Hokejka e30 m50 turbo build
  • Pootis
    • 636
    #61
    I had a similar issue and I know you don't think you left anything in your intercooler piping but just for shits pull it off and check it again........I had a walmart bag on the turbo side of the intercooler not my proudest moment
    1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
    COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
    • hokejka
      • Jun 2014
      • 271
      #62
      lol, at least it was a quick fix. I checked all of that too
      • hokejka
        • Jun 2014
        • 271
        #63
        its tuning. Went to John at WOT-tech and got a quick flash for stock timing and my injectors so I could at least drive the car around. I had high hopes for my tune but oh well. Car will be retuned in the next couple weeks.
        • IronFreak
          • Dec 2012
          • 3702
          #64
          Getting closer! Light at the end of the tunnel. These situations are frustrating, hang in there.
          Instagram @rebellionforge
          • hokejka
            • Jun 2014
            • 271
            #65
            I am real tight with cash but am considering just going straight for bigger injectors, studs an head gasket so i don't have to retune twice and pay double. What do you guys recommend for MAF's? Is there a specific MAF everyone uses for blow through 15+ psi applications?
            • Pootis
              • 636
              #66
              Did you rebuild the turbo?
              • hokejka
                • Jun 2014
                • 271
                #67
                turbo
                turbo is brand new, all turbo hardware is brand new
                • JCarp90
                  • Feb 2011
                  • 1759
                  #68
                  Hahaha quick fix? This motherfucker's car was down for 8 months and he was contemplating selling it.
                  Say thank you, John.
                  • Pootis
                    • 636
                    #69
                    ......didn't you say you stopped getting on these sites?
                    • IronFreak
                      • Dec 2012
                      • 3702
                      #70
                      ^^John? The guy that bought my Z3 coupe John?
                      • Pootis
                        • 636
                        #71
                        Ha yes still have it too but might put it up for sale soon
                        • hokejka
                          • Jun 2014
                          • 271
                          #72
                          Turns out the tune was no good. Had high hopes for it. Took car to John at WOT a couple days after the new year. Got a base flash for my injectors so I could break in the clutch. Had to run to across state for school and work then was back at it the following week. Set up a dyno time and started tuning. Long story short stopped tuning short b/c waste gate spring was holding too much boost. Spiked briefly at 14-15 and holding at 12-13 on stock CR. Looks like engine is in good shape. Didn't want to risk and plan on running around 8 psi so have to reschedule final tune.
                          • hokejka
                            • Jun 2014
                            • 271
                            #73
                            Put weaker spring in. Holds 6 psi. Put in boost controller so I can go up from there. Until tune is finished i'm running 7 psi and shifting before 4.5k
                            • Pootis
                              • 636
                              #74
                              Ha I'm running the same boost controller and it works awesome! holds boost right where I want it
                              • CorvallisBMW
                                Long Schlong Longhammer
                                • 13039
                                #75
                                Nice, I ordered the same boost controller and it just arrived yesterday. Glad to hear it's getting good reviews.
                                Good luck on the tuning OP, keep pushing!
