Got bit by the turbo bug.
  • einstein57
    • Jun 2007
    • 10780
    #46
    Originally posted by TCD
    Why didn't you call me? You bought it used from Will. It was a quicky cobbled together build that I did for my vert. Will new the score when I sold it to him. I fabricated the parts and obviously my welding skills are limited.
    I don't fabricate our kits. They are done professionally and had you really decided to go big and buy new parts from me you would have received high quality parts.
    Bitching on the internet while never voicing concerns to the person or company that you are upset with is LAME and childish.
    So what you actually bought was a TCD manifold, rebuilt vintage 80s T04b turbo with new 60 trim compressor wheel and a downpipe cobbled together by yours truly.
    Again, you didn't buy these parts from TCD! You bought them second hand from Will.
    I did not mean to imply that i bought it directly from you or your company. I thought I was clear about that. I have been having trouble with my post going through on R3V from my droid for some reason. I was never upset with TCD and am a fan of your porducts. If you want I'll edit my post and have responses deleted.
    Originally posted by einstein57
    I don't know what the back story as i bought it off someone else. For all I know its a TCD knock off.
    I bought it "used" even thought it appears to have never been used. I'd hit up TCD about it but I have no way of confirming this is his actual product.
    so the story is todd welded this up himself for his own car and he does not know how to weld. It was never intended to be sold as a TCD product.
    For all I know the person I bought it from received it for free from todd cause they bought some of his personal stash. Does not seem like i have any right to ask him to fix or replace it.
    www.gecoils.com
    • ieatmango
      • Jul 2010
      • 67
      #47
      I was wondering how you feel about papaya?
      depends on my mood and the gravity of the situation. if you look at my car in an untoward way you begget papaya, if it's a light beating required situation never forget kiwi or red peppers
      • ieatmango
        • Jul 2010
        • 67
        #48
        children always require oranges, evil children get lemons or limes, and drunks get bananas
        • Aptyp
          • 6584
          #49
          So today i got my TCD schtuff. I was happy and disappointed at the same time. Being TCD i expected great quality. What i got was something that looked like it was take your kid to work day and they let some 10 year old weld it together. Perhaps it was a second quality rejected part that someone took and sold anyway. I don't know what the back story as i bought it off someone else. For all I know its a TCD knock off. Spent a couple hours grinding off ceramic coating and re welding everything. I suck at welding but i did a better job.
          think i had the feed to high
          that is not TCD... everything I saw there today looked spectacular with perfect welds. I drooled the entire time at the skills.
          • ieatmango
            • Jul 2010
            • 67
            #50
            that quote beggets a sack of pineapples no less than 4
            • einstein57
              • Jun 2007
              • 10780
              #51
              Fact! I've already stated that. If steve jobs put a bunch of parts together and made a computer it would not be an apple computer. Just a computer that happened to be made by an apple employee. I would not expect a warranty for that computer either.
              www.gecoils.com
              • reelizmpro
                • 9554
                #52
                So it's not "TCD"...it's just "T" Pretty sad welds right there. I would have stopped and let a pro finish it. Oh well...this is unfortunate but nothing that can't be cleaned up.
                88 M3 - LACHSSILBER
                89 M3 - ALPINEWEISS II
                • einstein57
                  • Jun 2007
                  • 10780
                  #53
                  Started wrapping up my boost gauge pod. This started as 2 pieces, then became 3 pieces, and now back to 1 piece. Need to decide on whether to do it textured or wrinkle. I think i'll do it texture coat and change it if i don't like it.
                  www.gecoils.com
                  • einstein57
                    • Jun 2007
                    • 10780
                    #54
                    Wrapped up the LC-1 install today. I ended up chasing down the 02 sensor wire inside the main harness so that i would not have any extra wires hanging out of the MS module. I mounted the LC-1 on top of the battery tray and pushed all the wiring through all the little nipples on the harness gromet. Very clean but a huge pain to figure out how to get those jacks through a 2mm whole. I mounted everything in the glovebox for now. May hang a pod from the ecu cover in the future. I figure the only time i'll be looking at the AFR is when i'm tunning anyway. Durin some down time i also gutted my GM coils of their inner electronics.
                    I also mounted the gauge pod which was a nightmare in itself. I had to figure out how to install it w/o taking out the dash. Ended up removing the clip from the steering column and sliding the whole damn out. I'm in the process of tinting the white LEDs inside the boost gauge red.
                    www.gecoils.com
                    • einstein57
                      • Jun 2007
                      • 10780
                      #55
                      Got kind of a late start today. I did not manage to get much done other then the tear down. One of the manifold down pipe studs was fubar'd and took me an hour messing with it before it decided to snap off. Here are some of the parts that came in today.
                      www.gecoils.com
                      • einstein57
                        • Jun 2007
                        • 10780
                        #56
                        My aluminum welding skills are improving. Not bad for a spool gun.
                        All mounted up
                        Partly covered up. Took way longer then it should have to trim the valance. Thats the price of keeping A/C.
                        www.gecoils.com
                        • castros
                          • 828
                          #57
                          We want more man, when am I gonna get a ride in this beast.
                          www.CASTROMOTORSPORT.com
                          Castro Motorsport
                          12600 Sherman Way, Unit C
                          North Hollywood, CA 91605
                          818-765-3606
                          Follow Castro's on Facebook:
                          http://www.facebook.com/pages/Castro...02411516506828
                          Follow Castro's on Instagram:
                          http://instagram.com/castromotorsport#
                          • einstein57
                            • Jun 2007
                            • 10780
                            #58
                            Imma do you like your brother did me "Maybe next time" for like 6 months. Lol. Post up the pics of your oil cooler.
                            www.gecoils.com
                            • einstein57
                              • Jun 2007
                              • 10780
                              #59
                              Finished mocking up the plumbing from the turbo to the intercooler. I re-did it a couple of times. I'm not happy with the setup but it will have to do for now. Ran in to a few snags with the intake side. What i thought would be a one day job turned in to a 3 day future headache.
                              www.gecoils.com
                              • Dj Buttchug
                                • Jun 2010
                                • 7684
                                #60
                                interesting cooler setup
                                Turbo M42 Build Thread :Here
                                Ig:ryno_pzk
                                I like the tuna here.
                                Originally posted by lambo
