formyhealth - 1991 318is Build Thread - now with 1000% more 1JZ-GTE
  • formyhealth
    • May 2016
    • 217
    #106
    Hey everybody, just wanted to give an update to let you know the car (and us!) are in a new home. I'll attach pics of the new shop soon!
    • wworm
      • Dec 2016
      • 1719
      #107
      oh thank god. I was wondering about this car the other day...
      1984 Delphin 318i 2 door
      • mitchlevy7
        • Aug 2011
        • 672
        #108
        what are you going to do for engine mounts? or are you still figuring out engine placement?
        I was looking at a 2.0 block just now. The drivers side looks pretty simple but the passenger side is a pain as you have the turbo oil drain right there.
        www.cp-e.com
        1989 Zinno 325i m52 turbo coupe
        2015 Ford Fiesta ST, Daily Driver.
        • formyhealth
          • May 2016
          • 217
          #109
          [emoji4]
          Sent from my SM-N950U using Tapatalk
          • formyhealth
            • May 2016
            • 217
            #110
            I fabbed up some engine side brackets but haven't came up with any ideas on attaching them to the frame yet. I'm all ears if you see a way, I'm currently running into vertical space restrictions.
            • formyhealth
              • May 2016
              • 217
              #111
              Some photos of the shop!
              • HawaiianE30
                • Nov 2012
                • 81
                #112
                How’s it coming? Just came across this and it’s a great read, excited to see any progress!
                Originally posted by e30guydownunder
                Stupid German wookie winning F1 WDC and beating Webs. waffleswaffleswaffleswaffles.
                • formyhealth
                  • May 2016
                  • 217
                  #113
                  Thanks man! I've got some updates coming soon(ish)
                  • formyhealth
                    • May 2016
                    • 217
                    #114
                    Since I've gone with overhung pedals I need to do something different with my steering column as the bracket that mounts the pedals is not compatible with an airbag column.
                    Since that's the case I've decided to completely Fab the column instead of retrofitting the airbag column. So, to kill two birds with one stone I've found both my power steering replacement as well as the start of the steering column fabrication in the form of a 2009 Toyota Corolla electric power steering motor.
                    I've read a ton about options and this is one of the easiest (subjectively) as it doesn't require a 3rd party controller and only 3 wires to power up.
                    • formyhealth
                      • May 2016
                      • 217
                      #115
                      Another little update, since I needed to prototype some parts I picked up a 3d printer (Ender 3) and went about learning Fusion 360. I started with the dash vents and am pretty close to a final part. I'll do a cutout vent for a 52mm gauge on the driver's side, blank on the passenger and in the middle will be three holes, one for another gauge and 2 50mm air vents.
                      Once I get more comfortable with modeling I'll start on prototyping mounts for the Corolla power steering motor.
                      • formyhealth
                        • May 2016
                        • 217
                        #116
                        Got the car out of the shop so I can organize. Shop is basically good to go so I can actually get in there, and move around. Updates should start trickling in soon, I plan to get the steering situated first, and then finish up the body work.
                        • formyhealth
                          • May 2016
                          • 217
                          #117
                          After much deliberation I finally got the focus pedal mounted. Was going around and around about it and then realized the easiest thing to do was modify the pedal box mount from garagistic by adding a bracket on the side. I think it turned out quite nicely!
                          • econti
                            • May 2014
                            • 1090
                            #118
                            Big work, love it
                            • formyhealth
                              • May 2016
                              • 217
                              #119
                              Originally posted by econti
                              Big work, love it
                              Thanks man happy to be working on it again.
                              • formyhealth
                                • May 2016
                                • 217
                                #120
                                Had Under Pressure Racing Development weld up all the pieces I put together for the oil pan. It's a front sump now!
