M42 Turbo Build (Semi Budget, keepng AC!) No 56k
  • xwill112x
    • Jan 2009
    • 4236
    #61
    we keep waiting because turbo m42s are badass. lol
    • Schnitzer318is
      • Jan 2008
      • 2057
      #62
      LOL sorry guys, been enjoying the car a bunch now... got over 4000 on it since turbo went in, but have been holding off on vids. Reason being is I have a dyno coming mid december and just got some new parts to put in for more boost! :)
      Got 46lb injectors and boost controller parts for MS going in which will allow me to reliably run 12psi! I am upping my rwhp estimate to 215. LOL though I'm not holding out much hope for longevity of the head gasket. :)
      "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
      91 318is Turbo Sold
      87 325 Daily driver Sold
      06 4.8is X5
      06 Mtec X3
      05 4.4i X5 Sold
      92 325ic Sold & Re-purchased
      90 325i Sold
      97 328is Sold
      01 323ci Sold
      92 325i Sold
      83 528e Totaled
      98 328i Sold
      93 325i Sold
      • BUDNUNTA
        • Apr 2005
        • 996
        #63
        O yeah
        This things sick.
        Are you going to use one of those GM Solenoids for boost control?
        With 46lb injectors im thinking the m42 is possible of 250whp or more with a stock bottom end.
        The e36 guys are doing it.
        .140MLS and APR2000 Head studs and crank that boost.
        I wonder how long the baby diff will last?
        Hunter
        We're out there in here.
        • e30guydownunder
          • Jul 2008
          • 874
          #64
          sounds good mate, keep at it. I have some 1000cc injectors in the mail :D E85 and 18psi boost here i come
          - Chris
          Project M42 - 255 @ 19 psi
          • Schnitzer318is
            • Jan 2008
            • 2057
            #65
            Originally posted by BUDNUNTA
            O yeah
            This things sick.
            Hunter
            Yes, GM solenoid controlled by MS. I plan on running 12psi up to 4500rpm and then dropping to 10psi higher up to ease the strain on the head gasket. But if it does go, then you are right... new stock gasket, oringing, and arp studs = upping to 15psi all the way through the rev range.
            E85 sounds interesting. I have to do more reading on it as it seems to be the better fuel for boost. Though honestly this is a daily so I should keep it on the conservative side.
            91 318is Turbo Sold
            06 4.8is X5
            06 Mtec X3
            05 4.4i X5 Sold
            90 325i Sold
            97 328is Sold
            01 323ci Sold
            92 325i Sold
            83 528e Totaled
            98 328i Sold
            93 325i Sold
            • e30guydownunder
              • Jul 2008
              • 874
              #66
              E85 really is the shit for off the wall N/A builds (>14:1 CR) or high CR boosted builds.
              It has cooling properties similar to methanol, high detonation threshold. Generally promoting more CR, more boost and somewhat of a misconception more ignition advance (this is entirely dependant on the actual engine and how it works as a system).
              I'm going O-rings and bigger bolts straight out of the box, basically counting on winding my turbo out. I'm really keen for you to get to a dyno so we can see how you go with pump fuel!
              - Chris
              • SamE30e
                • Sep 2007
                • 4319
                #67
                O-ring... blow head gasket, top end or bottom end? Hmmm
                1985 325e 2.8 Turbo VEMS
                • pbr87
                  • May 2008
                  • 853
                  #68
                  nice build!
                  Originally posted by accident
                  I have achieved the title of Douche of the month.
                  Discuss.
                  Originally posted by kronus
                  It was probably pissed off because it didn't want to pay taxes for poor people's healthcare.
                  1990 300ZX TT 5spd ($6,000)
                  1991 318i 4dr 5spd (DD)
                  • e30guydownunder
                    • Jul 2008
                    • 874
                    #69
                    For an engine that owes me $500 plus the expense of a headgasket, bolts and o-rings.... WHO CARES :p
                    - Chris
                    • BUDNUNTA
                      • Apr 2005
                      • 996
                      #70
                      Im leaning towards the .140MLS over the o-ring
                      It slightly lowers the CR but are more prone to leak.
                      I think with the right RA On the mating surfaces and a nice flat block and head it wont leak
                      E36 people have ran 26psi with the MLS
                      Thankfully there are a bunch more m42turbos around
                      R&D
                      Hunter
                      • Iain
                        • Oct 2005
                        • 2815
                        #71
                        I always shoot for more timing than boost, particularly with E85.
                        Cooler EGTs FTW LOLWTFBBQ.
                        Pork Hunt Motorsport
                        eBay is like the summit racing catalog for today's special Olympics crowd
                        • Schnitzer318is
                          • Jan 2008
                          • 2057
                          #72
                          Update: 12/09/09
                          1. Got the 42.8lb/hr @ 3 bar injectors installed.
                          2. Rerouted some lines for better aesthetics
                          3. Oil change (switched to 15w50 as turbo was thinning the 5w20 too much)
                          4. Working on tuning for the bigger injectors now so I don't drown my plugs on first start.
                          Pics will come tomorrow and will work on getting the boost control and efan temp control circuits installed, all controlled by MS.
                          91 318is Turbo Sold
                          06 4.8is X5
                          06 Mtec X3
                          05 4.4i X5 Sold
                          90 325i Sold
                          97 328is Sold
                          01 323ci Sold
                          92 325i Sold
                          83 528e Totaled
                          98 328i Sold
                          93 325i Sold
                          • Schnitzer318is
                            • Jan 2008
                            • 2057
                            #73
                            Update: 01/02
                            Had been working on adding a boost control circuit to my megasquirt, but because it is a PnP unit built into the motronic box... I guess something else is using that input/output and causing a conflict. Since I couldn't get that to work I just threw a manual boost controller in. I now have a solid 10.5psi all the way to redline.
                            Also threw a new set of NGK spark plugs. Went with 1 degree colder plugs. Feels like it added a small amount of torque before boost, but that is probably just placebo.
                            I didn't realize it... because I've never felt this before, but my clutch can't handle all the torque after the turbo install. It has been slipping in 4th and 5th on the highway for quite some time and now that I have 10.5psi consistently I can't even gun it on the highway anymore.
                            So, my next course of action is a spec stage 2 clutch kit... good for 270tq which should be plenty.
                            With my new boost level I am estimating 215rwhp but I won't throw it on a dyno until I get a new clutch.
                            Will keep updating if anyone is still interested. I know everyone wants vids, but I'm trying to get everything ironed out so I can get some GOOD vids.
                            91 318is Turbo Sold
                            06 4.8is X5
                            06 Mtec X3
                            05 4.4i X5 Sold
                            90 325i Sold
                            97 328is Sold
                            01 323ci Sold
                            92 325i Sold
                            83 528e Totaled
                            98 328i Sold
                            93 325i Sold
                            • White325is
                              • Oct 2006
                              • 5947
                              #74
                              What flywheel are you running now?
                              Ever think of getting a LWFW?
                              • iamsam
                                • Jun 2008
                                • 174
                                #75
                                wee need LOTS of pics and vids man!!!
