Blue sedan I didn’t learnt the 1st go around
  • prisonerofdoom83
    • May 2013
    • 529
    So finally got the AC to work . The blend doors were stuck . Moved them manually and cosconnected the actuators . Blowing sub 50 degrees . Finally washed it and took it to the gas station for a drive . The filler neck leaks now . Also I think the premium amp went out . So I can finally put insurance on it and start to drive it around . Runs very solid
    • zwill23
      • Jul 2015
      • 615
      Interior looking very plush. Did you go with an AC retrofit or redo the stock system? 50 deg is great, that's colder vent temps than any E30 I've ever sat in on a hot summer day.
      • prisonerofdoom83
        • May 2013
        • 529
        Only 2 people have really seen the car in person and love the interior . I’m very happy with it . So when I got the car the complete AC was removed . So yeah I did a full conversion kit half AC solutions half LCWylie . Worked out well once it was sorted . It was about 90 degrees when I was getting 50 . I’ve read that a 35 degree difference between t vent and outside temp is a orettt efficient system especially on an old car . It cools better than my other r12 e30
        • zwill23
          • Jul 2015
          • 615
          That's really impressive, I have the same kit on mine actually but I have a turbo sitting right next to the low pressure AC line and I think it's killing the performance from high ambient temps. I might see mid 60s at the vent on a 90 deg day. Yours sounds lovely!
          • prisonerofdoom83
            • May 2013
            • 529
            Window tint 35 all around and 50 on the windshield . A bit more maintenance is on hand . Valve cover gasket refresh injectors a couple vent and vacuum hoses fuel filter . Then I will get into putting on the cow catcher getting brackets lights and getting it painted
            • prisonerofdoom83
              • May 2013
              • 529
              Momo mod 07 wood grain wheel with leather horn button . I like how it looks with the interior . I sprung a power steering leak so I’ll have that as a weekend project .
              • 2mAn
                Señior Mod
                • 21075
                Cars looking great! Any plans for suspension? Mtech 1 kit to join the Mtech 2 car?
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • prisonerofdoom83
                  • May 2013
                  • 529
                  this is the car that replaced the bmw i3 . It’s supposed to be a chill grandpa car . Automatic not lowered easy to drive . While it’s supposed to stay stock we shall see . I like the simplicity I do have a cow catcher for it I need mounting brackets and paint . Hopefully that’s the last big purchase . Then maintenance and keep it tidy
                  • AWDBOB
                    hooptie connoisseur
                    • Aug 2013
                    • 4515
                    looks like the odometer is working ;)
                    • prisonerofdoom83
                      • May 2013
                      • 529
                      The end of the saga . It ended up being faulty gears #bestclusterbuilderintheworld
                      • prisonerofdoom83
                        • May 2013
                        • 529
                        Well when they did the door panels they used a much thicker foam . So the original interior door trims wouldn’t work then I broke an interior door handle so while pricey and a bit over built . Billet aluminum anodized black Leo grande door handles . I got all 4 here’s passenger front .
                        • prisonerofdoom83
                          • May 2013
                          • 529
                          Well not much lately . Just fixing leaks into the cabin it was the windshield seal and elephant trunk . Right now doing the trans service and replacing the trans cooler lines . Send out my cow catcher and mirrors to be painted thats the next project . Also front end suspension refresh control arms bushings tie rods etc . Car runs great do 200 mile round trips about 2 times a month
                          • prisonerofdoom83
                            • May 2013
                            • 529
                            Front end “refresh” getting a clunk on the right front so control arms bushings sway bar links and tie rods . The cow catcher is finally at the painter . Will have a nice appearance upgrade all the way around next time I update
                            • 2mAn
                              Señior Mod
                              • 21075
                              Cant wait to see how it looks with the cowcatcher
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              • prisonerofdoom83
                                • May 2013
                                • 529
                                I am ever so patient I dropped off parts 2 months ago . Cow catcher should be done this weekend . Mirrors and wing done in bough
