My 1988 e30 325ix - Garage'd
  • jeenyus
    • Aug 2011
    • 2064
    #616
    Everything seems to be lining up well. Just gotta weld it together now. I even checked out how it fits with the vbands to weld together.
    • Northern
      I like cupcakes & sh!tboxes
      • 5256
      #617
      I've had issues with vbands warping when welded, so now I clamp them together in the orientation they'll be on the car and they seem to warp a little less and at least warp together so they still seal. I think your flanges are thicker than mine, so maybe that'll help too.
      I also learned the hard way to cover the clamp threads when welding this way - I stripped one of the t-bolts because the nut carried some slag up the thread.
      Originally posted by priapism
      Originally posted by shameson
      • jeenyus
        • Aug 2011
        • 2064
        #618
        Originally posted by Northern
        I've had issues with vbands warping when welded, so now I clamp them together in the orientation they'll be on the car and they seem to warp a little less and at least warp together so they still seal. I think your flanges are thicker than mine, so maybe that'll help too. I also learned the hard way to cover the clamp threads when welding this way - I stripped one of the t-bolts because the nut carried some slag up the thread.
        Thanks for the advice! I have heard a lot about the warping and I am nervous about it. I've also heard to wrap the v section of the flange to avoid spatter getting on it.
        • Northern
          • 5256
          #619
          Yeah the spatter is what eventually screwed up the threads. I just wrap the clamp in a layer or two of masking tape.
          There's probably a better way to cover it, but I don't have any anti-spatter spray.
          • jeenyus
            • Aug 2011
            • 2064
            #620
            i think using the clamp while welding is an awesome idea. I am def doing that.
            • jeenyus
              • Aug 2011
              • 2064
              #621
              Old vs new. Worth it.
              • mike.bmw
                • Dec 2015
                • 1770
                #622
                Mmmm. New shiny parts.
                I am loving the updates. The exhaust is going to be awesome. Keep it up!
                • 2mAn
                  Señior Mod
                  • 20892
                  #623
                  x2 What a wonderful feeling to throw that rusty POS in the trash and replace it with something shiny... even if its under the car
                  Simon
                  Current Cars:
                  -1966 Lotus Elan
                  -1986 German Car
                  -2006 Volkswagen Jetta TDI
                  Make R3V Great Again -2020
                  • jeenyus
                    • Aug 2011
                    • 2064
                    #624
                    Speaking of under the car. Progress is being made slowly. I only need to weld in the flanges and o2 sensor and it's done and off to ceramic coating. I realized I have to wait till it's all assembled before I could send it off.
                    • dadsbmw
                      • Oct 2014
                      • 475
                      #625
                      Is that the summit 2 x 2.25" to 3" y-pipe? How do you like it?
                      Also are you using an expander? I tried one from HF but it was absolute trash.
                      2003 Z4 3.0 6-speed- Silver, 19's, daily driver
                      1990 Silver 325i- Lowered on H&R OE Sports, e90 drop hats, KYB shocks, color matched rocker panels, 16" Emortal RS wheels on 205/50/16 tires... Currently getting a full refresh including an S52 swap!
                      1997 Black Ford Probe GT- Stripped to 2220lbs, MS3X, Forged motor in midst of assembly... Dyno results and 1/4 mile times pending
                      • jeenyus
                        • Aug 2011
                        • 2064
                        #626
                        haha! that's exactly what it is! you know your y-pipes.
                        I won't be using an expander. the fit is very tight on each connection, so i feel OK without it. The y collector, i bought some exhaust clamps to keep them connected on the long tube headers. I am unsure how successful it's going to be and if it doesn't work i guess i might just do vbands there as well... hoping that's not the case. all the other slip on connections have been welded together.
                        • jeenyus
                          • Aug 2011
                          • 2064
                          #627
                          I GOT IT STARTED!! sounds mean! Below is a picture of the final exhaust assembled. A picture of the headers after burning off a little (kind of cool color) and then finally my best weld yet with the Flux welder. LoL! Now I can officially send them off to ceramic coating and get the fenders on this car fixed up.
                          • jeenyus
                            • Aug 2011
                            • 2064
                            #628
                            Happy Quarantine. I've been getting some things done on the car. On the 14th of April I will get the exhaust parts over to the ceramic coater. They are working on limited capacity with the pandemic, so basically you schedule the drop off and that's my date. I should get them back on the 20th. In the meantime I've had to figure out the location of the oil filter. It just won't do in the stock location with these headers and tbh it's a dumb spot to begin with so I'm happy to have another reason. The lines are 10an, but those haven't arrived yet. Location idea is on the frame rail. Any advice how to properly attach the bracket to the frame without a rivnut?
                            • jeenyus
                              • Aug 2011
                              • 2064
                              #629
                              Oh I forgot to mention the brake lines. I swapped the front for Chase Bays lines and the driver's side was a PITA so I ended up mangling the shit outta the flare nut on the hard line. In the picture you'll see the rust that had accumulated that caused the struggle.
                              • Iloveboost
                                • Sep 2019
                                • 136
                                #630
                                Is this some universal clamp to be welded?
                                can you tell me where you bought it ?
                                nice work !
