s54/5 lug coupe, finally finished!
  • Jb325is
    • 2137
    #61
    I would say that's definitely a factor, the merge is very far up, it's right around the transmission mount crossmember. I think the top end will get a lot stronger with some help from Frank. I talked to him about my lean idle issue, and he said with the 3.5" exhaust and the set-back bung that Innovate uses, there probably isn't enough velocity at idle to properly register on the wideband, which is why my readings are so high.
    - '88 m54 coupe
    <3
      • 34839
      #62
      yeah it looks like you're already making more power after 4k with a stock tune. I think you'll probably get some of that low end back.
      • digger
        • Nov 2005
        • 6140
        #63
        there was a guy on "M3forum.net" put the merge too close and killed the torque by 40-50rwtq sub 4000rpm compared to stock, moved it back near where BMW tend to put it (2nd harmonic) and it all came back.
        the shape of the curve suggests that the tune at low rpm is not optimised for the setup in anycase but even if that is optimised it is unlikely to bring back the all the torque.
        • darvo
          • Dec 2010
          • 407
          #64
          Wpuld you recommend the massive booster delete for a Daily with these brakes?
          • Butler
            • Nov 2009
            • 1613
            #65
            JB, you do solid work man! Great taste. My jaw hit the keyboard when I saw the RCs.... too good.
            -Nick
            Originally posted by 87e30
            First of all: calm the fuck down; second of all; cool story bro.
            • ttrousdell
              • Nov 2009
              • 1770
              #66
              inspirational. that is a gorgeous car.
              The Build:
              • Lee22
                • Feb 2012
                • 400
                #67
                the swap looks very clean. i'm curious as to why you went with a huge 3.5" exhaust headers back.
                  • 34839
                  #68
                  S54 likes huge exhaust - 3.5" is dyno proven.
                  I agree with digger, merge placement could be making a big difference here.
