Things are going to start getting interesting now.
Parts list, ordered:
-Piston rings
-Rod bearings
-Head gaskets
-Manifold gaskets
-water pump gasket
-head bolts (no need for studs, stock hold)
-034 Trans mounts
-Apikol diff mount
-Trans rebuild kit
-inner cv boot (one is torn)
-crank seal
-rear main seal
Need to order:
-Timing belt
-Clutch disk
Since I just did a timing belt and top end reseal 10k ago, I'm going to reuse what I can.
Getting excited. I've got some vacation time I have to use, so I looks like I'll have 3 day weekends all of December. Should give me some time to work on it.
As for Single, I think I'm still going to go that route.
-Piston rings
-Rod bearings
-Head gaskets
-Manifold gaskets
-water pump gasket
-034 Trans mounts
-Apikol diff mount
-Trans rebuild kit
-crank seal
-rear main seal
Need to order:
-Timing belt
-Clutch disk
