Something Something Tony G's E30 Sedan (we're using a coupe now) - S54 Swap
  • Panici
    • Dec 2009
    • 2553
    #76
    Originally posted by spike68
    Well....If you thought this thread was getting derailed YOU AIN'T SEEN NOTHING YET.
    It's to put the s54 in the race coupe.
    Racecar looks the part that's for sure!
    • 2mAn
      Señior Mod
      • 20991
      #77
      I like the chaos... yes... yes I do
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • spike68
        • Apr 2009
        • 1185
        #78
        Only downside to the car is the cage. I found out that it's only bolted in which seems so silly to me. The front half is most likely coming out since the front bars are poorly routed in front of the dash and the door bars don't seems as needed since the doors aren't gutted or anything. It looks like the rear half was a purchased as a kit and the front half was added later, probably to meet some kind of regulation on the track. I'll rework the rear half to be welded in. I'm going to have to look up how to properly box in the connection points so they're structurally sound. Might as well take a shot at fabrication skills.
        The floors aren't in great shape either. The drive side was modified to lower the seat mounting position for the previous owner. He's a tall guy.
        IMG_3157 by Tony Gomez, on Flickr
        As for the passenger side it just had some general bars added and drilled huge bolts through the bottom of the car. At some point one of the bolts caught the ground and crumpled the floor some. I'll just massage that side out, but some weird shit was done to get seats in this car.
        In terms of everything else I've evaluated, the chassis harness was definitely modified in a few ways. Looks like theres an aftermarket ignition system that was for the m20. It was also rewired to not need a key to start the car. i'll probably undo that so I'll be keeping an eye out for a keyset (car didn't have keys).
        I don't even own this car anymore, but I'm too lazy to change the picture.
        • Panici
          • Dec 2009
          • 2553
          #79
          If you haven't seen it yet, Chilezen has a great thread on cage work:
          • Chilezen
            I weld cats
            • Dec 2013
            • 1941
            #80
            Coincidentally I've also done rust repair, for another forum member here. I salute you on your brave attempts! It's not hard, just annoying lol. Absolutely get a proper mask so you don't breathe in fumes.
            Currently building a badass coffee table
            Random stuff on insta @kevanromero
            • spike68
              • Apr 2009
              • 1185
              #81
              Originally posted by Panici
              Wow I didn't see this. This gives me what I need.
              Chilezen I spent quite a bit of time looking at your welding porn. Love your work!
              • spike68
                • Apr 2009
                • 1185
                #82
                I'm back! Here to provide an update since not much has moved since I purchased the race car back in May.
                The summary of the waiting was that I had an issue with main bearings for the build. It was a mixup and some issues with ordering that took some time, but on top of that I procrastinated some. Tbh this whole engine building process has seemed intimidating, but I'm happy to report that S54 reassembly has started!
                IMG_4538 by Tony Gomez, on Flickr
                IMG_4619 by Tony Gomez, on Flickr
                IMG_4272 (1) by Tony Gomez, on Flickr
                IMG_4620 by Tony Gomez, on Flickr
                • spike68
                  • Apr 2009
                  • 1185
                  #83
                  More recently I've been working on rebuilding the head. I decided to replace the valve stem seals and doing a valve a port clean while I was at it. I invested into a ultrasonic parts cleaner and it's been great. It's nice to be able to set some parts in and just walk away for a while and really gave me a head start on the valve cleaning.
                  However while cleaning the exhaust valves I noticed some pitting. I could easily get these fixed, but fuck it. Lets ball out and buy some supertech valves.
                  IMG_4807 by Tony Gomez, on Flickr
                  Here is the second part of all of this. While cleaning the exhaust ports I noticed this
                  IMG_4816 by Tony Gomez, on Flickr
                  That is indeed chipping in the port. I'm assuming that when this motor let go it may have thrown some small pieces of piston and caused this damage. Right now I'm leaning towards this isn't an issue because this isn't on the valve seat, but right above. If anything it could effect airflow, but probably isn't noticeable. This occurs on both exhaust ports of at least two cylinders.
                  You guys have any thoughts on this?
                  EDIT: I'm wrong. It's not chipping. It's just stubborn carbon buildup. I think this is just a sign that no matter how deep I go into car shit that I still have no idea what I'm doing. Just learning along the way.
                  • Panici
                    • Dec 2009
                    • 2553
                    #84
                    You said it before I could, carbon buildup.
                    And those are true words.
                    There is always another area to learn or new challenge that comes along.
                    As for me, all I know is that I know nothing.
                    -Socrates
                    • spike68
                      • Apr 2009
                      • 1185
                      #85
                      Heres another update. Been slowly chipping away at things and just haven't been doing a good job at recording things. I think I just get lazy with the extra stuff or I think it's not interesting enough.
                      So for the most part the engine is all back together. Didn't really run into any hiccups aside from doing the valve adjustment. Cams are now almost out of tolerance than the size shims you can get in a shim kit. I know before the head was rebuilt it was well within tolerance and the only thing thats changed since then is the valves. Either way I'm rolling with it for now.
                      IMG_5140 by Tony Gomez, on Flickr
                      I've also been getting some supporting parts in like this RHD flywheel. It was cheapest and the lightest. Could be a bad recipe, but we're just gonna send it.
                      IMG_5256 by Tony Gomez, on Flickr
                      On top of engine stuff I finally felt like it was a good point to start tearing into the car to prep for engine insertion. Got the m52 pulled out of it and parked it on a stand. Took a couple hours to get out. there wasn't anything connecting it to the car so it was simple. Just unbolted the trans and motor mounts and out it came.
                      IMG_5156 by Tony Gomez, on Flickr
                      I decided while I waited on some parts I would go ahead and just repaint the engine bay because why not try to make it look a little cleaner?
                      IMG_6026 by Tony Gomez, on Flickr
                      IMG_6027 by Tony Gomez, on Flickr
                      Not bad for a rattle can paint job. The only thing I'm a little disappointed about is that the paint I used seems to still be tacky after almost a week. I'm going to try some solutions I read online, but if it stays that way I may sand it down again and try another paint. A little disappointed, but ehh I've got time while I wait on parts from Garagistic for brakes.
                      Before the engine goes in I'm actually plumbing my own brake lines so I've been collecting supplies and tools to do that. It wont be anything complicated, but the previous owner had their own after removing the ABS module and just looked like trash. Since I'm going with a Willwood pedal box I figured this would be a good opportunity to learn a new skill.
                      Thats all for now.
                      • Panici
                        • Dec 2009
                        • 2553
                        #86
                        You're going to love that RHD flywheel.
                        Can be more challenging to drive (depending on your clutch & slave choice).
                        But the rev-match downshifts and blips are glorious.
