cameras ready prepare to flash
  • ngampleh
    • Jul 2012
    • 466
    #121
    Originally posted by s14brent
    vht high temp primer
    Cool!
    I will looking those spray cane in my place
    [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
    [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
    Transaction Feedback
    • 318isbmw
      • Nov 2005
      • 2843
      #122
      Hey Brent, where'd you end up getting the adapter's for the e46 calipers. Looks identical to the 300mm.de but I'm sure a lot cheaper.
      • ngampleh
        • Jul 2012
        • 466
        #123
        He bought from me..
        Check this out
        I make also front kit for e46m3 on stock e30 knuckle..
        Will be available soon!!
        • s14brent
          • Mar 2014
          • 570
          #124
          yup! adapters were from hita (ngampleh)
          I finally had the chance to rebuild the four calipers.
          ended up getting new guide pins and bushings w/new caps. Car will be street driven and used on road trips to events so brass guides were out of the question.
          piston seals were replaced as well.
          reassembled and loaded. fronts have brembo pads, rears are just ATE. just waiting for new bleeder valves for the e36 m3 calipers, and they're good to go!
          My shorter swaybar hex turnbuckle came in. 6" vs 7" that I had on my e36 m3. Went with grade 8 lock nuts this time around as well.
          I need to unhook the driveshaft from the differential side next. and start working back there since the front camber plates are still over a week and a half out.
          89 325i 4dr s52
          02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
          21' Toyota Tacoma TRD OR 4x4 6 speed Manual
          • s14brent
            • Mar 2014
            • 570
            #125
            ugh. I dipshitted today. came home with this problem child.
            2002 525i 5spd touring, car has e39 m5 brakes all around. Car idles like shit. It has 150k, and has codes for a misfire (on cyl 4/5 startup), o2 sensor bank 1 sensor 1 (replaced bosch o2) and replaced the battery already. I replaced the spark plugs (awesome...they use s52 ngk's which I had sitting around for my next service on the e36! and the plugs I pulled out were way overdue!) but i think I need to check the coil packs next since it's still idles rough. I got it for a smoking deal and I've been trying to get a wagon back in my life! over $200 in parts ordered already, sorry e30!!
            89 325i 4dr s52
            • jpod999
              • Dec 2015
              • 1401
              #126
              E39 wagons are awesome, enjoy it!
              OBDI M62B44/6 swap
              Transaction feedback
              - jpod999
              • s14brent
                • Mar 2014
                • 570
                #127
                Cyl 4 has a frozen lifter or a stuck valve or combo of both..... might be looking for a m54b30 soon.
                I finally got my fortune auto camber plates (e30) for the e36 m3 coils!!
                Met up with 2man in Torrance over the weekend and got these sedan rear seats off him! Thanks again for driving and meeting me!
                and I just left the front suspension like this (just need to put the front calipers on both sides and then start the rear!)
                I'm pretty happy this is finally being worked on!! damn e39 impulse buy!
                89 325i 4dr s52
                • 2mAn
                  Señior Mod
                  • 20881
                  #128
                  It was good to meet you too Brent, seats look good in there. Hopefully, the seats are a perfect in your car because it certainly looks good in there!
                  Simon
                  Current Cars:
                  -1966 Lotus Elan
                  -1986 German Car
                  -2006 Volkswagen Jetta TDI
                  Make R3V Great Again -2020
                  • s14brent
                    • Mar 2014
                    • 570
                    #129
                    Thanks again Simon! The seats are flawless! I'll have to try and take better pictures when the cars not flooded with boxes of parts again!
                    cleaned the oily film off the rotors and put on the calipers. damn this looks soooo good!!
                    I'm hoping to get a few things during black friday...maybe a rear sway bar since I'm there. I'd actually be happy with just a stock ix/m3 rear bar but I like UUC/IE's mounting solution.
                    I unhooked the parking brake lines, and have most of the rear ready to drop out. Got the axles out earlier today, going to drop them off locally to get rebuilt soon!!
                    edit: just going to add on to this post. Haven't had time to drop off axles to be rebuilt yet. I dropped the subframe out yesterday.
                    and already pictured - I added garagistic's diff mount stud-conversion because why not
                    89 325i 4dr s52
                    • s14brent
                      • Mar 2014
                      • 570
                      #130
                      got the axles rebuilt by local repair shop ARE. holy crap I can't believe they are the same axles!!
