formyhealth - 1991 318is Build Thread - now with 1000% more 1JZ-GTE
  • formyhealth
    • May 2016
    • 217
    #151
    Originally posted by jeenyus
    something super satisfying about making a DT connector.
    My first time! It really is nice though and pretty easy with the right tools.
    Sent from my SM-G973U1 using Tapatalk
    • mitchlevy7
      • Aug 2011
      • 672
      #152
      noooooo. i was so excited on for the ecoboost!
      shoot me a PM id like to maybe buy some of the swap parts if you are getting rid of them
      www.cp-e.com
      1989 Zinno 325i m52 turbo coupe
      2015 Ford Fiesta ST, Daily Driver.
      • formyhealth
        • May 2016
        • 217
        #153
        Selling all of it, some is already spoken for.
        • formyhealth
          • May 2016
          • 217
          #154
          Dang, so far this engine looks in great shape!
          • formyhealth
            • May 2016
            • 217
            #155
            Worked a bit on wiring, steering column and seating position and got some goodies in.
            • e30mclow
              • Jun 2010
              • 193
              #156
              2 x White 1JZ 2 door build threads going on in here. Oh how the times have changed!
              • formyhealth
                • May 2016
                • 217
                #157
                Who's the other one? Its pretty cool!
                **edit** oh shoot, its you!
                • e30mclow
                  • Jun 2010
                  • 193
                  #158
                  Yup, right below your thread.
                  I should be running in the next couple of weeks, fingers crossed.
                  • formyhealth
                    • May 2016
                    • 217
                    #159
                    Too cool! I'll have to read through it. Did you go with the stock harness or use a plug and play from someone?
                    • e30mclow
                      • Jun 2010
                      • 193
                      #160
                      I initially set out to reuse the stock harness as it was running perfectly in my SC300. In my thread you can see I had begun stripping it down.
                      In the end I went with a Wiring Specialties harness.
                      Is using the stock harness doable? In my opinion yes, and I had a lot of it figured out and connected to the e30 bulkhead connector. I just started finding cracked wires etc.
                      • formyhealth
                        • May 2016
                        • 217
                        #161
                        That makes a lot of sense really, I am about 90% confident that I've found all the wires on the loom that I need to connect. I probably have an easier go at it since I'm directly connecting it to a standalone relay panel.
                        • formyhealth
                          • May 2016
                          • 217
                          #162
                          Its alive! Unhappy because no MAF and such but it lives.
                          12 likes, 0 comments - Daniel Maxwell (@1jze30) on Instagram: "It's alive! #1jze30 #1jzgte #e30"
                          • formyhealth
                            • May 2016
                            • 217
                            #163
                            Did some more stuff, steering column is fabricated, mounted the throttle pedal to the garagistic pedal mount and started on primer. Sent from my SM-G973U1 using Tapatalk
                            • ZekeTheSneak
                              • 1562
                              #164
                              I like the steering setup, Smart way of doing it.
                              • formyhealth
                                • May 2016
                                • 217
                                #165
                                Thank you! To be honest I kind of winged it but it worked out. Sent from my SM-G973U1 using Tapatalk
