E30 325I turbo stroke
  • Barzakov
    • Oct 2023
    • 17
    Hi, this is my project. The car is 320 m20b20 stroke of 2.5. I have used a crankshaft from m21 and pistons from vag 1.8t 81x81, arp studs, metal head gasket, tds gearbox and differential 2.65 188. The turbo is holset hx35 at 1.2 bar.I use 50mm wastegate, an electric throttle valve from м54б30 and megasquirt 3. The head is 731 with dibilas spings. Intake from m20b25
  • Barzakov
    • Oct 2023
    • 17
    • Barzakov
      • Oct 2023
      • 17
      • Barzakov
        • Oct 2023
        • 17
        • Barzakov
          • Oct 2023
          • 17
          • Barzakov
            • Oct 2023
            • 17
            • Barzakov
              • Oct 2023
              • 17
              • Barzakov
                • Oct 2023
                • 17
                • It's Soda Not Pop
                  • Jan 2022
                  • 877
                  I've never seen anyone use a drive by wire throttle body on a M20. Nice build.
                  88' Seta 2.7i Zinno
                  https://www.r3vlimited.com/board/for...430-my-88-seta
                  • Barzakov
                    • Oct 2023
                    • 17
                    I wanted to avoid the old stepper motor
                    • 82eye
                      • Jan 2009
                      • 2095
                      you didn't use the old style stamped gear for the oil pump did you ? those can shear destroying your engine. the new gears are sintered like the cam gear.
Name:	images?q=tbn:ANd9GcRemg8z3CaiuC3G5xXOmSPRCPjr9pgGm-ZAW73fil1c4Mosv4qVNiWQRYrKhmzaNfACi-4&usqp=CAU.jpg
                      • Panici
                        • Dec 2009
                        • 2543
                        Can't say I've seen that specific combination of engine parts before!
                        Do you have any sounds clips?
                        Also, I suggest running an air filter to protect the engine you've worked so hard to rebuilt. BMS makes some silicone low-profile filters that are designed to mount right on a turbo.
                        • Barzakov
                          • Oct 2023
                          • 17
                          I have an air filter installed but I haven't pic
                          short clip
                          • Barzakov
                            • Oct 2023
                            • 17
                            Do u have a part number for the new one
                            • Barzakov
                              • Oct 2023
                              • 17
                              We cut the face of block 3mm to feet this pistons.
                              The car has become very pleasant to drive and in low revs it feels very good. This summer i did 8k km as a daily car
