some good insight why the later M42 ditched that idler!!!
          -Nick
          M42 on VEMS
          • Dj Buttchug
            • Jun 2010
            • 7688
            the 2nd one ive seen go to the grave like this. Makes me wonder if my perfectly rebuild engine with 800 miles on it is going to have this issue
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • M3s14
              • Jan 2014
              • 34
              Remove the snap rings of the chain tensior before installing it.
              Likely this wont happen.
              • hellraiserdlx
                • Feb 2014
                • 47
                I pulled the trigger on a low ish mile complete m42 off craigslist...kinda worries me doing that but at this point its really my only option. Let's just hope it runs :) I got the old engine out last night. Waiting on a couple parts before throwing the "new" one back in. If anyone wants the engine less the timing stuff and intake manifold let me know. CHEAP!
                • wazzu70
                  • Jan 2005
                  • 1143
                  I very highly doubt that is the problem.
                  -Nick
                  M42 on VEMS
                  • bmwman91
                    • Oct 2004
                    • 3134
                    Mine died the same way. I HIGHLY recommend swapping in a late model M42 timing case since those used a guide rail instead of that stupid sprocket. It should bolt right on to your replacement engine.
                    Transaction Feedback: LINK
                    • hellraiserdlx
                      • Feb 2014
                      • 47
                      I dont have time for that since its my only car and I need to be mobile like now :/
                      • M3s14
                        • Jan 2014
                        • 34
                        The sprocket is not the problem.
                        The bearings of the sprocket last like 500.000 kilometers.
                        If you put an M42 apart that has like 250.000 kilometers on the clock, the sprocket is still fine.
                        The sprocket itself is just the weakest point in the whole, but it does not just crack out of the timing case because its the weakest.
                        It brakes because of to high chain tension.
                        • E30beemer
                          • Oct 2013
                          • 131
                          Ouch!
                          • SSE30
                            • 362
                            Sorry to see this. I'm in Racine and have some miscellaneous M42 parts lying around if you find yourself needing something.
                            How can I ensure this doesn't happen to my M42?
                            Are there any symptoms to observe for?
                            1991 318iS Sterlingsilber - 1989 325i Cirrusblau (sold) - 1990 318iC Brilliantrot (sold)
