Project: Spielereien. AKA "The dumpster fire"
  • delamaize
    • Nov 2013
    • 1465
    #76
    Swap is now in progress, Updates in other thread, See links in my sig....
    Dumpster Fire Pilot
    • MonkeyMadness
      • 3251
      #77
      Originally posted by delamaize
      Ghetto Shifter V1.0
      seems legit...
      • delamaize
        • Nov 2013
        • 1465
        #78
        Originally posted by MonkeyMadness
        seems legit...
        Don't kid yourself, It's not, Not Legit at all. haha. It's a ghetto mock up, and it's not staying.
        Dumpster Fire Pilot
        • MonkeyMadness
          • 3251
          #79
          But it's too legit to quit...
          • delamaize
            • Nov 2013
            • 1465
            #80
            Ha! Ultimately, I'm going to probably get the AKG DTM, like you have. For now, I got other things I should be spending the $370 on, Like a radiator. haha.
            I pretty much planned on using this one to make a shifter linkage, then I was going to have a buddy turn me a real handle to replace the allthread. Once everything is good to go, it will get replaced.
            But now, I'm in touch with the Ghetto side. haha
            Dumpster Fire Pilot
            • delamaize
              • Nov 2013
              • 1465
              #81
              More shit happened this weekend, I got the transmission crossmember re-welded, and reinstalled, the motor and transmission are sitting on their own mounts now, Square, and strait. 10mm spacers worked out well. In addition, I made a shitty little shifting rod, to go with my shitty shifter, both of which work pretty damn well. If I can clean this shifter up, and get a buddy to turn me a replacement for the all-thread, I may just keep this less than legit mock up. Also, I know my welds look like shit, but I'm getting good penetration, and they seem to be strong.
              Maston and I also got the Garagistic pedal box, and wilwood pedals installed. I still need to plumb the whole thing. In addition, we modified the Accelerator pedal, then had a thought, and I think I may be removing the orginial one, and retrofitting a IS300 one into the car, from the box of leftover parts from the IS300 parts car. It's a better pedal, and it will put the cable in a better position.
              Shit's rolling, I am hoping to have the first start by the end of April, and hopefully on the road by the end of may.
              Dumpster Fire Pilot
              • delamaize
                • Nov 2013
                • 1465
                #82
                IS300 Accelerator life.
                So I never liked the E30 accelerator, I had this one lying around from the IS300 parts car. I straitened out the bends on the cable end, rotated the cable connection 90 degrees, and put a rubber bushing in it to accept the BMW style cable, removed the weight, and spring. The bolt at the bottom of the steering column lined up with the bottom mount bolt on the IS300 pedal. I like it so far, I have not measured the throw, so I don't know if I need to bend it more, but just eyeballing it, I think I'm good.
                Dumpster Fire Pilot
                • delamaize
                  • Nov 2013
                  • 1465
                  #83
                  More Progress tonight. Yanked the motor and tranny out again, so I could get the brakes plumbed up, and replace the steering rack with a 330i one. I still need to get spacers, and new inner and outer tye rods.
                  Dumpster Fire Pilot
                  • jpod999
                    • Dec 2015
                    • 1401
                    #84
                    So I've got a question that's been bugging me for a while. You have two new brake hard lines going into the pump, one into the front and one into the back. Is the front line for the back or the front brakes?
                    OBDI M62B44/6 swap
                    Transaction feedback
                    - jpod999
                    • delamaize
                      • Nov 2013
                      • 1465
                      #85
                      There is marking on the pump, H, h, l, r and V
                      H is for Heck, which is back in German, and upper case letters is input, Lower case is output.
                      V is for Vorderseite, Which is Front in German, Upper case letter is for Input, l and r are for left and right front circuits.
                      Dumpster Fire Pilot
                      • jpod999
                        • Dec 2015
                        • 1401
                        #86
                        H is for Heck, witch is back in German, and upper case letters is input, Lower case is output.
                        Awesome thanks dude! I figured the markings meant something in German, I just couldn't figure out what.
                        OBDI M62B44/6 swap
                        - jpod999
                        • delamaize
                          • Nov 2013
                          • 1465
                          #87
                          I'm thinking about building my own harness again. I'd like some input from people that have done it before. Worth it or not? and how many plugs are still available from BMW?
                          Dumpster Fire Pilot
                          • delamaize
                            • Nov 2013
                            • 1465
                            #88
                            No new pictures, But Master cylinder reservoirs are mounted, remote Bias control cable attached and routed, Motor and tranny are back in, Clutch is plumbed, and fuel injectors, rail and fuel lines are all hooked back up. It's been a long few days....
                            Getting closer.....
                            Dumpster Fire Pilot
                            • delamaize
                              • Nov 2013
                              • 1465
                              #89
                              Rear subframe is out, Only too me about 45 minutes, I got lucky, no fight at all.
                              The camber/caster adjusters are welded on the new subframe, New subframe bushings are in, stub axle removed from the 2.93 open, and installed on the 3.25 lsd, new diff attached to new subframe. Gotta press the old swing arm bushings out and put new ones in, check wheel bearings, and press out and replace the diff mount. then I can get the subframe back together and back in the car....
                              Shit is moving fast now....
                              Dumpster Fire Pilot
                              • delamaize
                                • Nov 2013
                                • 1465
                                #90
                                I know you guys are probably getting sick of the little BS updates, but I like making them, so Onward.
                                I'm waiting for a few parts so I can continue, so I decided to get the head covers stripped and repainted. These covers had been stripped with a wire brush and repainted before, and they were kinda chewed up already. But they don't look too bad With new paint.
                                Freshly stripped with Chemical paint stripper and a nylon "wire" brush.
                                First 2 coats of paint
                                4 more coats, and installed.
                                Painting the Coil covers
                                Taping off the raised areas
                                Not perfect, but it fits my car, and I'm happy with it.
                                I got the dash back in yesterday, I'm still looking for a 4 cylinder tach coding plug. Hopefully, parts will be here tomorrow, I can get the rubber fuel hose between the filler and the tank replaced, then the subframe can go back in.
                                Dumpster Fire Pilot
