Budget M42 turbo build
  • BUDNUNTA
    • Apr 2005
    • 996
    #136
    pics?
    We're out there in here.
    • e304me
      • Feb 2006
      • 1374
      #137
      Oh man seems like my vacuum is pretty low:sad:
      • Schnitzer318is
        • Jan 2008
        • 2057
        #138
        I'm only at ~15hg on my gauge at warm idle. I idle at 1050-1100 though. Idles just fine for me though where it's at so I'm not worried about changing it.
        What RPM do you have your idle at? Are you running an ICV?
        "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
        91 318is Turbo Sold
        87 325 Daily driver Sold
        06 4.8is X5
        06 Mtec X3
        05 4.4i X5 Sold
        92 325ic Sold & Re-purchased
        90 325i Sold
        97 328is Sold
        01 323ci Sold
        92 325i Sold
        83 528e Totaled
        98 328i Sold
        93 325i Sold
        • e304me
          • Feb 2006
          • 1374
          #139
          I idle around 900 or 1000 with the stock computer and ICV.
          So I got the knocklite hooked up and it seems alright. It doesnt seem very good at detecting light load knocks but I was getting the slight knock light at around redline. I thought it was just too sensitive but I tried dialing some timing back and it went away. Now I only have 8 degrees of timing near redline! damn DASC
          • TooTall90
            • 338
            #140
            updates? pics?
            Strategic Alpine Command:...sig loading
            • e304me
              • Feb 2006
              • 1374
              #141
              Yeah whats going on with this thing
              • Dj Buttchug
                • Jun 2010
                • 7686
                #142
                shit by the time we get an update my turbo m42 will be done haha
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • gearheadE30
                  • Jun 2007
                  • 3734
                  #143
                  haha sorry guys. It's all done and running and such, just gotta hunt down bugs and finalize some bits here and there (i.e. the piping situation). I just moved to college as of the 17th and the car is still back home, but it'll be up here in a few weeks so I can continue working on it. Gotta get some stuff done now, but I'll probly post an update in a half hour or something.
                  Project M42 Turbo
                  • gearheadE30
                    • Jun 2007
                    • 3734
                    #144
                    Okay, pics:
                    As you can see, the WG piping is very, very temporary. That is supposedly being taken care of right now. The wastegate is circulated back into the exhaust, which, until I save up some more money, is 2.5" to the end of the center section and 2.25" from there to the back.
                    I did have one rather scary moment due to too much oil in the pan, which caused crank splash bad enough for oil to get into the #1 cylinder. I thought I had a blown HG and towed it home, but eventually discovered the problem. I have an oil catch can hooked up to both the the PCV valve and the turbo drain to prevent hydrolock in the pipe, and the can is filling up rather rapidly, so I need to figure out what to do with that turbo drain...
                    The turbo also has a tiny bit of oil blow-by into the intake, but it is really minimal. I'll just keep an eye on it to make sure it doesn't get worse.
                    I had to remote-mount the oil feed adapter because the vibration from it hanging off the side of the engine with the pressure sender attached to it eventually cracked one of the L fittings, and the last thing I want is a turbo with no oil feed.
                    I also need to work out a bracket to support the exhaust at the downpipe, but I think that is being done at the same time as the WG piping.
                    I have a T3 heatshield for the hot side of the turbo, so what should help with underhood temps, and I have some silicone couplers from siliconeintakes.com going in to replace the crappy rubber blue ones from ebay. The ebay couplers also seem to have a tendency to pop off under boost.
                    The LC1 issue has now been remedied. The main controller died, and even though it was out of warranty, Innovate sent me a new one, no questions asked. Even if their quality could use some help, at least their service is good.
                    So first order of business when I get the car to Purdue will be to tune AFRs and get ignition set. Right now I have fuel and spark cut set so I never go above 1 psi, so I'll just steadily creep up on the goal of 7.5 psi for now, and then up it to 10psi once everything is reliable and sorted. At some point, I may also be swapping in a med-case 373 lsd, because I get the feeling that my gearing is going to be wayyyy too short. Plus I don't know how well the small case diff can handle the power.
                    Oh, and the turbo comes on pretty strong right at 3000 RPM, which, for an aftermarket turbo install, I'm thrilled with :)
                    Project M42 Turbo
                    • BUDNUNTA
                      • Apr 2005
                      • 996
                      #145
                      Looking Good
                      I bet it feels great to finally get a taste of that boost
                      Is your turbo divided entry?
                      • gearheadE30
                        • Jun 2007
                        • 3734
                        #146
                        yeah, its awesome :). This thing is going to be a riot to drive when all the tuning is done. No, it won't have the power of a swapped car or anything, but I think it'll be a good balance of power and handling for a college kid hah.
                        Yeah, the turbo is divided entry.
                        Project M42 Turbo
                        • e304me
                          • Feb 2006
                          • 1374
                          #147
                          At 10psi I think you will be making more power than a swapped car! If they are stock at least. And yes the boost in power is and still lightweight is great
                          • Dj Buttchug
                            • Jun 2010
                            • 7686
                            #148
                            I think I may have missed this but is your turbo oil and water cooled ?
                            Ig:ryno_pzk
                            • gearheadE30
                              • Jun 2007
                              • 3734
                              #149
                              e304me-yeah, good point haha. Turbos do add a lot of weight though, but in all honesy, I can't feel it. It might understeer a tiny, tiny bit more than it used to, but it's hard to tell and I haven't really driven it that hard yet.
                              DJ-no, definiely just oil cooled/lubricated. Why do you think it's water cooled?
                              Project M42 Turbo
                              • Dj Buttchug
                                • Jun 2010
                                • 7686
                                #150
                                [QUOTE= Why do you think it's water cooled?[/QUOTE]
                                Just wasnt sure if you had coolant lines cause its hard to see in the pics. Its obvious main oil up top but some turbo apps run coolant lines underneath piping ect which makes it hard to see.
                                Looks nice and clean tho!!
                                Ig:ryno_pzk
