1993 Vert Build Progress - bagged and 5 spd swapped
  • mcgillaguddy
    • 487
    Hello,
    I've been on the forum for a while now, never been overly active though. I just picked up a another e30, so I wanted to re-introduce myself and introduce the new project. You can see my list of previous BMW's in the signature - picked up a cadillac ats to DD a few months ago and have been dying to have something to mess with again. So I picked up this:
    1993 325i Convertible (She is young: 11/1992 build date)
    Schwarz 2
    Black leather sport interior
    Automatic
    66k original miles
    fully documented repair history from 1995 to 2015
    hardtop, less a headliner
    crack free dash
    factory option 3.73 LSD
    original radio (I love this!)
    A/C still works! Never even been recharged
    almost zero rust (small bit attacking the rear valance)
    cut springs (it is the worst riding e30 I have ever been in)
    soft top is a good portion duct tape
    Everything in the car works, with the exception of the electric soft top
    The car has a pretty interesting story.. in 1994 the car was being used to smuggle diamonds between Canada and New York; NY police ended up impounding it. The smugglers had stripped some of the VINs off (most noticeable ones) of the car when the police got it. So New York assigned a new VIN to the car and auctioned it off. All of the VINs that are present and legible on the car match. It appears to be almost completely original.
    The family (mother's weekend car, so I hear) I purchased it from, had owned it from the time of the auction until now. They purchased the car in 1995 with 7k miles on it. It was eventually sold to the son in 2013 and immediately blew a timing belt (the factory original one!). It's amazing that it lasted 20 years! The son had the engine professionally gone through, partially rebuilt, and now it runs beautifully.
    The day I picked it up:
    and here is the title with the odd VIN:
    I've never really tracked a project before, but I plan to keep this thread as a build progress thread. I don't have a garage, so it will be stored through winter.
    Finished as of 8/14/16:
    5 speed swap
    new shaft seals
    new clutch
    new pilot bearing
    new slave cyliner
    new master cylinder
    new guibo
    lightened flywheel
    B&M SSK
    stainless clutch line
    Aero sport bags over Ksport adjustable coilover shocks up front
    Slam specialties RE-7 rear bags
    Stance coilover adjustable rear shocks
    Viair 480c compressor
    accuair vu4
    pressuryte auto level system
    Poly Subframe bushings
    Poly Rear Trailing Arm bushings
    Delrin offset Control Arm Bushings
    stainless brake lines
    New Transmission mounts (OEM)
    Poly Diff bushing
    Diff reseal
    rear seat repaired (was separating at one seam)
    new tie rod ends
    Garagistic RSM reinforcements
    New Valve cover gasket
    New fluids everywhere
    New fuel filter
    Walbro 255 fuel pump
    Rear Seat Headrest kit
    Rear seat headrests
    momo steering wheel refinished
    ZHP shift knob
    New rear brakes (crossed drilled)
    Bav auto plug wires
    Bav auto SS cat-back
    Catless mid-pipe with dual resonators
    new spark plugs
    valve adjustment
    New control arms
    Relocate Battery to trunk
    new cap & rotor
    new intake manifold gaskets
    Air management cubby built
    19lb injectors + SSSquid chip + m30 AFM
    Brand New soft top & tension straps
    Lloyd ultimats
    US ellipsoids with 55W 5000k HIDs
    35W 3000k HID fog lights
    Custom center console gauge panel
    New 18" leader hoses up front
    Future items:
    16x9 Borbet BS - almost done.
    205/50/16 Kumho Ecsta ASTs
    skid plate
    Fix power top (needs linkages)
    install coupe trunk lid
    Paint (over winter)
    1988 M6 - The real project.
    1993 325i Vert - Project/Weekender
    2013 ATS 2.0T - DD
    1997 740i - sold
    1987 325is Turbo -sold
    1991 325ix - Sold
    1990 m50 325is - sold
    1987 535is - sold
  • mcgillaguddy
    • 487
    So turns out the car was originally a 5 speed. Why it was ever changed to an automatic, I have no idea. I saw that it stated manual on bmwarchive, but I was hesitant to believe.. It is definitely correct though.
