Overnighted a clutchmasters fx300 from VAC - was here at 7:30 am. Excellent shipping and excellent customer service at VAC.
A/C coil out, another little weight savings.
Oil Bung welded on
Long story short I figured I would do all the gaskets and seals on the tranny while it was out. Not sure why but I was advised the rear housing seal was leaking and at the time it made sense. Decided to pull the tranny apart. If you don't have to do this please don't. It is a press fitted transmission and a huge pain to take apart. I make shifted a tool to push the bearing through to take it apart but at a certain point I felt uncomfortable so I took it to a shop to be taken part and reassembled with the new gaskets and seals. Also turns out the rear housing seal was not leaking but at least everything will be fresh and checked out from the inside. Looking forward to getting the tranny back in the morning to start putting everything back in the car.
Injectors in. 30lb. remanufactures and flow tested. Like new. Took the intake off and replaced the O-ring seals just in case.
Took the old clutch off. Cleaned everything. Cleaned the flywheel, took some steel wool and made it extra smooth. Replaced rear main seal. New clutch installed. Locktite on everything.
Oil Bung welded on
