I kinda doubt titanium valves and springs (only really good for top fuel dragsters where they rebuild the engine every night). maybe rods. but now i'm curious.
sure, but you don't need titanium valve springs to rev an M20.. most of it probably came from efficient boost, and lots of it, headwork (including a very aggressive cam) and tuning. I'd think the bottom end would be the more expensive part.
and somebody did. Like I said, because you can, not because you should. If we all thought like that none of us would have E30s. :p
I'd be amazed if it weren't titanium. It's not for the durability of it, but for the weight. The stuff's super light AND super bulletproof. With the rpm that motor's likely to see, and the speed at which it likely spools you'd need to reduce as much valvetrain weight as possible. Bottom ends are pretty simple to build to reliability. You get beefy rods and mic everything to make sure it's in spec. Forged everything... assemble and done. As long as everything's in decent order you should be ok. All the tough stuff is in the head. I'd wager the real cost in the ppf m20 would be in the valve hardware, with port work a close second. They've probably got oversized titanium valves in there.
Shitbag should call up and see if they want him to make needle bearing rockers though.
needle bearings on the rocker shaft have been done.. but there's no point to that. it needs roller tips on the valve and came lobes. But it requires a special cam developed just for it. They were actually going to do full roller rockers but decided it wasn't worth it.
Please tell me Mr. Laffs hasn't infected you with whatever the fuck he has that kills all humor. You DO realize I was 100% kidding in that post, right?
lol, well I figured this worthless thread may as well have some real discussion in it. :p