    2013 ATS 2.0T - DD
    1997 740i - sold
    1991 325ix - Sold
    1987 535is - sold
    • 2mAn
      SeƱior Mod
      • 20985
      Should make the swap back to manual a little easier. Car looks nice
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • mcgillaguddy
        • 487
        Thanks, it's not too shabby. Picked up the parts car..
        Complete tear down of the parts car starts tomorrow. Let me know if anyone needs anything. I'll be starting a part out thread soon enough.
        Sent from my SM-N9005 using Tapatalk
        2013 ATS 2.0T - DD
        1997 740i - sold
        1991 325ix - Sold
        1987 535is - sold
        • R1dd1ck913
          • Jul 2014
          • 382
          I need a trunk lock. Hopfuly with a key.
          Current
          99 328i (Sold)
          91 318is M50B25TU
          89 325ix (Parted out)
          87 325is (Parted out)
          95 525i (Parted Motor for 91 318is)
          • mcgillaguddy
            • 487
            Sounds do-able. I've never looked into how it's mounted but I'll check it out and let you know. I can always make a key copy so you have that too.
            2013 ATS 2.0T - DD
            1997 740i - sold
            1991 325ix - Sold
            1987 535is - sold
            • mcgillaguddy
              • 487
              Progress.
              2013 ATS 2.0T - DD
              1997 740i - sold
              1991 325ix - Sold
              1987 535is - sold
              • steve68
                • Jan 2013
                • 457
                hows the blower fan in the parts car??
                88 M3 Lachsliber glass top, 90 IS project,
                • mcgillaguddy
                  • 487
                  Not sure on the blower. I will check tomorrow and get back to you.
                  Riddick, I'll get back to you on the lock after tomorrow as well.
                  2013 ATS 2.0T - DD
                  1997 740i - sold
                  1991 325ix - Sold
                  1987 535is - sold
                  • steve68
                    • Jan 2013
                    • 457
                    thanks,
                    • mcgillaguddy
                      • 487
                      Sorry, blower is no good.
                      Riddick, sent you a pm on the trunk lock.
                      2013 ATS 2.0T - DD
                      1997 740i - sold
                      1991 325ix - Sold
                      1987 535is - sold
                      • steve68
                        • Jan 2013
                        • 457
                        oh well, thanks for checking for me,
                        Like your vert, looks good,
                        • TimKninja
                          • 2131
                          If your on Facebook, go on NE30. Its a local E30 enthusiast forum. Thatll get the parts car par out moving along.
                          Whats the matter with the parts car?
                          Really weird the car being converted to auto.
                          1985 325e M50TU(Sold)
                          1991 318is Slicktop (Sold)
                          1990 325is Brilliantrot S50/5 Lug Swapped.
                          1992 525i Manual shitbox Winter Beater
                          • mcgillaguddy
                            • 487
                            Thanks for the advice. Tear down is almost complete and I've got lots of good parts to get rid of; including e30 m3 rear seats. Just need to take the time to take pictures and make a complete list.
                            I believe it had spun a rod bearing, but I'm not positive. Engine was already taken apart, which is great for me, and everything there appears to be in pretty great shape. Head was previously rebuilt and he was planning on rebuilding the rest, but the car is not worth the time/money - lots of rust issues.
                            2013 ATS 2.0T - DD
                            1997 740i - sold
                            1991 325ix - Sold
                            1987 535is - sold
                            • 613EDRTY
                              • Apr 2014
                              • 267
                              Nice vert! and dam that parts car looks pretty clean..
                              Rescued 1986 325e Coupe
                              1988 325ix Touring 5spd currently being rescued
                              Ottawa, Ontario, Canada :finger:
