E30 M42 Touring -92 // bagged + turbo build thread ** #119 Dyno 593hp/611nm @hubs
  • ccsdo5
    • Mar 2013
    • 708
    #31
    Very nice work OP! Great job with the wiring too! Nice and neat, this is a very detail oriented build and should be awesome when done.
    -Dee
    5-lugged turbo 318is Barn car
    IG: @deebelmont
    • krisu
      • Aug 2014
      • 76
      #32
      Originally posted by jeenyus
      great build! love how it's coming together.
      Love all the new hotside bits, the exhaust wrap looks great!
      thank you guys! :D new flywheel is ordered, it should be coming later this week! i'll upload some pics when installing it!
      meanwhile here is some pics from last summer!
      @ instagram: https://www.instagram.com/krisueh/
      • Olie92
        • May 2017
        • 42
        #33
        Great build here...engine bay would look super cool....
        • krisu
          • Aug 2014
          • 76
          #34
          Hi all, something been done! :p
          i will use m42 pilot bearing, but my problem is that transmissions clutch axle is not long enough for the pilot bearing.. i need to make an extension to make it fit..
          and its done!
          new m50 flywheel in place. starter ring from m42, its the same as m50 etc :)
          pressure plate and clutch installed!
          gearbox in place , new 320d clutch slave cylinder and throwoutbearing.. and new oils!
          everything done, engine back to the bay!
          • krisu
            • Aug 2014
            • 76
            #35
            aem ethanol fuel pump
            an fittings to fuel lines
            china catchcan, its so small, i might need to replace it LOL
            current situation, engine wiring yay..
            standalone in orginal location
            to be continued
            • downforce22
              • Aug 2009
              • 3193
              #36
              I have th same oil catch can, but want to make it filter better. Have any ideas?
              • krisu
                • Aug 2014
                • 76
                #37
                what do you mean? why do you want to filter it better? are you running it back to the intake manifold?
                • downforce22
                  • Aug 2009
                  • 3193
                  #38
                  When I opened mine up it just had a couple of baffles. I wanted to condense more of the oil vapor so I added some scotch brite pads as a filter material but it still vents lots of oil vapors. I was wanting to add a better filter material to the center of the can to help catch more oil. I have now drive over 1000 km with mine so I should probably check to see if there is any oil in the bottom of the can.
                  • krisu
                    • Aug 2014
                    • 76
                    #39
                    Ah yeah, well i don't really know what should be used in there to make it filter better..
                    i am going to try not to use any filter in there. it will vent the oil vapors to atmosphere
                    • krisu
                      • Aug 2014
                      • 76
                      #40
                      shortened driveshaft with bigger flange for 96mm guibo
                      • krisu
                        • Aug 2014
                        • 76
                        #41
                        shifter assembly modified, now it works.. needed to weld shifter arm to different angle and also the shift selector rod..
                        couldn't use the original shift lever, had to put some random short shifter in there!
                        • krisu
                          • Aug 2014
                          • 76
                          #42
                          hello!
                          car is almost complete! engine management wiring done, and everything bolted back to the bay.
                          had a small panic because my clutch didnt disengage, well thank god it was only the slave cylinder that had to be replaced. i were worrying that i need to take the trans out one more time. well i didn't, the e36 328i slave cylinder works just fine!
                          everything seems to be working, it was time to go dyno and see how much whp we get! :D
                          unopened engine with original gasket and head bolts. lets see how long will this last! i got arp headbolts and athena mls waiting
                          its pretty damn fun to drive!! videos from dyno in my instagram!
                          • Powling
                            • Jan 2015
                            • 1291
                            #43
                            I recently picked up a second valve cover and intake to powder coat them black, but this pic might have made me change my mind! The clean silver looks awesome.
                            Steve • Toronto
                            1991 318is • Brillantrot
                            Build Thread
                            • econti
                              • May 2014
                              • 1152
                              #44
                              What turbo is it again? Very impressive for unopened engine
                              • krisu
                                • Aug 2014
                                • 76
                                #45
                                yeah its pretty dope
                                thanks ;) turbo is garrett GT2871R 836026-5021S (TURBINE trim 76 ind 53,9 exd 47 A/R 0,64 COMPRESSOR trim 56 exd 71 ind 53,1 A/R 0,60)
