1989 325iX - Alpine Rescue
  • mjweimer
    • Dec 2015
    • 648
    Looking good! The rest of the car must be in great shape underneath if the struts were that clean. Somebody will end up with a real nice ride.
    MJ
    • e30austin
      • 15382
      Wow, that carpet piece showed up fast! Looks great. Glad I could help. AB
      • AWDBOB
        hooptie connoisseur
        • Aug 2013
        • 4463
        MJ
        Thanks, Matt! Agreed, she's going make a great daily or weekend cruiser for someone.
        I actually didn't know what it was until I opened it, as I wasn't expecting it that soon! Worked out perfectly though. Thanks again!
        • notanawdix80
          • Apr 2017
          • 111
          Looking gooooooooooood :)
          Glad to see ix's being properly fixed.
          • AWDBOB
            hooptie connoisseur
            • Aug 2013
            • 4463
            Thanks!
            I got her back together this weekend, finally. Thankfully, this should be the last time I'll have to refresh front iX axles.
            Completely disassembled, cleaned, checked for wear/replaced worn parts, paint, reassemble with GKN boots.
            This is my first time driving the car since I completed all the maintenance including a full drivetrain Redline/LiquiMoly fluid change, Bilsteins up front, KYB's out back, H&R springs, inner/out tie rods, Meyle HD endlinks, and a ton of other stuff. It drives like a dream, I can't wait to get it aligned. Front brakes had 12/32 on them, I disassembled the calipers and cleaned/greased everything and replaced the rubber grommets on the pins that always crack.
            I have a small exhaust leak in the cat section and I broke a brittle ABS sensor while disconnecting it. Just a few more small things to go! I have almost all the parts for an R134 conversion and all the parts to upgrade the throttle body vacuum fittings, so once I get time I'm going to do that stuff as well.
            Untitled by Bobbie Morrone, on Flickr
            • Mvader
              • Dec 2018
              • 16
              Wish my IX was that clean!
              Slowly and painstainkenly trying to save my 88 IX coupe. Recently I’ve been wrestling with the ABS system, finally narrowed it down to sensor issues. I’ve been scouring the forums to see if those sensors are IX specific. I’ve read through a few of your posts and you seem the filled with much knowledge, hoping you can help!
              3 of my sensors are bad. Two of them mangled while removing and one I’m going to try and repair a broken wire. My buddy has a few laying around from his IS and would love to be able to throw those in instead of buying new or searching for IX ones.
              Thanks!
              • econti
                • May 2014
                • 1143
                Thanks!
                I can't actually find iX ABS sensors on real OEM but I see no reason why they would be different to regulars in the rear, and it would make sense if the fronts were the same too
                • Mvader
                  • Dec 2018
                  • 16
                  Realoem is basically my homepage every time I log onto my computer lol I found it strange that they weren’t on there.
                  Had another post on here about my ABS issues, someone commented that the rears are interchangeable but the fronts are side and IX specific. Ended up biting the bullet and buying new ones that “fit” my car according to ECS tuning.
                  I get them in Friday so I guess we’ll see!
                  Thanks!
                  • AWDBOB
                    hooptie connoisseur
                    • Aug 2013
                    • 4463
                    The alpine rescue has moved on to a new home.
                    • jeenyus
                      • Aug 2011
                      • 2064
                      You did a great job cleaning that sucker up! Great work Bobby! Let me know when you have a spare set of IX struts housings and then save them for me for like a few years till I can get them shipped here. I kid... but really.
                      • AWDBOB
                        hooptie connoisseur
                        • Aug 2013
                        • 4463
                        Thanks, man! This was my last iX...... I am no longer AWDBOB in relation to E30s :(
                        I have a set of coilover core strut housings you could have on the cheap. You need Ground Controls!
                        • jeenyus
                          • Aug 2011
                          • 2064
                          Yea I gotta get the IX lowered to Nando status/quality
                          Sent from my Pixel 2 using Tapatalk
                          • e30RS
                            • Mar 2019
                            • 437
                            Car looks superb! Well done.
