E30 M42 Touring -92 // bagged + turbo build thread ** #119 Dyno 593hp/611nm @hubs
  • krisu
    • Aug 2014
    • 76
    sachs 765 pressure plate, M50/M52/M54S50/S54 light weight flywheel 6kg for 240mm pressure plate and PPF flywheel bolts
    also bought type188 lsd 3,23 ratio
    my 240mm sachs clutch also came, but once i opened the package i saw this, well hopefully i'll get a new one
    @ instagram: https://www.instagram.com/krisueh/
    • ThatM20Guy
      • Aug 2014
      • 600
      Holy nuts this is gonna be cool!
      89' 325ix Diamantschwarz/Black rattle can...
      Insta: r_moose_w
      Originally posted by flyboyx
      I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
      • downforce22
        • Aug 2009
        • 3193
        i always wondered about how to fit an m42 turbo manifold in there, surprised the g&t unit doesn't fit
        • CorvallisBMW
          Long Schlong Longhammer
          • 13039
          Great progress, looking forward to more :up:
          • Codym42
            • Mar 2013
            • 611
            This is really cool. Sometimes I wish I had gone the turbo route instead of buying a 24v...
            What are your power goals?
            '90 325i - 5 speed coupe
            '05 330ci 6MT ZHP
            • krisu
              • Aug 2014
              • 76
              thanks man :)
              yeah, it would have fitted with a regular t25 turbocharger, but not t28..
              thanks! slowly but surely! it will probably take me half summer to finish it, but it's getting there!
              thanks! haha ye 16v is the way to go! too many 24v around my town! im trying to get 250-300whp for this summer! but later maybe even more
              • krisu
                • Aug 2014
                • 76
                hi, small update!
                sand blasted and painted the brake calibers, also new seals etc..
                more sand blasting and paint for rear axle, new strongflex bushings installed!
                rear sway bar!
                and its there! with new brake lines and the lsd..
                rear
                front
                suspension is starting to be complete! next to do is paint the engine bay and remove unnecessary mountings etc..
                • Shangsta
                  • 1485
                  Love this build. I have a lachsilber touring too but mine is a 320 and i also own a 318is. I kind of wish my touring was a m40 as I have a spare m42 and would love an m42 touring
                  :shock:
                  • krisu
                    • Aug 2014
                    • 76
                    thanks man! :D i got an original 318is too, im driving it daily
                    • krisu
                      • Aug 2014
                      • 76
                      finally my engine bay starts looking better, removed unneccesary brackets and all that ugly tectyl, also repaired small rust spots and painted it with air gun!
                      • Shangsta
                        • 1485
                        awesome look forward to seeing more updates
                        :shock:
                        • krisu
                          • Aug 2014
                          • 76
                          hey all! something done at garage! oil filter housing got oil pressure adapter. it was a tight fit but it works!
                          plastic pipe has an- fitting now, waterfeed to turbo. there was orginally heater plate for the M42 throttle body from there.
                          engine bay getting some stuff back there! also battery relocation done!
                          i moved my airtank and compressors a bit to make those touring hatches fully open.
                          • krisu
                            • Aug 2014
                            • 76
                            some dei engineering heat wrap, also egt sensor there!
                            also vag coils with integrated amplifier
                            1100cc injectors, had to use the original fuel rail because my nuke performance didn't fit with original intake manifold. well some day i'll make/find a plenum for it!
                            starting to look like an engine
                            new clutch finally came, it took over a month but i have some problems now with my flywheel. here is an image where my clutch will stay if i use this flywheel. it won't go further in the transmission bore. i might need to buy a new flywheel and sell this one or machine my tranny -10mm. to make the clutch fully go to the tranny axle!
                            • jeenyus
                              • Aug 2011
                              • 2064
                              great build! love how it's coming together.
                              • CorvallisBMW
                                • 13039
                                Love all the new hotside bits, the exhaust wrap looks great!
