formyhealth - 1991 318is Build Thread - now with 1000% more 1JZ-GTE
  • econti
    • May 2014
    • 1092
    #121
    I assume there is enough drain from the back to the front like the stock ones are?
    • formyhealth
      • May 2016
      • 217
      #122
      Hopefully!
      I'll be baffling the sump area and may end up inserting a slanted plate inside of the flat section to give it the proper drain angle. Or I give the whole engine 1 or 2 degrees of forward slant which should do the same thing.
      • formyhealth
        • May 2016
        • 217
        #123
        I got the engine back up on the stand today to start working on lengthening some of the harness wires. Will be glad to be done with this part!
        Sent from my SM-N950U using Tapatalk
        • iso_hi
          • Dec 2014
          • 510
          #124
          As an owner of a Focus ST and E30, I cant wait to see this in action
          1987 325 Turbo
          • formyhealth
            • May 2016
            • 217
            #125
            Can't wait for all of the torques!
            • formyhealth
              • May 2016
              • 217
              #126
              Diy big brake solution arrived! These are 4 pot calipers from a 1991 rx7.
              • formyhealth
                • May 2016
                • 217
                #127
                I need bigger wheels but these are going to be sweet!
                • e30RS
                  • Mar 2019
                  • 437
                  #128
                  Gunna be beastly.
                  • formyhealth
                    • May 2016
                    • 217
                    #129
                    Well, I scored one hell of a deal today. 15x7 Team Dynamics wheels with healthy looking Toyo Proxes RR slicks, $300!! Quite happy and they fit over the rx7 brake calipers.
                    • formyhealth
                      • May 2016
                      • 217
                      #130
                      Kinda jumping around a bit on projects but worked on fitting the front valance today.
                      • formyhealth
                        • May 2016
                        • 217
                        #131
                        Got the oil cooler and intercooler installed today, and found some nice 6AN adapters for the steering rack lines. I'm going to go with a Volvo pump to save space in the footwell area.
                        Sent from my SM-G973U1 using Tapatalk
                        • formyhealth
                          • May 2016
                          • 217
                          #132
                          Oooooh [emoji3]
                          • Sh3rpak!ng
                            • Jan 2014
                            • 2667
                            #133
                            Originally posted by formyhealth
                            Oooooh [emoji3]
                            What's that?
                            Sent from my SM-G960U using Tapatalk
                            Shadetree30
                            • formyhealth
                              • May 2016
                              • 217
                              #134
                              Originally posted by Sh3rpak!ng
                              What's that?
                              That's a wireless (infrared) button pad that sends a signal to a programmable relay controller. It mounts behind the steering wheel and I'll be using it for turn signals, wipers, launch control ;) etc.
                              • Sh3rpak!ng
                                • Jan 2014
                                • 2667
                                #135
                                that sounds pretty damn cool :p saving this idea for future use
                                Shadetree30
