Yes man! Finally you installed the suspension. I bet it is nice having a car that handles like BMW and not a mid 1990's S500 now. hah.
Strict budget, slow restoration. *Now with moar budget*
Cars sittin nice man.
John F. Kennedy
how much was it to get it aligned... you notice a difference?Last edited by fiftytakedowns; 04-28-2010, 09:49 PM.
[/url]
Team USA Wrestling 67KG
Team USA Wrestling Strength And Conditioning CoachComment
Nice work.
I like those Vasek Polak plate frames!
88 M3 - 95 E320 Wagon - 70 Mini - 04 LS430
BBS RS-style wheels for your RC car:
http://www.teampogi.com
http://www.facebook.com/teampogi
Eh, too much. I posted my alignment experience in a local forum:
Before specs were actually pretty similar to after specs, but there was a bunch of toe-in. Turn in is much better now and I don't have to worry about tire wear as much. I was happy with the result, but I got ripped off by these jokers. Not going back.So I go into superior alignment and ask for an alignment and tell him I want it to a certain spec.
Here's the alignment I want--caster: max out the right, .3 degrees less caster on the left. -2 degrees camber, zero toe. I went here a year or so ago with my old car and they did a thrust angle alignment for $50, so I went again.
I tell him what I want and he says ok so you want the caster all the way forward on the right?
"Uh no, all the way back."
"Oh ok."
Then he gives me the work order: $100
I say a year ago it was half that. "Well you asked for custom specs so it will take longer than a factory alignment"
"but if it takes less time then we won't charge you as much" Okay, fair enough.
But then I go over the work order and it says LEAST amount of caster and +.3 degrees on the right. I tell him no, I want the MOST caster.
"So you want us to push the wheels forward"
"NO that is subtracting caster... I shelled out extra for camber/caster plates, I want the MOST positive caster you can get."
"Oh well in some cars when you push the camber plate forward it pushes the wheels back"
"No, it's a macpherson strut, they don't work like that.. you know what, forget it, I've already got the caster maxed out, just leave it"
"No no we'll do it"
if I'm going to shell out $100 for a 2-wheel alignment can I at least get someone who knows what caster is? jesus.
Haha, I've seen them on SO many E30s, it's ridiculous.Last edited by Wh33lhop; 04-28-2010, 11:06 PM.paint sucksComment
how much is just normal alignment cost usually I jsut did the suspension on my whip and think I should probably take it in.
[/url]
