Lets see your supension set-ups!
  • 325is_MadBimmer
    • Mar 2004
    • 654
    Ok so post a picture of your suspension setup. Also list your suspension/handling mods.
    thanks guys.
    Luke
    98 M3 with many goodies
  • Bill 84 318i
    • 1600
    Ground Control sleeves/perches with Bilstein Sports (riding on the bumpstops in the front when at full low).
    12mm sway bar in the back (came with none).
    New control arms, M3 bushings, and tie rods up front.
    Yoko AVS es100's in 225/50.
    • Beej '86 325es
      • 2639
      Ground-Control with 350 lb. (FRONT)
      ERS 2.5" ID, 6", 500 lb. spring on H&R adjuster (REAR)
      Bilstein Sport shocks
      ST 22/19mm sway bars
      Modified adjustable toe and camber rear subframe
      Reinforced trailing arms
      Urethane sway bar, control arm, and rear subframe bushings
      RD front/rear strut bars
      Schneller HD rear shock mounts
      ...probably would have been easier to just give the link to my mods:
      -Brandon
      '86 325es S50
      '12 VW GTI Autobahn DSG
      '03 540i M-Sport (sold)
      '08 Jeep SRT-8 (sold)
      For sale:
      S50 TMS chip for Schricks
      • rs4pro3
        • 5808
        85 318i
        Spax 60mm springs
        12mm rear sway bar
        88 325is
        Bilstein M-tech shocks
        Racing dynamic springs
        21mm cabrio front bar
        M3 front end link and Ground control mounting tabs on the strut housings
        Erik Lucas Rear strut bar
        Unknown front strut bar
        205/50/r16 tires
        I'm working right now on installing the bilsteins on the car so the ride height shot is from before. The ride height should be the same after except for I pulled the front spring pads but they were completly shot and almost paper thin.
        Comparo shot
        I'll change the picture next week once the bilsteins are on.
        85 325e 2.7 ITB'd stroker
        • modifiede30
          • 1208
          Ground control coilover setup with 350/450 Eibach springs
          Koni adjustables front and rear
          Aluminum rear shock mounts with urethane bushings
          Offset urethane control arm bushings
          Adjustable camber plates
          Eibach front strut bar
          M3 rear sway bar
          Stock bar up front with adjustable links
          15" wrapped in Falken Azenis tires
          Driving is the only way to go faster....
          • Ryan Stewart
            I Love Miatas
            • 8978
            Racing Dynamics Blue, sways and all. Good luck finding it.
            At Rest.:
            Im now E30less.
            • M3 Ryan
              Site Sponsor
              • 2298
              Bilstein Sports
              RD Sways
              Suspension Tech Springs
              Urathane Bushings
              Aluminum Control Arms
              Offset front camber bushings
              Offset front crash mountsM-Coupe Diff Cover (stiffer busihing)
              Urathane Eccentric trailing arm mounts for camber/toe
              Urathane subframe bushings
              Urathane swaybar mounts
              Adjustable sway bar links
              Rolled Fenders to clear tires
              245/35/ZR17 Goodyear Eagle F1 Tires
              '88 M3.2 S54 Lachssilber/Black
              '07 335i Alpine/Black Sedan
              '12 X5 3.5i Alpine/Black
              iS Splitters For Sale, PM ME!
              • OOMPH!
                • 3487
                Not the best pic, but I have GCs (they're all the way in the pic) and Koni Adjustables. Also have a Sparco Strut tower bar.
                • Digitalwave
                  is a poseur
                  • 6299
                  AP Sporttuning 60mm front/40mm rear drop springs
                  AC Schnitzer-revalved Bilstein Sport front shocks
                  AP Sporttuning rear gas shocks
                  E36 cabrio rear shock mounts
                  brand new factory front strut mounts
                  removed spring pads all around
                  LUKAS rear strut bar
                  RISING EDGE
                  • BMW BMXER
                    • 2325
                    Eibach Springs (dunno which ones)
                    Bilstien Sports
                    The end.
                    Sold it.
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      Factory 1984 318i set-up:
                      :nice:
                      Originally posted by Gruelius
                      • Bryson
                        • 1490
                        ground controls 375 front/ 475 rear
                        bilstein sports :? konis in a couple weeks
                        racing dynamics sway bars w/ urethane bushings (isn't it standard)
                        urethane rear subframe bushings
                        e36 RSMs
                        somebody want to find a picture from the side of my car?
                        • e9nine
                          • 1890
                          GCs
                          Koni SAs
                          15" wheels & tires...(tires so smooth they're not roadworthy)
                            • 34847
                            I'll get pics tomorrow (haven't taken any new ones in ages, and my car is really dirty!), but here's my current setup:
                            H&R sport springs (no pads)
                            Koni adjustables
                            M3 offset CA bushings
                            polyurethane subframe, trailing arm, and differential bushings.
                            E46 M3 convertible RSMs
                            Eric lukcas rear brace
                            Weichers Sport front strut brace
                            all with bottlecaps and yokohama ES 100's in 205/60-14, soon to be demoted to winter wheels by a set of 15" BBS :)
                            • kansas-ix
                              • Jan 2004
                              • 1600
                              nando; they make a strut brace for the ix I had no idea, where did you get it from?
                              E30 325ix 62k
