Drop it like it's hot (lowered my car)
  • DarkWing6
    • Apr 2004
    • 7144
    Looks great. I hope to see it in person soon, seeing that I'm moving right down by you tomorrow. We gotta meet up.
    • hamann318is
      • 3382
      How much of an extra drop does loosing spring pads give you?
      The BMW 318 is back. With a vengeance.
      • m42technic
        • 1056
        Maybe 1/4". Almost negligible.
        James Peacock
        WWFSMD?
        • Digitalwave
          is a poseur
          • 6299
          James, it depends on the car, my rear ones were closer to 1/2".
          RISING EDGE
            • 34844
            what size tires are those? that's still quite a bit of fender gap.. of course it still looks great, the weaves are a ton better than the bottlecaps :)
            • m42technic
              • 1056
              True. My 318is came with super thin pads so it didnt really do much. What kinda spring pads does the '84 318i come with? You could at least swap out for some thinner ones.
              James Peacock
              WWFSMD?
              • modifiede30
                • 1208
                Which picture is the one with it lowered?
                Driving is the only way to go faster....
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  They're 195s. It's hard to make an early 318 look slammed on stock sized tires (save for coilovers) due to the low weight of the car in the front and rear.
                  Originally posted by Gruelius
                  • kencopperwheat
                    King of Kegstands
                    • 14396
                    The pads on the top are about .5" thick and the bottom ones are really thin.
                    • mikeedler
                      • 6707
                      Its not hard at all to make an early M10 E30 low, all you have to do is buy the correct springs! looks better though. and new shocks on a E30 will not make it higher if you have real struts (bilstein)
                      • Digitalwave
                        is a poseur
                        • 6299
                        He has blown stock shocks which are causing the car to sag a lot. Trust me, when he installs Bilstein Sports it will raise the car a bit.
                        RISING EDGE
                        • kencopperwheat
                          King of Kegstands
                          • 14396
                          They're 60mm springs. They'll drop a 325 about 2.5" or so. It only dropped mine around 2".
                          Which springs should I have gotten?
                          • hamann318is
                            • 3382
                            I think the IE stage 3 would only lower it about the same. We're just stuck without coilovers.
                            • kencopperwheat
                              King of Kegstands
                              • 14396
                              According to IEs website, the stage 3 will drop an e30 (presumably a 325) 2" in the front and 1.5" in the rear. Which would probably translate to 1.5 fron and 1 rear for my 318.
                              • ///M Powered
                                • Jan 2004
                                • 1109
                                I had blown shocks all around as well, but it only seemed to raise the rear a tad with the bilsteins. ( makes for a nice mini rake I guess )
