2.8L M20 9.8:1 stroker build: my 323i reincarnated
  • betz
    • May 2016
    • 317
    New intermediate oil pump shaft bearings (Order using part number, had machinist fit them via procedure described here... http://www.e30tech.com/forum/showthread.php?t=95546)
    '86 Burgundrot 325 2.8 stroker.
    Other cars:
    2000 Porsche Boxster
    2006 Subaru Outback XT 5MT
    1972 Porsche 914
    • 2mAn
      SeƱior Mod
      • 21031
      Oh man, this is going to be so good! I already love it
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • betz
        • May 2016
        • 317
        New main bearings, clearances checked via plastigage
        Other cars:
        1972 Porsche 914
        • betz
          • May 2016
          • 317
          Crankshaft & pistons in, oil pump rebuilt
          Other cars:
          1972 Porsche 914
          • betz
            • May 2016
            • 317
            Aaaand finally to present day. The head as it sits at the machine shop. Should be getting new valves today.
            Other cars:
            1972 Porsche 914
            • betz
              • May 2016
              • 317
              Not pictured, breaking two piston rings and even breaking the shitty wrinkle band ring compressor, buying a tapered ring compressor, getting the wrong main bearings, getting the wrong clutch and pressure plate, lugging the head, block, and crankshaft to different shops in the back of my G35 Coupe, and getting my hands greasy af for like 10 weekends straight.
              Other cars:
              1972 Porsche 914
              • LateFan
                • May 2013
                • 4432
                ^^ this is normal - you're doing it right.
                Original size valves going in?
                • betz
                  • May 2016
                  • 317
                  Yes, original 42mm intake/ 36mm exhaust valves with 3 angle valve job. New valves replacing the bent ones from the original head.
                  All new febi rockers and eccentrics and bimmerheads 274 cam.
                  Other cars:
                  1972 Porsche 914
                  • wworm
                    • Dec 2016
                    • 1719
                    This is so sweet! Looking forward to more progress
                    1984 Delphin 318i 2 door
                    • sampayne
                      • Apr 2014
                      • 396
                      Looking good. Sub'd. What management are you running? Power goals?
                      Originally posted by 2mAn
                      The BMW V6 is the best
                      • AwakenNoMore
                        • Dec 2010
                        • 1291
                        Sub'd as well. I'd like to build the same engine for myself one day. May Pm you for info when the time comes. Build is looking great so far!
                        1991 325i - "Scambles" The Daily Driven lightly modded.
                        1988 Mazda RX-7 TII "Mako" The Free Dorito
                        bacon by Jared Laabs, on Flickr
                        • betz
                          • May 2016
                          • 317
                          I will be running Motronic 1.3 with the 173 ECU and an Sssquid tune. The tune is stage 2, 91 octane, M50 green top injectors.
                          I'm shooting for about 200 bhp to start, but plan on changing things incrementally later. After I'm sure the setup is solid, the car has passed smog, and my wallet feels heavier than usual will I start changing externals.
                          Long tube headers and ITBs are on the want list. Hoping for 200whp all said and done.
                          Other cars:
                          1972 Porsche 914
                          • betz
                            • May 2016
                            • 317
                            Thank you!
                            Feel free! It's been a learning experience for sure.
                            Other cars:
                            1972 Porsche 914
                            • AwakenNoMore
                              • Dec 2010
                              • 1291
                              I'm betting it'll make more than 200whp if the tune is optimized for your specs. It'll be interesting to see where it ends up.
                              • betz
                                • May 2016
                                • 317
                                I really think so too. No need to get caught up in numbers at this point, though. So long as it sounds bitchin, and embarrasses my roommate's 2017 BRZ ;D
                                Other cars:
                                1972 Porsche 914
