E30 M42 Touring -92 // bagged + turbo build thread ** #119 Dyno 593hp/611nm @hubs
  • mike.bmw
    • Dec 2015
    • 1777
    #106
    Congrats on the feature! Those photos are great.
    • krisu
      • Aug 2014
      • 76
      #107
      Hey all, radium engineering fuel surge tank from usa, it has 450 lph walbro e85 fuel pump inside it. hopefully it will be enough for my goals, pictures installed on car spare wheel area.
      some other goods ready to be installed too, davies craig ewp 150 water pump to help on the cooling. i will try to leave the original water pump there aswell.
      Mocal eop2 oil pump for oil cooling setup. both water and oil pumps are going to be pwm controlled.
      #staysafe
      @ instagram: https://www.instagram.com/krisueh/
      • krisu
        • Aug 2014
        • 76
        #108
        Also exhaust manifold and downpipe almost done, just need to wrap them up again with some exhaust heat wrap. manifold has now v band for the exhaust housing for easy installation, i will never go back to bolt flanges again! wastegate is also welded on the exhaust housing, i think it was best decision for the smooth flow of exhaust to wg. i might need to go for polyurethane motor mounts, but we will see..
        Plenum arrived, it was a custom job i bought it from one small company VK-tuning in Finland. Small modifications and it fitted really well. Had to weld the throttlebody to different angle aswell as the last curve. no big deal!
        • econti
          • May 2014
          • 1152
          #109
          Do you rate the Nuke rail? What injectors are you using? Bout to start doing fuel system on mine
          • krisu
            • Aug 2014
            • 76
            #110
            Im going to use 2200cc injectors with E85 obviously, walbro 450 should be capable to +600hp aswell as original fuel pipes and an6 lines..
            • econti
              • May 2014
              • 1152
              #111
              Ah OK. I'm looking at probably 1200cc injectors, I've already got a Walbro 460 so that should be fine. Beautiful, thanks.
              • pandaboo911
                • 2070
                #112
                Holy Perkele!!
                Im jealous how much room you have in the engine bay. Nice car!
                • krisu
                  • Aug 2014
                  • 76
                  #113
                  Originally posted by pandaboo911
                  Holy Perkele!!
                  Haha, yeah i got alot of space to work on! 4 bangers are nice because of that! But i still feel like its getting tight in some areas.
                  • krisu
                    • Aug 2014
                    • 76
                    #114
                    Update from garage, exhaust manifold and downpipe got wrapped, had to modify turbo heat shield a little bit so it fits nicely! used some steel wire so it doesnt unravel.
                    Injectors, Ignition coils, spark plugs etc back to car! spark plugs are bcpr bcpr7es. Injectors 2200cc ev14, im going to drive with RE85.
                    Oil drain for turbo stainless steel PTFE teflon hose, same for oil feed.
                    Both oil and water pump are now in place. AN10 hose from oil pump to cooler and back to oil pan. Oil cooler is mounted on front of the car, kinda jdm looka like lmao, but i like it. i think you will probably hate or love it, it will definitely divide opinions.
                    To do list is getting short. Some electrics and throttle cable to be done and oils into engine and then getting ready for first start!
                    • econti
                      • May 2014
                      • 1152
                      #115
                      Got to be one of the most serious M42s on the planet
                      • Jaker
                        • Oct 2013
                        • 234
                        #116
                        Let me know how you like the Davies Craig water pump setup. I am planning to use the same pump for my E36 K series swap turbo motor. Also, that surge tank is designed to be mounted vertically. I don't know how effective it will be mounted the way you have it.
                        • krisu
                          • Aug 2014
                          • 76
                          #117
                          Hey, i will post you some feedback on the pump when i have seen it in action. Actually this surge tank can be mounted either vertically or horizontally. Fuel pump output is still the lowest point in the tank. It might not be as effective but its definitely gonna make the job done without issues.
                          • krisu
                            • Aug 2014
                            • 76
                            #118
                            This weekend i done some last wirings to the pumps and now they are ready to go. Soon its time to give it a first start and get ready for dyno. Removed car from jack stands and i am getting hyped!
                            • krisu
                              • Aug 2014
                              • 76
                              #119
                              Car started fine this weekend and almost straight away drove to dyno to see the numbers. first oils i used 5w-40 and then before dyno i switched to 10w-60 castrol edge. Dyno results are pretty damn impressive and this turbo is spooliing damn nice! I almost got what i wanted. missing 6.5hp from my goal. I will make it with this turbo i think. I need to do bigger exhaust, i think i currently have to small. Even a screamer would definitely help me. So close! I will post some videos on instagram go check them out!
                              Dyno results
                              420hp at hubs @1.2 bar boost
                              Best result 593hp/611nm at hubs @ 2.3 bar boost
                              m42 power!
                              • econti
                                • May 2014
                                • 1152
                                #120
                                Jesus fucking Christ. 600rwhp out of a M42 with a power curve that still looks normal and driveable. This is insane!