                      I removed the wheel hubs/bearings. I was looking for instructions on welding these trailing arm reinforcements. I don't think I got any instructions....I know i have to weld about an inch on both sides and then hammer the "ear" to fit. Hope I don't mess these up! Will probably prep surface/weld next week if I have the time.
                      Here's whats been grabbing most of my attention lately.
                      m54b30 from the junkyard. Going to be putting that into my e39 525iT. Motor was super clean the day I spotted it, then I went back and a bunch of accy were missing (alternator, ps pump, coil packs, water pump, etc. I decided to pull it anywyas after a quick -manual crank compression test (1 compression stroke by hand) which resulted in 58-60 across the board. I think this motor will be a strong candidate. The car was t-boned, and had a bunch of new parts (driveline esp). i've never made this mistake of having so many inop project cars....I hope I can get one of these done by the end of the year!!::doubtful::
                      89 325i 4dr s52
                      • s14brent
                        • Mar 2014
                        • 570
                        #131
                        small update! but glad it's finally moving along! I had my friend shave down the subframe bushings for eccentric bolt clearance. Includes cluster fuck of parts:
                        uuc rear sway bar reinforcement, garagistic differential reinforcement and trailing arm reinforcements, ie motorsports camber/toe adjustments and subframe bushings, revshift trailing arm bushings.
                        next up: parking brake hardware/shoes and lines, e30 rear wheel bearings, z4 hubs. e46 caliper adapters.
                        edit: no need to bump thread since traffic is low. - Pressed in the wheel bearing and hub, installed new parking brake cables, shoes and hardware. Ended the day installing 78mm motorsport hardware studs
                        89 325i 4dr s52
                        • s14brent
                          • Mar 2014
                          • 570
                          #132
                          So..a few things stopped working right in my garage last week. When I was welding the garagistic trailing arm reinforcements, my wire speed kept fluctuating and pissing me off. I goofed up and realized I was using .35 drive rollers on .30 wire. :facepalm:
                          It seems to be working great, but most of the welding is already done.
                          Then my 60 gal air compressor's pressure switch took a shit on me and replacement parts took about a 4 days and finally arrived today. The stock PSI gauge was cracked when I got the compressor 2nd hand. I decided to go with a liquid filled one so the needle won't go crazy every time it's filling up. I didn't realize the gauge readings were backwards. I'm thinking of maybe getting a 90 degree brass fitting and seeing if I can have it sit upright, but I really don't care. The new switch cutoff is closer to 140 psi vs 130 psi. I have to look into adjusting that later.
                          Of course I had to test it out, so I cut he lip off the rear rotor dust shields to fit the larger e46 rotors. I'll clean the jagged edges up later.
                          and right when I was done UPS showed up and dropped off my ecs pair of front brake lines (that I'll obviously be running in the rear). Decided to throw them on along with Hita's (e30 adapters) e46 rear caliper adapter.
                          notice axles are also in!!
                          I won't be reinstalling right away, I decided to order an Ireland Engineering poly diff bushing. I realized I just did the new e28 3.46 recently, but it will be the only thing rubber back there, and I don't really want to drop anything back there for as long as possible if necessary! I gotta find a way to reuse the redline fluid in there currently! LOL...me being a cheap ass!
                          89 325i 4dr s52
                          • jeenyus
                            • Aug 2011
                            • 2064
                            #133
                            dude, fluid gets expensive when it's all said and done. I wouldn't say you're being a cheap ass as much as you're being efficient.
                            • Bggdnssnguy
                              • May 2016
                              • 585
                              #134
                              So you didn't press the bearing onto the hub first before installation? I would think you would want to press them in the knuckle as one..
                              88 d21 draggin pavement
                              89 dirty30 kissin earth
                              Im just here to learn new things and meet new people.
                              • s14brent
                                • Mar 2014
                                • 570
                                #135
                                I guess I could have, but I did my e36 m3 wheel bearings the same way (so far 7k no issues), and the c-clip would probably be a huge PITA to put in after.
                                89 325i 4dr s52
