2.8L M20 9.8:1 stroker build: my 323i reincarnated
  • betz
    • May 2016
    • 317
    So the story goes.. I crashed my beloved 323i in a sharper than I thought downhill turn that caused unexpected oversteer. It was 1000% my fault with my shit driving ability is the reason I mangled one of the last 323i's to exist in California.
    After dumping about $1k into straightening the body it became clear that the 323i wouldn't be completely straight without spending inordinate amounts of money.
    So I started searching for an early model shell. I saw an ad on craigslist for a pretty shitty looking 325e, but it was super close so I basically said fuck it.
    Owner was a skater dude who wanted to drift it but lost interest after he got an E36.
    He offered I take it for $200 so he'd have money to go to the beach with his friends...
    So hell yeah I bought it
    Edit: I found a crisp $20 bill while cleaning the carpet, so it really was an $180 car.
    Alright, so I'm gonna try and help people who want to do this build by listing the parts required to make it happen. I will update it as I think of stuff.
    Main Engine parts:
    -Any M20 block
    -885 (325i) head. At least a 272 cam.
    -84mm Crankshaft from a 2.8 M50/52engine. E36 328i, E39 528i, etc.
    -Stock 325i short skirt pistons. These pistons have the domed top and the flat skirts.
    -130mm rods. Either from 325e, 320i, 323i etc
    -325i intake manifold, throttle body, AFM, airbox, boot, and ICV
    Machining:
    -This spacer (Just ask a local machine shop)
    -My block was decked exactly 0.020" or .508 mm for a CR of exactly 9.81:1 assuming a stock M20B25 is exactly 8.8:1
    -Shave off the non-structural looking part of the piston skirt.
    -Turn the crankshaft counterweights down pretty much all the way, right before you start hitting the other side of the crankshaft (the part that sticks out next to the connecting rod bearings)
    -Get the entire assembly professionally balanced: pistons, rods, crankshaft, flywheel, vibration damper, fan pulley, and pressure plate
    Electrical: (starting from 325e)
    -325i complete engine wiring harness
    -325i injector harness
    -Toothed crank wheel
    -CPS and CPS bracket
    -Motronic 1.3 ECU (173)
    -Recommend megasquirt or custom/dyno chip
    -Recommend Wideband (Innovate LC-2)
    -325i Spark plug wires (for CID sensor)
    -NGK BPR6ES spark plugs
    Fuel:
    -At least 19 lb injectors.
    -325i 3.0 bar Fuel pressure regulator
    -Stock pump should be fine.
    Cooling:
    -Stock cooling is fine. Either late or early model.
    March 2019 cotm
    https://www.r3vlimited.com/board/for...the-month-betz
    vidyas
    In car
    From stop
    "Swing it bro!"
    '86 Burgundrot 325 2.8 stroker.
    Other cars:
    2000 Porsche Boxster
    2006 Subaru Outback XT 5MT
    1972 Porsche 914
  • betz
    • May 2016
    • 317
    Other cars:
    1972 Porsche 914
    • 2mAn
      SeƱior Mod
      • 21031
      Took you long enough to post pics! hahah
      Where is the rear trim? lemme have it
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • betz
        • May 2016
        • 317
        Car had a "blown head", didn't care since I already had a "e" block in the works for a 2.7 stroker for my 323i.
        Other cars:
        1972 Porsche 914
        • betz
          • May 2016
          • 317
          Yeahhhh the photos were way too big. Undid it and compressed them. More incoming...
          And what trim? From the 323i?
          Other cars:
          1972 Porsche 914
          • 2mAn
            SeƱior Mod
            • 21031
            No, the diving board. Its missing in the pic. Trying to make some front delete panels since nobody else.
            BTW Im VERY curious about the 2.8L M20 build so I will be watching closely
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • betz
              • May 2016
              • 317
              I pulled the 731 head from the 323i, got the head inspected by a machinist but it needed new valve guides. I was planning on using valves from this 885 head I picked up, but he said he could't make them fit easily. So, I decided to go a different route...
              E36/E39 84mm M52 crank, 325i short skirt pistons, eta rods, 885 head. 2.8L, 9.75:1+ compression. My machinist decked the head and measured the squish band clearance, so it could easily be closer to 10:1. 5mm off the block is standard to bring it to normal clearance. Here's some general info on the 2.8 build: http://www.e30zone.net/e30zonewiki/i...Building_a_2.8
              Other cars:
              1972 Porsche 914
              • betz
                • May 2016
                • 317
                Got the block hot tanked, then shot peened..
                Other cars:
                1972 Porsche 914
                • 2mAn
                  SeƱior Mod
                  • 21031
                  please keep posting more progress
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  • betz
                    • May 2016
                    • 317
                    Crankshaft turned, rods and pistons glass beaded, piston skirts shaved. Also got my company to machine me a spacer for the front crankshaft oil seal.
                    Other cars:
                    1972 Porsche 914
                    • betz
                      • May 2016
                      • 317
                      The pistons were knurled and the whole assembly was balanced...
                      Other cars:
                      1972 Porsche 914
                      • betz
                        • May 2016
                        • 317
                        Block painted aluminum color, high temp engine block paint.
                        Other cars:
                        1972 Porsche 914
                        • betz
                          • May 2016
                          • 317
                          Meanwhile, pulled the engine out the 325e and put the Z3 steering rack and ground controls from my 323i in.
                          Other cars:
                          1972 Porsche 914
                          • LateFan
                            • May 2013
                            • 4432
                            Burgundrot is a good start.
                            Sad to lose a 323...was it euro bumpered?
                            What does the knurling do on the skirts?
                            • betz
                              • May 2016
                              • 317
                              It twas. Forgot to mention, the front got a little mangled, but I've already swapped the rear onto the "e". I'm looking into straightening the front but there's hardly any chrome bumper shops around anymore.
                              Knurling helps hold oil at the edge of the skirt. Its also allows a worn piston skirt to perform more like a new one because knurling raises the edges of the skirts up, so that it fits tighter.
                              It also looks cool.
                              Other cars:
                              1972 Porsche 914
