Hmmm... I don't see the fog light mounts on that valence like mine has. But I think you're right. I was trying to get the valence that my 323i had (but got mangled) so I suppose it makes sense it was the 84-85 valence since my 323i was an '85. My 325 is production date 03/86. You sure that the lips aren't compatible for all early valences?
2.8L M20 9.8:1 stroker build: my 323i reincarnated
'86 Burgundrot 325 2.8 stroker.
Other cars:
2000 Porsche Boxster
2006 Subaru Outback XT 5MT
1972 Porsche 914 -
The valance in that picture is just the US one, the difference b/w them is that the Euro one has cutouts for fog lights and doesn't have the cutouts for some of the diving board one. I'm pretty sure the lips aren't going to interchange nicely without some hackery. I took off the pfeba lip and put the Jimmy Hill in front of the car when I got it, it's like a quarter inch or so longer on the sides because the later valence is more squared off compared to the early one that slopes inward. The early lip with the brake ducts also follows the slope of the valance whereas the later ones stick out out kind of like how the M3 has it.
Compare the two versions here:
Early early
Late early
Final few tweaks at the body shop! Perfect
Whopedy scoop poop'86 Burgundrot 325 2.8 stroker.
Other cars:
1972 Porsche 914Comment
Just got the second valve adjustment in. Most exhaust valves actually seemed slighty loose.. it was pretty consistent. I think only one or two intake valves were out of spec. And only one exhaust in spec. Still looks really nice under the valve cover though.
Pick n pulled some parts off an E34 525i and just got around to installing. I've decided to update to the late model valve cover and finally got a late model fuel rail so my supply and return lines are on the same side. Did the same with this valve cover that I did with the previous one, though the big blocky BMW letters seem to take the sanding and polishing better than the early model one.
Up next... The smileysLast edited by betz; 05-01-2018, 09:51 PM.'86 Burgundrot 325 2.8 stroker.
Other cars:
Other cars:
Nothing wild just a replacement engine for my wifes 1983 318 which has a clacky 350,000Km b25 in it nowWe're out there in here.
Good luck! It seems my influence is spreading ;)'86 Burgundrot 325 2.8 stroker.
Other cars:
Other cars:
looks good man! Might want to throw a front plate on there just to avoid tickets if at all possible.Comment
Other cars:
